The list of included libraries has been changed... rebuilding all libraries
Windows 11
IDE 2.3.10
Regardless of board (ESP32, Arduino, Nesso N1), this happens nearly every time I compile.
The list of included libraries has been changed... rebuilding all libraries.
  • No warnings in the compiler before or after the "rebuilding."
  • I have moved everything Arduino off OneDrive (which now contains zero files).
  • I have only recently noticed this is happening (October 2026).
I understand updates occur, and I do not want to stop updates.
I do not believe this (always rebuilding) is the intent of the IDE (authors).
Just FYI
I did see the same message yesterday while verifying with ctrl<shiftr to clear the cache.
I use CTRL-U to compile and upload.
After looking a little further my observation is that that message only shows when there are no cached files.
When recompiling the same sketch (for the same board) the message does not show. ctrl<shiftr clears the cache.
IDE 2.3.10 uses CLI 1.5.1
So this is before "Generating function prototypes". There are at least three conditions required to see it: two to actually make it happen and one to see that message.
The receiver in this method is (b *Builder) -- which has both logIfVerbose and separately a logger that has a VerbosityLevel that must also be VerbosityVerbose.
I wonder if it's been happening before but you're only seeing the message now. Do you see It with a new sketch that uses a single library? And then rebuild it?
I did only notice it yesterday; that does not mean it did not happened before. Here is a test sketch that shows the behaviour, fresh, not saved
#include <FastLED.h>
Verify output
FQBN: arduino:avr:nano
Using board 'nano' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8
Using core 'arduino' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8
Detecting libraries used...
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.merged -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.merged.libsdetect.d
Alternatives for FastLED.h: [FastLED@3.10.6]
ResolveLibrary(FastLED.h)
  -> candidates: [FastLED@3.10.6]
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.merged -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.merged.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\extras+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\extras+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.asset+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.asset+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.audio+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.audio+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.channels+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.channels+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.chipsets+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.chipsets+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.codec+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.codec+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.control+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.control+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fled+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fled+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.font+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.font+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fs+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fs+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fs.embedded+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fs.embedded+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fs.sd+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fs.sd+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fx+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fx+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.gfx+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.gfx+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.log+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.log+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.math+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.math+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.net+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.net+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.remote+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.remote+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.sensors+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.sensors+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.stl+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.stl+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.system+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.system+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.task+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.task+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.test+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.test+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.ui+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.ui+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.video+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.video+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.wdt+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.wdt+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\platforms+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\platforms+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\src.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\src.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\third_party+.cpp -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\third_party+.cpp.libsdetect.d
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\platforms\esp\32\drivers\gpio_isr_rx\fast_isr.S -o nul -MMD -MF C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\platforms\esp\32\drivers\gpio_isr_rx\fast_isr.S.libsdetect.d
Generating function prototypes...
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\cores\arduino -IC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8\variants\eightanaloginputs -Ic:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.merged -o C:\Users\bugge\AppData\Local\Temp\4131874816\sketch_merged.cpp
C:\Users\bugge\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\bugge\AppData\Local\Temp\4131874816\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\sketch\\sketch_oct12a.ino.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\sketch\\sketch_oct12a.ino.cpp.o"
Compiling libraries...
Compiling library "FastLED"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\extras+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\extras+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.audio+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.audio+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.fs.sd+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fs.sd+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.fled+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fled+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.control+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.control+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.asset+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.asset+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.font+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.font+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.fs+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fs+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.chipsets+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.chipsets+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.codec+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.codec+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.channels+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.channels+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.fs.embedded+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fs.embedded+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.fx+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fx+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.gfx+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.gfx+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.log+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.log+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.math+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.math+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.net+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.net+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.remote+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.remote+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.sensors+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.sensors+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.stl+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.stl+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.system+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.system+.cpp.o"
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/codec/_build.cpp.hpp:9:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.codec+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/codec/mp3.cpp.hpp: In member function 'int fl::third_party::Mp3Minimp3Decoder::decodeFrame(const u8**, fl::size*)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/codec/mp3.cpp.hpp:205:32: warning: large integer implicitly truncated to unsigned type [-Woverflow]
