Livrary for infrared on unor4 maxima?
is there a library for infra red transmit/receive for unor4 maxima
Hi @jerru.
Are you referring to the UNO R4 Minima? I'm not aware of any board named "unor4 maxima".
If you are referring to the UNO R4 Minima, then you should give the excellent "IRremote" library a try. I haven't tried it personally, but it is reported (by one of the library's maintainers, no less) here that the library does work with the UNO R4 Minima:
You can install the library via the Arduino IDE Library Manager. After you install it, you will find example sketches that demonstrate usage of the the library under Arduino IDE's File > Examples > IRremote"
