Load cells are not working together
Hello everyone, I'm trying to get two pairs of load cells to read different values at the same time on the ESP32. The library that im using is HX711_ADC.
here's the link: GitHub - olkal/HX711_ADC: Arduino library for the HX711 24-bit ADC for weight scales
But, when i upload the example sketch from the library "Read_2x_load_cell.ino", the readings are very unstable, they keep changing all the time, even with no weight on the load cells, and sometimes I get very high or negative values.
Here's the code:
// HX711_ADC.h
// Arduino master library for HX711 24-Bit Analog-to-Digital Converter for Weigh Scales
// Olav Kallhovd sept2017
// Tested with      : HX711 asian module on channel A and YZC-133 3kg load cell
// Tested with MCU  : Arduino Nano
// This is an example sketch on how to use this library for two ore more HX711 modules
// Settling time (number of samples) and data filtering can be adjusted in the config.h file
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout_1 = 4; //mcu > HX711 no 1 dout pin
const int HX711_sck_1 = 5; //mcu > HX711 no 1 sck pin
const int HX711_dout_2 = 6; //mcu > HX711 no 2 dout pin
const int HX711_sck_2 = 7; //mcu > HX711 no 2 sck pin
//HX711 constructor (dout pin, sck pin)
HX711_ADC LoadCell_1(HX711_dout_1, HX711_sck_1); //HX711 1
HX711_ADC LoadCell_2(HX711_dout_2, HX711_sck_2); //HX711 2
const int calVal_eepromAdress_1 = 0; // eeprom adress for calibration value load cell 1 (4 bytes)
const int calVal_eepromAdress_2 = 4; // eeprom adress for calibration value load cell 2 (4 bytes)
unsigned long t = 0;
  Serial.begin(57600); delay(10);
  Serial.println("Starting...");
  float calibrationValue_1; // calibration value load cell 1
  float calibrationValue_2; // calibration value load cell 2
  calibrationValue_1 = 696.0; // uncomment this if you want to set this value in the sketch
  calibrationValue_2 = 733.0; // uncomment this if you want to set this value in the sketch
#if defined(ESP8266) || defined(ESP32)
  //EEPROM.begin(512); // uncomment this if you use ESP8266 and want to fetch the value from eeprom
#endif
  //EEPROM.get(calVal_eepromAdress_1, calibrationValue_1); // uncomment this if you want to fetch the value from eeprom
  //EEPROM.get(calVal_eepromAdress_2, calibrationValue_2); // uncomment this if you want to fetch the value from eeprom
  LoadCell_1.begin();
  LoadCell_2.begin();
  //LoadCell_1.setReverseOutput();
  //LoadCell_2.setReverseOutput();
  unsigned long stabilizingtime = 2000; // tare preciscion can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  byte loadcell_1_rdy = 0;
  byte loadcell_2_rdy = 0;
  while ((loadcell_1_rdy + loadcell_2_rdy) < 2) { //run startup, stabilization and tare, both modules simultaniously
    if (!loadcell_1_rdy) loadcell_1_rdy = LoadCell_1.startMultiple(stabilizingtime, _tare);
    if (!loadcell_2_rdy) loadcell_2_rdy = LoadCell_2.startMultiple(stabilizingtime, _tare);
  if (LoadCell_1.getTareTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 no.1 wiring and pin designations");
  if (LoadCell_2.getTareTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 no.2 wiring and pin designations");
  LoadCell_1.setCalFactor(calibrationValue_1); // user set calibration value (float)
  LoadCell_2.setCalFactor(calibrationValue_2); // user set calibration value (float)
  Serial.println("Startup is complete");
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check for new data/start next conversion:
  if (LoadCell_1.update()) newDataReady = true;
  LoadCell_2.update();
  //get smoothed value from data set
  if ((newDataReady)) {
    if (millis() > t + serialPrintInterval) {
      float a = LoadCell_1.getData();
      float b = LoadCell_2.getData();
      Serial.print("Load_cell 1 output val: ");
      Serial.print(a);
      Serial.print("    Load_cell 2 output val: ");
      Serial.println(b);
      newDataReady = 0;
      t = millis();
  // receive command from serial terminal, send 't' to initiate tare operation:
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if (inByte == 't') {
      LoadCell_1.tareNoDelay();
      LoadCell_2.tareNoDelay();
  //check if last tare operation is complete
  if (LoadCell_1.getTareStatus() == true) {
    Serial.println("Tare load cell 1 complete");
  if (LoadCell_2.getTareStatus() == true) {
    Serial.println("Tare load cell 2 complete");
The values in the serial monitor:
And the diagram:
Any help would be greatly appreciated.
It looks like you have not done a calibration yet. Also look at the .h file to determine what functions exist, I used a function that took several readings, sorted them and threw away the top and bottom n entries.
Oh, sorry, I forgot to mention the calibration value I obtained. Even with that value, the output readings are high and unstable. I couldn't identify the functions in the config.h file. Could you show me an example, please? I would be grateful.
The config.h file show this:
   HX711_ADC
   Arduino library for HX711 24-Bit Analog-to-Digital Converter for Weight Scales
HX711_ADC configuration
Allowed values for "SAMPLES" is 1, 2, 4, 8, 16, 32, 64 or 128.
Higher value = improved filtering/smoothing of returned value, but longer setteling time and increased memory usage
Lower value = visa versa
The settling time can be calculated as follows:
Settling time = SAMPLES + IGN_HIGH_SAMPLE + IGN_LOW_SAMPLE / SPS
Example on calculating settling time using the values SAMPLES = 16, IGN_HIGH_SAMPLE = 1, IGN_LOW_SAMPLE = 1, and HX711 sample rate set to 10SPS:
(16+1+1)/10 = 1.8 seconds settling time.
Note that you can also overide (reducing) the number of samples in use at any time with the function: setSamplesInUse(samples).
#ifndef HX711_ADC_config_h
#define HX711_ADC_config_h
//number of samples in moving average dataset, value must be 1, 2, 4, 8, 16, 32, 64 or 128.
#define SAMPLES 					16		//default value: 16
//adds extra sample(s) to the dataset and ignore peak high/low sample, value must be 0 or 1.
#define IGN_HIGH_SAMPLE 			1		//default value: 1
#define IGN_LOW_SAMPLE 				1		//default value: 1
//microsecond delay after writing sck pin high or low. This delay could be required for faster mcu's.
//Mcu's reported to need this delay is the ESP32 (issue #35) and RP2040, the Arduino Due and ESP8266 seems to run fine without it.
//Change the value to '0' to disable the delay.
#define SCK_DELAY					1		//default value: 1 (enabled)
//if you have some other time consuming (>60μs) interrupt routines that trigger while the sck pin is high, this could unintentionally set the HX711 into "power down" mode
//if required you can change the value to '1' to disable interrupts when writing to the sck pin.
#define SCK_DISABLE_INTERRUPTS		0		//default value: 0
#endif
Have You tried reading only one HX711 using a proper test code?
Yeah, with only one hx711. the values is stable and normal, but when i add one more hx711 the issues start to appear
I see you are using a different library. I used the HX711 library. As with any library, look in the .h file for the functions. If you do a successful compile, then right click the include statement, highlighting the library name, and click on GoTo Definition, which will open a read-only tab containing the .h (header) file.
I made my scale by the usual method of starting with a library example. Highly recommended.
I have seen several attempts at multi HX711 but have never seen one that works. I have no idea why you would need one, for a few bucks you can get the load cells in sizes up to 50kg or 100lbs. Most people can't lift 100lbs so that $10 solution should be great.
Good luck.
Oh, i understand. Thanks!!