     const fl::size max_input = 0x7fffffff;
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.task+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.task+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.test+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.test+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.ui+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.ui+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.video+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.video+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\fl.wdt+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.wdt+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\platforms+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\platforms+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\src.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\src.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\fl\\build\\third_party+.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\third_party+.cpp.o"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.8\\variants\\eightanaloginputs" "-Ic:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src" "c:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\FastLED\\src\\platforms\\esp\\32\\drivers\\gpio_isr_rx\\fast_isr.S" -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\platforms\\esp\\32\\drivers\\gpio_isr_rx\\fast_isr.S.o"
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/channels/_build.cpp.hpp:9:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.channels+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/channels/channel.cpp.hpp: In member function 'void fl::Channel::raiseColorProfileFallback(const char*)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/channels/channel.cpp.hpp:413:53: warning: unused parameter 'reason' [-Wunused-parameter]
 void Channel::raiseColorProfileFallback(const char* reason) FL_NO_EXCEPT {
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/channels/channel.cpp.hpp: At global scope:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/channels/channel.cpp.hpp:215:13: warning: 'void fl::{anonymous}::emitDisabledDriverError(const fl::string&, const fl::string&, const fl::string&)' defined but not used [-Wunused-function]
 static void emitDisabledDriverError(const fl::string& channelName,
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/stl/_build.cpp.hpp:17:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.stl+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/stl/ieee754_string.cpp.hpp: In function 'fl::u32 fl::ieee754_parse_decimal(const char*, fl::size, fl::size*)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/stl/ieee754_string.cpp.hpp:416:33: warning: left shift count >= width of type [-Wshift-count-overflow]
         if (ieee_mant == (1u << 23)) {
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/gfx/_build.cpp.hpp:20:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.gfx+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/gfx/gamut_map.cpp.hpp:38:44: warning: left shift count >= width of type [-Wshift-count-overflow]
 constexpr i32 kGamutProbeCeilingQ16 = 4 << 16;
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/gfx/gamut_map.cpp.hpp:38:41: warning: right operand of shift expression '(4 << 16)' is >= than the precision of the left operand [-fpermissive]
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/stl/assert.h:3:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/stub/mutex_stub_noop.h:13,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/stub/mutex_stub.h:20,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/mutex.h:50,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/stl/mutex.h:15,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/audio.cpp.hpp:6,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/_build.cpp.hpp:5,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.audio+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/fft/fft_impl.cpp.hpp: In member function 'void fl::audio::fft::Context::initOctaveWise(int, int, float, float, int)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/fft/fft_impl.cpp.hpp:673:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         FL_ASSERT(bands <= 0xFFFF, "CQ_OCTAVE band count exceeds u16 index range");
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/assert_defs.h:103:20: note: in definition of macro 'FASTLED_ASSERT'
             (void)(x);                                                         \
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/fft/fft_impl.cpp.hpp:673:9: note: in expansion of macro 'FL_ASSERT'
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/fft/_build.cpp.hpp:6:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/_build.cpp.hpp:22,
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/fft/fft_impl.cpp.hpp: In member function 'void fl::audio::fft::Context::runOctaveWise(fl::span<const int, 65535>, fl::audio::fft::Bins*)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/audio/fft/fft_impl.cpp.hpp:797:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
             while (next <= mCoverageLast[i]) {
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/stl/flat_map.h:4,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fs/fs.h:9,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/TJpg_Decoder/driver.h:14,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/TJpg_Decoder/driver.cpp.hpp:1,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/TJpg_Decoder/_build.cpp.hpp:8,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/_build.cpp.hpp:6,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\third_party+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/stb/truetype/stb_truetype.cpp.hpp: In function 'fl::third_party::truetype::stbtt__buf fl::third_party::truetype::stbtt__new_buf(const void*, fl::size_t)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/stb/truetype/stb_truetype.cpp.hpp:1197:22: warning: comparison is always true due to limited range of data type [-Wtype-limits]
    STBTT_assert(size < 0x40000000);
             (void)(x);                                                         \
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/stb/truetype/stb_truetype.cpp.hpp:307:28: note: in expansion of macro 'FL_ASSERT'
 #define STBTT_assert(x)    FL_ASSERT(x, "stb_truetype assertion failed")
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/third_party/stb/truetype/stb_truetype.cpp.hpp:1197:4: note: in expansion of macro 'STBTT_assert'
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/_build.cpp.hpp:6:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/_build.cpp.hpp:13,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fx+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp: In member function 'void fl::PerlinParticlePunch::renderAmbient(const fl::PerlinParticlePunch::AmbientParticle&)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp:298:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         if (idx < 0 || idx >= mNumLeds)
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp:309:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
             if (nextIdx < mNumLeds) {
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp: In member function 'void fl::PerlinParticlePunch::renderMeteor(const fl::PerlinParticlePunch::MeteorParticle&)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp:328:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp:346:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         if (idx >= mNumLeds)
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp: In member function 'void fl::PerlinParticlePunch::renderDebris(const fl::PerlinParticlePunch::DebrisParticle&)':
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp:367:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     if (idx >= 0 && idx < mNumLeds) {
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/fl/fx/1d/perlin_particle_punch.cpp.hpp:373:33: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     if (nextIdx >= 0 && nextIdx < mNumLeds && frac > 0.01f) {
In file included from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/parlio/parlio_engine.h:79:0,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/parlio/channel_driver_parlio.h:194,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/parlio/channel_driver_parlio.cpp.hpp:20,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/parlio/_build.cpp.hpp:16,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/_build.cpp.hpp:37,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/_build.cpp.hpp:23,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/_build.cpp.hpp:7,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/_build.cpp.hpp:24,
                 from c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\platforms+.cpp:10:
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/parlio/parlio_buffer_calc.h:33:63: warning: large integer implicitly truncated to unsigned type [-Woverflow]
     #define FASTLED_PARLIO_MAX_RING_BUFFER_TOTAL_BYTES (256UL * 1024UL)
c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src/platforms/esp/32/drivers/parlio/parlio_buffer_calc.h:210:63: note: in expansion of macro 'FASTLED_PARLIO_MAX_RING_BUFFER_TOTAL_BYTES'
                                        size_t totalCapBytes = FASTLED_PARLIO_MAX_RING_BUFFER_TOTAL_BYTES) const FL_NO_EXCEPT {
Compiling core...
