We plan to include robust load cells in our Arduino project. The load cells should weight cement (1 to 2 tons) and it should be outdoor in the dirt
Can somebody recommend good load cells for our project? I guess we should include 4 cells each with the max capacity of 1-2 tons due to the weight of the iron bucket and the loading process or what would be a good solution? The load cells should have a maximum variance of +/- 1 kg (is this possible)?
Is there a load cell conversion module which can be recommended?
The goal of the project is to show the actual weight on a lcd display and stop the process when the load has reached X kg.
Thank you for your response. It should be very simple but robust. We haven't set up anything. We have a cement auger which should be switched off when X kg are loaded (for example with a relay).
I tried to draw a draft.
Thank you very much! Every advice is very welcome!
Good start. Now do you expect the load cells to return to zero when the load is removed? What mechanism? Will your load cells actually return to zero or will you need to re calibrate after each load is removed? In other words, what is the required recovery time for the load cells?
Looks great. Thank you very much. Is the maximum 500 kg for each cell? We had to install 6 to 8 units to reach the 4 tons? Is it possible to connect the cells with an arduino?
MT19:
2. Choose the appropriate load cell. Find its complete Technical Specification (Excitation Voltage, Response in mV for Full Load, and etc) and post this information or its link.
3. You can easily interface your load cell with a LCD via HX711 Module (amplifier + ADC) and the Arduino UNO.
4. You just want to measure the load only or you want to enter the price from a Keypad and compute the cost as well?
Can we use HX711 for any load cell and Arduino UNO combination or only for some specific load cells with specific Arduinos only it will work? Because in many videos I have seen Hx711 using for measuring only small weights can it be used for heavy (load cells) weights?
Nataraj18:
2. The data sheet says --
Any load cell whose differential output is either 0 to 20 mV or 0 to 40 mV can be connected with Channel-A of the HX711 Module; the bias voltage of the Module is 5V.
