Hi All,
Being a new bee, I am trying to link a variable to a temperature gauge in my widget in order , however having problem linking the right code, can anyone please help, I have shared the code on here .
regards
type or paste code here
#include <Wire.h>
#include "max6675.h"
LiquidCrystal_I2C lcd(0x27,16,2);
volatile unsigned int encoderPos = 60; // Inital value for set temp
static boolean MesLessThanSet;
static boolean rotating = false; // debounce management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
//TemSensor
int CLK = 13;
int CS = 10;
int SO = 12;
int relay = 7;
//Encoder
int dt_pin = 3;
int clk_pin = 2;
int clk_old = 0;
static int SetTemp;
int MesTemp;
MAX6675 temp_sensor(CLK, CS, SO);
struct debState
boolean InpOld;
int timer;
struct debCnt
int LtH;
int HtL;
debState St1 = {0};
debCnt Ct1 = {0};
//Definining Termometer Icon
byte tempchar1[8]={B00000, B00001, B00010, B00100, //Row 0, Col 2
B00100, B00100, B00100, B00111,};
byte tempchar2[8]={B00111, B00111, B00111, B01111, //Row 1, Col 2
B11111, B11111, B01111, B00011,};
byte tempchar3[8]={B00000, B10000, B01011, B00100, //ROW 0, Col 3
B00111, B00100, B00111, B11100,};
byte tempchar4[8]={B11111, B11100, B11100, B11110, //Row 1, Col 3
B11111, B11111, B11110, B11000,};
pinMode(dt_pin, INPUT);
pinMode(clk_pin, INPUT);
pinMode(relay, OUTPUT);
digitalWrite(relay,HIGH);
lcd.init(); // initialize the lcd
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Welcome To Cinch ");
lcd.setCursor(2,1);
lcd.print ("Connectivity");
delay(3500);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Oven ID QC XXXX ");
lcd.setCursor(1,1);
lcd.print("Auto Temp Ctrl");
delay(5000);
lcd.clear();
Ct1.LtH = 80;
Ct1.HtL = 80;
St1.InpOld = false;
attachInterrupt(digitalPinToInterrupt(2), doEncoderA, CHANGE);
attachInterrupt(digitalPinToInterrupt(3), doEncoderB, CHANGE);
MesTemp = temp_sensor.readCelsius();
delay(2000);
int State;
rotating = true; // reset the debouncer
lcd.setCursor(0,0);
lcd.print("Set_Temp:");
lcd.setCursor(9,0);
SetTemp = encoderPos;
lcd.print(SetTemp);
lcd.print(char(223));
lcd.print("C");
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("Mes_Temp:");
lcd.setCursor(9,1);
delay(400);
lcd.print(MesTemp);
lcd.print("C");
lcd.print(" ");
if(MesTemp <= SetTemp)
State = true;
else if(MesTemp > SetTemp)
State = false;
MesLessThanSet = debounce(State,&St1,&Ct1, 10);
// Serial.print(MesLessThanSet);
// Serial.print("\t ");
// Serial.println(St1.timer);
if(MesLessThanSet == true)
digitalWrite(relay,LOW);
printCustom(MesLessThanSet);
else if(MesLessThanSet == false)
//Debounce
boolean debounce(boolean x, debState *st, debCnt *cn, int rtr)
if(x == st->InpOld)
st->timer = 0;
if(st->timer >= ((x!=false) ? cn->LtH : cn->HtL))
st->timer = 0;
st->InpOld = x;
st->timer += rtr;
return st->InpOld;
// Interrupt on A changing state
void doEncoderA() {
// debounce
if ( rotating ) delay (1); // wait a little until the bouncing is done
// Test transition, did things really change?
if ( digitalRead(2) != A_set ) { // debounce once more
A_set = !A_set;
// adjust counter + if A leads B
if ( A_set && !B_set )
encoderPos += 1;
rotating = false; // no more debouncing until loop() hits again
// Interrupt on B changing state, same as A above
void doEncoderB()
if ( digitalRead(3) != B_set ) {
B_set = !B_set;
// adjust counter - 1 if B leads A
if ( B_set && !A_set )
if(encoderPos > 0)
encoderPos -= 1;
rotating = false;
void printCustom(boolean x)
if(x == true)
lcd.createChar(1,tempchar1);
lcd.createChar(2,tempchar2);
lcd.createChar(3,tempchar3);
lcd.createChar(4,tempchar4);
lcd.setCursor(14,0);
lcd.write(1);
lcd.setCursor(14,1);
lcd.write(2);
lcd.setCursor(15,0);
lcd.write(3);
lcd.setCursor(15,1);
lcd.write(4);
else if(x == false)
lcd.print(" ");
lcd.print(" ");
lcd.print(" ");
lcd.print(" ");
