Hi guys,
I have a 12v linear actuator, and when i power it up, I hear a click but nothing really happens. However, when I gently push the shaft, it snaps to the correct position. When I cut the power, it retracts as it should. I have had linear actuators working autonomously before, for them to suddenly work strangely like this. I have tested the batteries on a multimeter and they are giving out the correct voltage. Why do I need to push the shaft for it to work?
Please can you help?
That does not seem right! IF it is NOT powered, what makes it move? Are you SURE the actuator is not already at the end of it's movement and an internal stop is disconnecting until you reverse the voltage to the actuator?