Using precompiled core: C:\Users\bugge\AppData\Local\arduino\cores\arduino_avr_nano_cpu_atmega328_784ccd771d8a49968e68b822ada55589\core.a
Linking everything together...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/sketch_oct12a.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\sketch\\sketch_oct12a.ino.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\extras+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.asset+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.audio+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.channels+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.chipsets+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.codec+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.control+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fled+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.font+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fs+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fs.embedded+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fs.sd+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.fx+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.gfx+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.log+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.math+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.net+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.remote+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.sensors+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.stl+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.system+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.task+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.test+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.ui+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.video+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\fl.wdt+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\platforms+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\src.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\fl\\build\\third_party+.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0\\libraries\\FastLED\\platforms\\esp\\32\\drivers\\gpio_isr_rx\\fast_isr.S.o" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/..\\..\\cores\\arduino_avr_nano_cpu_atmega328_784ccd771d8a49968e68b822ada55589\\core.a" "-LC:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0" -lm
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/sketch_oct12a.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/sketch_oct12a.ino.eep"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/sketch_oct12a.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/sketch_oct12a.ino.hex"
Using library FastLED at version 3.10.6 in folder: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\bugge\\AppData\\Local\\arduino\\sketches\\23A6BDED9CBD569927AE102AA6C326F0/sketch_oct12a.ino.elf"
Sketch uses 1920 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 222 bytes (10%) of dynamic memory, leaving 1826 bytes for local variables. Maximum is 2048 bytes.
Verify again
FQBN: arduino:avr:nano
Using board 'nano' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8
Using core 'arduino' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.8
Detecting libraries used...
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.merged
Alternatives for FastLED.h: [FastLED@3.10.6]
ResolveLibrary(FastLED.h)
  -> candidates: [FastLED@3.10.6]
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\extras+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.asset+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.audio+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.channels+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.chipsets+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.codec+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.control+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fled+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.font+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fs+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fs.embedded+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fs.sd+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.fx+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.gfx+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.log+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.math+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.net+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.remote+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.sensors+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.stl+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.system+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.task+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.test+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.ui+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.video+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\fl.wdt+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\platforms+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\src.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\fl\build\third_party+.cpp
Using cached library dependencies for file: c:\Users\bugge\OneDrive\Documents\Arduino\libraries\FastLED\src\platforms\esp\32\drivers\gpio_isr_rx\fast_isr.S
Using cached sketch with function prototypes.
Compiling sketch...
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\sketch\sketch_oct12a.ino.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\extras+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.asset+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.font+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fs+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fs.embedded+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fled+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fs.sd+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.codec+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.chipsets+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.log+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.remote+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.channels+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.gfx+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.sensors+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.test+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.math+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.control+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.audio+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.net+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\platforms\esp\32\drivers\gpio_isr_rx\fast_isr.S.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.ui+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.fx+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.wdt+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.task+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.stl+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.video+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\third_party+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\fl.system+.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\src.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\arduino\sketches\23A6BDED9CBD569927AE102AA6C326F0\libraries\FastLED\fl\build\platforms+.cpp.o
Compiling core...
And after clearing the cache the message shows again
This message comes from the Arduino CLI helper tool. Arduino CLI is bundled with the Arduino IDE installation. Updates of Arduino CLI only occur through updating the installed Arduino IDE version.
The last update of Arduino IDE was four months ago. So the appearance of this message is not caused by an update to a different version of Arduino CLI that has different behavior.
The message is expected to appear when the list of library dependencies of your sketch has changed. That may occur through a change to the sketch (e.g., adding a new #include directive). It may also occur through a similar change to the code of one of the library dependencies.
