Loading a library
I have modified a library (.cpp)
How do I get the IDE to use it?
If I unload and re-load it, it downloads the cloud version, over-writing my file.
TIA
Hi @marty_k.
Put the modified library under the libraries folder of your sketchbook. Arduino IDE will then use the modified library just the same as it would do with any library you installed via Library Manager.
I'm not sure I understand what you mean by this.
Please add a reply here on this forum topic that provides a detailed description of the exact procedure you are performing to "unload and re-load".
Pleas also make sure you clearly describe what you are referring to by "it".
The file is in it's original location C:\users\........\libraries\......
If I just run my IDE, it does not see the change. Doesn't it get compiled somewhere?
You want to know how I unload it? Is there more than one way?
Please provide a detailed description of the observations you made that led you to the conclusion that it did not see the change. Make sure to include the following information:
  • What did you do?
  • What were the results you expected from doing that thing?
  • What were the results you observed that did not match your expectations?
If you encountered any errors or warnings, please provide the full and exact text of those messages.
We don't use the term "unload" in relation to Arduino libraries. I'll ask again for you to provide a detailed description of what you mean by this.
I guess you think you are saving time by being vague. I can assure you it is just the opposite. Those who provide sufficient information often receive a high quality solution from the forum helpers in a matter of minutes. Conversely, those who don't provide sufficient information and then resist efforts by the helpers to obtain that information often end up going through days of inefficient and unpleasant back and forth as we struggle to squeeze the information we need from them.
I am not being vague. There is nothing complicated about this.
The file I modified is SparkFun_Alphanumeric_Display.cpp
Since the change I made (modified one character) was no showing, I "removed" it. Installing it again did not use my file but a new download, over-writing mine. No errors.
Then why didn't you provide the information I requested:
Library Manager installs the official version of the library. If you want Arduino IDE to use your modified version of the library, then you must refrain from reinstalling or updating the library via Library Manager.
Ok so its your turn to be vague !
How should I install it?
I already told you how to do that:
If there is something you don't understand about what I wrote, provide a detailed description and I will explain further.
I notice you still haven't answered my question from post #4
That doesn't make sense. After I remove it from the IDE, it is no longer avail. Yes, the file is still there but that's all.
Post #4 was answered.
The Sparkfun library consists of a .h and a .cpp file.
A simple solution is to copy those files to your sketch directory.
You'll need to change the include statement in your sketch to #include "SparkFun_Alphanumeric_Display.h" (note the double quotes). You will also need to change the include in the .cpp file.
Advantage of this approach is that an update of the library by Sparkfun will not wipe your changes.
It can also be a disadvantage as bug fixes in the library will not reflect in the files of your your sketch and you have to add those two (modified) files to every sketch.
The "library" is now part of your sketch; I did put the word library between double quotes because it's now no longer a library.
You can observe which library is used when you compile with verbose output during compilation enabled in File → Preferences.
Original
FQBN: arduino:avr:mega
Using board 'mega' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8
Using core 'arduino' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8
Detecting libraries used...
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged.libsdetect.d
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged.libsdetect.d
Alternatives for SparkFun_Alphanumeric_Display.h: [SparkFun Qwiic Alphanumeric Display Arduino Library@2.2.11]
ResolveLibrary(SparkFun_Alphanumeric_Display.h)
  -> candidates: [SparkFun Qwiic Alphanumeric Display Arduino Library@2.2.11]
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src\Wire.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\libraries\Wire\Wire.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src\utility\twi.c -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\libraries\Wire\utility\twi.c.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src\SparkFun_Alphanumeric_Display.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\SparkFun_Alphanumeric_Display.cpp.libsdetect.d
The list of included libraries has been changed... rebuilding all libraries.
Generating function prototypes...
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged -o C:\Users\bugge\AppData\Local\Temp\3861050042\sketch_merged.cpp
C:\Users\bugge\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\bugge\AppData\Local\Temp\3861050042\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\src" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\demo.01.ino.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\demo.01.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\src" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\utility\\twi.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\src" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\Wire.cpp.o"
Compiling library "SparkFun Qwiic Alphanumeric Display Arduino Library"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\src\\SparkFun_Alphanumeric_Display.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\SparkFun_Alphanumeric_Display.cpp.o"
Compiling core...
