I'm using a LM393 Photo diode if i am not wrong.
I want the photo diode to test the surroundings for light and make an ultrasonic sensor test for the distance between an object and the Arduino if there is no light, turning on a led strip should the distance between the object and the Arduino be smaller than the set distance which can be adjusted by a rotary encoder.
Below is my code for before the LM393 photo diode sensor was added in:
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define echoPin 12 // attach pin D12 Arduino to pin Echo of HC-SR04
#define trigPin 13 //attach pin D13 Arduino to pin Trig of HC-SR04
#define PIN 9
// Rotary Encoder Inputs
#define CLK 2
#define DT 3
#define SW 4
int counter = 0;
int currentStateCLK;
int lastStateCLK;
String currentDir ="";
unsigned long lastButtonPress = 0;
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
// defines variables
long duration; // variable for the duration of sound wave travel
int distance_cm; // variable for centimeters measurement
// Set encoder pins as inputs
pinMode(CLK,INPUT);
pinMode(DT,INPUT);
pinMode(SW, INPUT_PULLUP);
// Read the initial state of CLK
lastStateCLK = digitalRead(CLK);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
pinMode(trigPin, OUTPUT); // Sets the trigPin as an OUTPUT
pinMode(echoPin, INPUT); // Sets the echoPin as an INPUT
Serial.begin(9600); // // Serial Communication is starting with 9600 of baudrate speed
Serial.println("Ultrasonic Sensor HC-SR04 Test"); // print some text in Serial Monitor
Serial.println("with Arduino UNO R3");
lcd.init(); // initialize the lcd
lcd.init();
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
// Read the current state of CLK
currentStateCLK = digitalRead(CLK);
// If last and current state of CLK are different, then pulse occurred
// React to only 1 state change to avoid double count
if (currentStateCLK != lastStateCLK && currentStateCLK == 1){
// If the DT state is different than the CLK state then
// the encoder is rotating CCW so decrement
if (digitalRead(DT) != currentStateCLK) {
counter --;
currentDir ="CCW";
// Encoder is rotating CW so increment
counter ++;
currentDir ="CW";
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Set: ");
lcd.println(counter);
lcd.print(" cm");
// Remember last CLK state
lastStateCLK = currentStateCLK;
// Read the button state
int btnState = digitalRead(SW);
//If we detect LOW signal, button is pressed
if (btnState == LOW) {
//if 50ms have passed since last LOW pulse, it means that the
//button has been pressed, released and pressed again
if (millis() - lastButtonPress > 50) {
Serial.println("Button pressed!");
// Remember last button press event
lastButtonPress = millis();
// Put in a slight delay to help debounce the reading
delay(1);
// Clears the trigPin condition
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin HIGH (ACTIVE) for 10 microseconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance_cm = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
// Displays the distance on the Serial Monitor
lcd.backlight();
lcd.setCursor(0, 1);
lcd.print("Distance: ");
lcd.print(distance_cm);
lcd.println(" cm");
static unsigned long LastTimeDistanceWasLE10 = 0;
if (distance_cm <= counter)
LastTimeDistanceWasLE10 = millis();
if (millis() - LastTimeDistanceWasLE10 >= 3000)
colorWipe(strip.Color( 0, 0, 0), 0);
colorWipe(strip.Color( 255, 125, 125), 0);
and below here is the new code that tries to incorporate the LM393 photo diode sensor:
#define PIN 9
#define CLK 2
#define DT 3
#define SW 4
int counter = 0;
int lastStateCLK;
pinMode(CLK,INPUT);
pinMode(DT,INPUT);
strip.begin();
lcd.init();
pinMode(8,INPUT);
strip.show();
delay(wait);
counter --;
currentDir ="CCW";
counter ++;
currentDir ="CW";
lcd.backlight();
lcd.print("Set: ");
lcd.print(" cm");
delay(1);
lcd.backlight();
lcd.println(" cm");
int temp=digitalRead(8); //assign value of LDR sensor to a temporary variable
delay(300);
if (temp==HIGH)
I have no idea why but after I changed the code to incorporate the LM393 photo diode, the code no longer works and the led strip doesn't turn on even after the distance between the object and the Arduino is far less than the set distance. Is my LM393 sensor just faulty, am I using the correct sensor or is my code wrong?