This message would also occur if the path of one of the library dependencies changed. That could occur if the library was moved, or if a new library with a header file of the same name is now present, which is selected by the library discovery system instead of the previous library.
I note you say you moved everything off OneDrive. This would change the paths of the library dependencies, and thus result in the appearance of the message on the next compilation of each sketch.
Likewise, updates to libraries, or installation of new libraries, could cause the appearance of this message in certain cases. Updating the boards platform could also cause its appearance, since platforms contain bundled libraries, and the platform code code could even reference libraries.
However, in any of these cases, the change should only cause the appearance of the message for the first compilation of a given sketch after the time of the change. The message should not recur on subsequent compilations.
As @sterretje mentioned, the message also occurs in the case where there isn't already a library dependency cache for the sketch. So it is normal and expected to see it on the first compilation of a sketch, and after clearing the cache. Clearing the cache could occur through performing a "clean compile" by holding the Shift key before triggering a compilation. Arduino CLI also periodically clears unused caches.
This is expected.
This is expected.
I regularly look at the verify output; I also regularly clear the cache. It's just strange that I've never noticed that message before.
I'm aware of that :slight_smile:
The message was added in Arduino CLI 1.3.0:
https://github.com/arduino/arduino-cli/releases/tag/v1.3.0
cba02e8 Improved compile speed by running multi-threaded library discovery. (#2625)
It was first introduced to Arduino IDE in version 2.3.7:
(the Arduino CLI dependency was bumped from 1.2.0 to 1.3.1 in this IDE release)
Sorry. I should have added, "off OneDrive months ago" so I would not confuse the situation.
@xfpd please try the experiment @kenb4 proposed:
I think that I did that experiment. Unless I missed something.
Yes, you did:
We are interested to see if @xfpd receives this expected result from the experiment, or the unexpected result that the message appears even on the subsequent compilation.
I recall this (above) being very near (topic title), but do not remember "before" or "after"... and I just did a couple compiles without getting (topic title).
Is my task to compile builder.go or just see the three conditions that cause (topic title)?
[edit] I did empty my "recycle bin"... so maybe that had something to do with not seeing the error.
[edit update] I compiled one sketch (no error) then with a second IDE open, compiled another, different, sketch and got the error... Direct copy/paste here...
This was the last line before (topic title)
C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2601/bin/riscv32-esp-elf-g++ -c @C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esp32c6-libs\3.3.12/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_ARDUINO_NESSO_N1 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ARDUINO_NESSO_N1" -DARDUINO_VARIANT="arduino_nesso_n1" -DARDUINO_PARTITION_app3M_fat9M_16MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:arduino_nesso_n1:UploadSpeed=921600,CDCOnBoot=default,CPUFreq=160,FlashMode=qio,PartitionScheme=app3M_fat9M_16MB,DebugLevel=none,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 @C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esp32c6-libs\3.3.12/flags/defines -IC:\Users\user\Documents\Arduino\sketchbook\NessoN1\LED_BUILTIN\heartbeat -iprefix C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esp32c6-libs\3.3.12/include/ @C:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esp32c6-libs\3.3.12/flags/includes -IC:\Users\user\AppData\Local\Arduino15\packages\esp32\tools\esp32c6-libs\3.3.12/qio_qspi/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.12\cores\esp32 -IC:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.12\variants\arduino_nesso_n1 -Ic:\Users\user\Documents\Arduino\sketchbook\libraries\Arduino_Nesso_N1\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.12\libraries\Wire\src -Ic:\Users\user\Documents\Arduino\sketchbook\libraries\M5GFX\src -Ic:\Users\user\Documents\Arduino\sketchbook\libraries\Arduino_BMI270_BMM150\src @C:\Users\user\AppData\Local\arduino\sketches\07D74D7A7A650B3DD4CAE35B62A2337B/build_opt.h @C:\Users\user\AppData\Local\arduino\sketches\07D74D7A7A650B3DD4CAE35B62A2337B/file_opts c:\Users\user\Documents\Arduino\sketchbook\libraries\Arduino_BMI270_BMM150\src\utilities\BMI270-Sensor-API\bmi2_ois.c -o nul -MMD -MF C:\Users\user\AppData\Local\arduino\sketches\07D74D7A7A650B3DD4CAE35B62A2337B\libraries\Arduino_BMI270_BMM150\utilities\BMI270-Sensor-API\bmi2_ois.c.libsdetect.d
... and immediately, (topic title)
The list of included libraries has been changed... rebuilding all libraries.
Generating function prototypes...
Compiled again... no (topic title), cleared cache (CTRL-SHFT-r) received (topic title), just like @sterretje