Using precompiled core: C:\Users\bugge\AppData\Local\arduino\cores\arduino_avr_mega_cpu_atmega2560_784ccd771d8a49968e68b822ada55589\core.a
Linking everything together...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\demo.01.ino.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\\SparkFun_Alphanumeric_Display.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/..\\..\\cores\\arduino_avr_mega_cpu_atmega2560_784ccd771d8a49968e68b822ada55589\\core.a" "-LC:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF" -lm
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.eep"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.hex"
Using library Wire at version 1.0 in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire
Using library SparkFun Qwiic Alphanumeric Display Arduino Library at version 2.2.11 in folder: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.elf"
Sketch uses 6300 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 635 bytes (7%) of dynamic memory, leaving 7557 bytes for local variables. Maximum is 8192 bytes.
Local files
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\SparkFun_Alphanumeric_Display.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\SparkFun_Alphanumeric_Display.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src\Wire.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\libraries\Wire\Wire.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src\utility\twi.c -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\libraries\Wire\utility\twi.c.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\mega -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\libraries\Wire\src C:\Users\bugge\AppData\Local\arduino\sketches\EBF8D2E233924A8350D3888ACCB966FF\sketch\demo.01.ino.cpp.merged -o C:\Users\bugge\AppData\Local\Temp\2668240969\sketch_merged.cpp
C:\Users\bugge\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\bugge\AppData\Local\Temp\2668240969\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\SparkFun_Alphanumeric_Display.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\SparkFun_Alphanumeric_Display.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\demo.01.ino.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\demo.01.ino.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\CDC.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\USBCore.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\Print.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\Print.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\Stream.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\Tone.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\PluggableUSB.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\IPAddress.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\WInterrupts.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\WMath.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\abi.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\abi.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\WString.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\WString.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\hooks.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\hooks.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\main.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\main.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\new.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\new.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\wiring.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_analog.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_digital.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_pulse.S.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_pulse.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\mega" "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_shift.c.o"
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp: In function 'void* operator new(std::size_t, std::nothrow_t)':
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp:59:60: warning: unused parameter 'tag' [-Wunused-parameter]
 void * operator new(std::size_t size, const std::nothrow_t tag) noexcept {
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp: In function 'void* operator new [](std::size_t, const std::nothrow_t&)':
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp:68:63: warning: unused parameter 'tag' [-Wunused-parameter]
 void * operator new[](std::size_t size, const std::nothrow_t& tag) noexcept {
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp: In function 'void operator delete(void*, const std::nothrow_t&)':
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp:103:55: warning: unused parameter 'tag' [-Wunused-parameter]
 void operator delete(void* ptr, const std::nothrow_t& tag) noexcept {
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp: In function 'void operator delete [](void*, const std::nothrow_t&)':
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino\new.cpp:106:57: warning: unused parameter 'tag' [-Wunused-parameter]
 void operator delete[](void* ptr, const std::nothrow_t& tag) noexcept {
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\CDC.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\IPAddress.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\PluggableUSB.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\Print.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\Stream.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\Tone.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\USBCore.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\WInterrupts.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\WMath.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\WString.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\abi.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\hooks.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\main.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\new.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_analog.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_digital.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_pulse.S.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_pulse.c.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\core.a" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\core\\wiring_shift.c.o"
Archiving built core (caching) in: C:\Users\bugge\AppData\Local\arduino\cores\arduino_avr_mega_cpu_atmega2560_784ccd771d8a49968e68b822ada55589\core.a
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/demo.01.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\SparkFun_Alphanumeric_Display.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\sketch\\demo.01.ino.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF/core\\core.a" "-LC:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\EBF8D2E233924A8350D3888ACCB966FF" -lm
Note that in the latter there is no mention of the library under "Using library ..." near the end. There is now a mention under "Compiling sketch" that indicates that the local copy is used.
Thanks for this, but I'd like to keep the original file location only for now.
What is the technique to do this?
Thanks.
