[45226.477446] usb 3-1: new full-speed USB device number 3 using xhci_hcd
[45226.614596] usb 3-1: New USB device found, idVendor=303a, idProduct=1001, bcdDevice= 1.01
[45226.614618] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[45226.614625] usb 3-1: Product: USB JTAG/serial debug unit
[45226.614630] usb 3-1: Manufacturer: Espressif
[45226.614635] usb 3-1: SerialNumber: 34:85:18:71:4E:D4
[45226.714381] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
[45226.714446] usbcore: registered new interface driver cdc_acm
[45226.714449] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[45503.352570] usb 3-1: USB disconnect, device number 3
[45503.858722] usb 3-1: new full-speed USB device number 4 using xhci_hcd
[45503.996182] usb 3-1: New USB device found, idVendor=303a, idProduct=1001, bcdDevice= 1.01
[45503.996205] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[45503.996212] usb 3-1: Product: USB JTAG/serial debug unit
[45503.996217] usb 3-1: Manufacturer: Espressif
[45503.996222] usb 3-1: SerialNumber: 34:85:18:71:4E:D4
[45503.998453] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
[46302.298091] usb 3-1: USB disconnect, device number 4
[46314.919029] usb 3-2: new full-speed USB device number 5 using xhci_hcd
[46315.055962] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[46315.055985] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[46315.055992] usb 3-2: Product: USB2.0-Ser!
[46315.363099] usbcore: registered new interface driver usbserial_generic
[46315.363119] usbserial: USB Serial support registered for generic
[46315.372655] usbcore: registered new interface driver ch341
[46315.372696] usbserial: USB Serial support registered for ch341-uart
[46315.372717] ch341 3-2:1.0: ch341-uart converter detected
[46315.373914] ch341-uart ttyUSB0: break control not supported, using simulated break
[46315.375015] usb 3-2: ch341-uart converter now attached to ttyUSB0
[46676.849368] usb 3-2: USB disconnect, device number 5
[46676.849739] usb 3-2: failed to send control message: -19
[46676.850235] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[46676.850296] ch341 3-2:1.0: device disconnected
[46679.947271] usb 3-2: new full-speed USB device number 6 using xhci_hcd
[46680.084252] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[46680.084272] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[46680.084279] usb 3-2: Product: USB2.0-Ser!
[46680.086043] ch341 3-2:1.0: ch341-uart converter detected
[46680.087067] ch341-uart ttyUSB0: break control not supported, using simulated break
[46680.087474] usb 3-2: ch341-uart converter now attached to ttyUSB0
[46936.522658] usb 3-2: USB disconnect, device number 6
[46936.523037] usb 3-2: failed to send control message: -19
[46936.523517] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[46936.523678] ch341 3-2:1.0: device disconnected
[46940.112529] usb 3-2: new full-speed USB device number 7 using xhci_hcd
[46940.253539] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[46940.253562] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[46940.253569] usb 3-2: Product: USB2.0-Ser!
[46940.255249] ch341 3-2:1.0: ch341-uart converter detected
[46940.256147] ch341-uart ttyUSB0: break control not supported, using simulated break
[46940.257117] usb 3-2: ch341-uart converter now attached to ttyUSB0
[47545.194002] perf: interrupt took too long (6314 > 6270), lowering kernel.perf_event_max_sample_rate to 31500
[47793.991195] usb 3-2: USB disconnect, device number 7
[47793.991903] usb 3-2: failed to send control message: -19
[47793.992582] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[47793.992637] ch341 3-2:1.0: device disconnected
[47796.004036] systemd-journald[288]: Under memory pressure, flushing caches.
[47798.023852] systemd-journald[288]: Under memory pressure, flushing caches.
[49362.328926] usb 3-2: new full-speed USB device number 8 using xhci_hcd
[49362.464832] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[49362.464841] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[49362.464844] usb 3-2: Product: USB2.0-Ser!
[49362.466207] ch341 3-2:1.0: ch341-uart converter detected
[49362.466622] ch341-uart ttyUSB0: break control not supported, using simulated break
[49362.468610] usb 3-2: ch341-uart converter now attached to ttyUSB0
[50551.180061] usb 3-2: USB disconnect, device number 8
[50551.180521] usb 3-2: failed to send control message: -19
[50551.180973] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[50551.181048] ch341 3-2:1.0: device disconnected
[51010.540387] usb 3-2: new full-speed USB device number 9 using xhci_hcd
[51010.677274] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[51010.677296] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[51010.677303] usb 3-2: Product: USB2.0-Ser!
[51010.680758] ch341 3-2:1.0: ch341-uart converter detected
[51010.681261] ch341-uart ttyUSB0: break control not supported, using simulated break
[51010.681508] usb 3-2: ch341-uart converter now attached to ttyUSB0
[53924.680835] usb 3-2: USB disconnect, device number 9
[53924.681270] usb 3-2: failed to send control message: -19
[53924.681580] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[53924.681616] ch341 3-2:1.0: device disconnected
[53960.542661] usb 3-2: new full-speed USB device number 10 using xhci_hcd
[53960.679710] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[53960.679732] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[53960.679739] usb 3-2: Product: USB2.0-Ser!
[53960.682249] ch341 3-2:1.0: ch341-uart converter detected
[53960.683458] ch341-uart ttyUSB0: break control not supported, using simulated break
[53960.683705] usb 3-2: ch341-uart converter now attached to ttyUSB0
[54144.151710] usb 3-2: USB disconnect, device number 10
[54144.152121] usb 3-2: failed to send control message: -19
[54144.152756] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[54144.152822] ch341 3-2:1.0: device disconnected
[54204.508085] usb 3-1: new full-speed USB device number 11 using xhci_hcd
[54204.644972] usb 3-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[54204.644994] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[54204.645001] usb 3-1: Product: USB2.0-Ser!
[54204.648850] ch341 3-1:1.0: ch341-uart converter detected
[54204.649423] ch341-uart ttyUSB0: break control not supported, using simulated break
[54204.649609] usb 3-1: ch341-uart converter now attached to ttyUSB0
[54243.650360] usb 3-1: USB disconnect, device number 11
[54243.650807] usb 3-1: failed to send control message: -19
[54243.650962] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[54243.650988] ch341 3-1:1.0: device disconnected
[54305.942987] usb 3-2: new full-speed USB device number 12 using xhci_hcd
[54306.079410] usb 3-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[54306.079418] usb 3-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[54306.079421] usb 3-2: Product: USB2.0-Ser!
[54306.080212] ch341 3-2:1.0: ch341-uart converter detected
[54306.080594] ch341-uart ttyUSB0: break control not supported, using simulated break
[54306.082934] usb 3-2: ch341-uart converter now attached to ttyUSB0
