Linear encoder from printer, can't get it to work - RESOLVED
EDIT : SOLUTION :)
Seems the encoders are picky on what strip is used !
When I hooked up the original pair from the printer with the connections and code below it works :)
Hi all,
I'm trying to use a q9846 or Q9864 to measure displacement.
Now I hooked it up to my arduino uno and also mega like this:
(pinout from datasheet)
I'm using this library:
And my code is the basic example from the library zip file:
/* Encoder Library - Basic Example
 * http://www.pjrc.com/teensy/td_libs_Encoder.html
 * This example code is in the public domain.
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder myEnc(2, 3);
//   avoid using pins with LEDs attached
  Serial.println("Basic Encoder Test:");
long oldPosition  = -999;
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
  Serial.println(digitalRead(2));
  Serial.println(digitalRead(3));
I added
To see the input on the pins. But they both stay at 1 constantly.
Also if I put a piece of paper into the encoder. Shouldn't they do to zero then ?
I tested with two different Q9846 encoders and oneQ9864.
What am I doing wrong here ?
Any hint would be welcome,
Thanks
did you tried with a slotted wheel?
blimpyway:
Yes I did, but didn't work with this encoder - got it to work though, see opening post with edit.
