Linear Actuator w/ Proximity Sensor and Counter
Hello,
I have a project where I want to use a linear actuator with a hook to pull a rod rearward, this rod is spring loaded and after a certain distance, the hook is to release the rod and let it spring forward. The linear actuator would then push forward and hook the rod again and repeat. I want to be able to set the cycle count as well as display what the current count is at. I believe I can use some kind of proximity sensor and a trigger mechanism to keep count as well as trigger the hook. I took an electromechanical class a few years ago where we used Arduino to program a robot to navigate a maze so I can somewhat familiar with using arduino. Does anyone have any suggestions on how to move forward with this project?
Start by building the mechanics. That's the most difficult part. Programming an Arduino for a motor control and some switches is the easy part.
And when your mechanics is done, measure the various forces needed for make your project function. Then you will know the mechanical power needed.
Paul
Sounds like a pinball machine actuator.
You might consider a magnetic coil instead of a hook. It can be turned on and off by the Arduino.
Perhaps the magnetic coil could be attached to the top of a cog belt, with a stepper moving the belt.
