LM317T voltage regulator power issue
I want to power a wemos mini and an esp01 with 3.3V. I used the following setup :
the input voltage is DC 12V. R1 =200 ohm. R2=330 ohm. I get 3.3V as output (I measured it with a multi-meter). I tried to power an esp8266 wemos mini with this voltage (3.3V) but it failed. the LM317 became very hot. I tried to power an esp01 but still failed. I believe the setup doesn't output enough power to run the microcontrollers. The description of the LM317 says:
regulator capable of supplying more than 1.5 A over an output-voltage range of 1.25 V to 37 V.
I wonder if I missed something in the setup. Any help is appreciated.
A TO220 cap can radiate 1 watt being naked. Just calculate the power lost in the 317. If it exceeds 1 watt, add a heatsink.
Where are the caps for input and output?
Then the regulator burns 12-3.3V = 8.7 times the current. Without a heat sink it may be at its limits with only 120mA.
The regulator dissipates "dropped voltage times current".
That's why we don't use linear regulators anymore if volt drop and current are high.
A switching buck supply is a much better choice here.
Leo..
Thank you All for your clarifications. I will use a Step Down Power Supply Module instead of the linear regulator.
