Load cell not responding
Hi, my load cell is not reading any values. It is giving me '0 g'. I am using Arduino Mega, HX711, 1kg load cell.
void weightControl(float desiredWeight) {
lcd.setCursor(0, 0);
lcd.print("Measuring Weight");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN );
scale.set_scale(1590.153);
scale.tare();
float weight = scale.get_units(10); // Read the average of 10 measurements for better stability
Serial.print("Measured Weight: ");
Serial.println(weight, 2);
lcd.setCursor(0, 1);
lcd.print("Weight: ");
lcd.print(weight, 1); // Display weight with one decimal place
lcd.print (" g");
while (weight < desiredWeight) {
// Rotate motor until the target weight is reached
digitalWrite(relayPin, LOW);
// Stop the motor
digitalWrite(relayPin, HIGH);
lcd.clear();
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Hi @3marie_butterfly
welcome to the arduino-forum.
You should post your code inside so called code-tags as a code-section
The code you have posted is not a complete sketch.
Here is a tutorial how to post code as a code-section
This is a demo-code for HX711 based loadcells which prints to the serial monitor.
to what IO-pins do you have connected clock and datapin of the HX711-module?
post a hand drawn schematic what is connected to what
//    FILE: HX_kitchen_scale.ino
//  AUTHOR: Rob Tillaart
// PURPOSE: HX711 demo
//     URL: https://github.com/RobTillaart/HX711
#include "HX711.h"
HX711 scale;
uint8_t dataPin = 6;
uint8_t clockPin = 7;
  Serial.println(__FILE__);
  Serial.print("LIBRARY VERSION: ");
  Serial.println(HX711_LIB_VERSION);
  scale.begin(dataPin, clockPin);
  Serial.print("UNITS: ");
  Serial.println(scale.get_units(10));
  Serial.println("\nEmpty the scale, press a key to continue");
  while(!Serial.available());
  while(Serial.available()) Serial.read();
  scale.tare();
  Serial.println("\nPut 1000 gram in the scale, press a key to continue");
  scale.calibrate_scale(1000, 5);
  Serial.println("\nScale is calibrated, press a key to continue");
  // Serial.println(scale.get_scale());
  // Serial.println(scale.get_offset());
  Serial.read();
  delay(250);
Welcome! Can you post an annotated schematic showing exactly how you wired it, be sure to show all connections, parts, power, ground and power sources.
