So I was trying to unify my code im using a Lilygo TSIM 7000G, so i tried the codes alone and now Im adding them in one code, so the problems becomes with the PMS sensor and I dont really now what to do or fix, because it reads when Im trying the code but when It is in the new code just doesnt print any info.
I think it could be the requesting, i read with the same error like use pointers to doesnt load the esp32, but what i have to do.
2
error opening test.txt
======== start print ========
temperature (unit Celsius): 0.00
pressure (unit pa): 0
altitude (unit meter): 44330.00
humidity (unit percent): 0.00
======== end print ========
Sensor operating status : 0
Air quality index : 0
Concentration of total volatile organic compounds : 0 ppb
Carbon dioxide equivalent concentration : 0 ppm
CO = 1000.00
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x40102f14 PS : 0x00060530 A0 : 0x800d5b96 A1 : 0x3ffb21f0
A2 : 0x3ffc1938 A3 : 0x000000e2 A4 : 0x00000000 A5 : 0x3ffc198e
A6 : 0x00000042 A7 : 0x3ffc1989 A8 : 0x00000000 A9 : 0x3ffb21d0
A10 : 0x00000000 A11 : 0x00000042 A12 : 0x00000a1d A13 : 0x00000004
A14 : 0x3ffc2800 A15 : 0x3ffc2804 SAR : 0x00000014 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x400872a5 LEND : 0x400872b5 LCOUNT : 0xffffffff
Backtrace: 0x40102f11:0x3ffb21f0 0x400d5b93:0x3ffb2210 0x400d1ee8:0x3ffb2230 0x400da184:0x3ffb2270 0x4008a7fa:0x3ffb2290
ELF file SHA256: 7e1943899
Rebooting...
This is the code it isnt like very reduce because Im trying to get to work first and after that do the upgrading.
#include <SPI.h>
#include <SD.h>
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
//Variables de O2
#include "DFRobot_OzoneSensor.h"
#define COLLECT_NUMBER 20
#define Ozone_IICAddress 0x73
DFRobot_OzoneSensor Ozone;
#define SD_CS 13
#define SPI_MOSI 15
#define SPI_MISO 2
#define SPI_SCK 14
#define i2c_Address 0x3C
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
File carpeta;
//CO2
#include <DFRobot_ENS160.h>
#include "DFRobot_BME280.h"
#define SEA_LEVEL_PRESSURE 1015.0f
#define ADDRESS_1 0x53
#define ENS160_ADDRESS ADDRESS_1
#define ADDRESS_2 0x76
#define BME_ADDRESS ADDRESS_2
DFRobot_ENS160_I2C ENS160(&Wire, /*i2cAddr*/ ENS160_ADDRESS);
typedef DFRobot_BME280_IIC BME; // ******** use abbreviations instead of full names ********
BME bme(&Wire, BME_ADDRESS); // select TwoWire peripheral and set sensor address
// show last sensor operate status
void printLastOperateStatus(BME::eStatus_t eStatus)
switch(eStatus) {
case BME::eStatusOK: Serial.println("everything ok"); break;
case BME::eStatusErr: Serial.println("unknow error"); break;
case BME::eStatusErrDeviceNotDetected: Serial.println("device not detected"); break;
case BME::eStatusErrParameter: Serial.println("parameter error"); break;
default: Serial.println("unknow status"); break;
//GASES
#include "DFRobot_MICS.h"
float COO=2;
#define Mics_I2C_ADDRESS 0x75
DFRobot_MICS_I2C mics(&Wire, Mics_I2C_ADDRESS);
#define ADC_PIN A0
#define POWER_PIN 10
//PMS
#include "BLINKER_PMSX003ST.h"
#define RX2 14 // To sensor TXD
#define TX2 15 // To sensor RXD
HardwareSerial pmsSerial(2);// UART1/Serial1 pins 16,17
BLINKER_PMSX003ST pms;
void setup(){
SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI, SD_CS);
Serial.println("starting");
if(!SD.begin(SD_CS, SPI))
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if(cardType == CARD_NONE)
Serial.println("No SD card attached");
return;
//card details
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("SD Card Size: %lluMB\n", cardSize);
Serial.println("-----");
delay(250); // wait for the OLED to power up
carpeta = SD.open("/test.txt", FILE_WRITE);
if (carpeta)
carpeta.println("Hello worl4!");
carpeta.flush();
carpeta.close();
Serial.println("error opening test.txt");
if (carpeta)
carpeta.print("Hello wor!");
carpeta.print("Hello wr!");
carpeta.flush();
carpeta.close();
display.begin(i2c_Address, true); // Address 0x3C default
//display.setContrast (0); // dim display
display.display();
delay(2000);
// Clear the buffer.
display.clearDisplay();
// text display tests
display.setTextSize(1);
display.setTextColor(SH110X_WHITE);
display.setCursor(0, 0);
display.println("Failure is NOT option");
display.setTextColor(SH110X_BLACK, SH110X_WHITE); // 'inverted' text
display.println(3.141592);
display.setTextSize(2);
display.print("0x"); display.println(0xDEADBEEF, HEX);
display.display();
delay(2000);
while(!Ozone.begin(Ozone_IICAddress)){
Serial.println("I2c device number error !");
Serial.println("I2c connect success !");
* set measuer mode
* MEASURE_MODE_AUTOMATIC active mode
* MEASURE_MODE_PASSIVE passive mode
Ozone.setModes(MEASURE_MODE_PASSIVE);
delay(5000);
//CO2
bme.reset();
Serial.println("bme read data test");
while(bme.begin() != BME::eStatusOK) {
Serial.println("bme begin faild");
printLastOperateStatus(bme.lastOperateStatus);
delay(2000);
Serial.println("bme begin success");
delay(100);
// Init the sensor
while( NO_ERR != ENS160.begin() ){
Serial.println("Communication with device failed, please check connection");
delay(3000);
* Set power mode
* mode Configurable power mode:
* ENS160_SLEEP_MODE: DEEP SLEEP mode (low power standby)
* ENS160_IDLE_MODE: IDLE mode (low-power)
* ENS160_STANDARD_MODE: STANDARD Gas Sensing Modes
ENS160.setPWRMode(ENS160_STANDARD_MODE);
* Users write ambient temperature and relative humidity into ENS160 for calibration and compensation of the measured gas data.
* ambientTemp Compensate the current ambient temperature, float type, unit: C
* relativeHumidity Compensate the current ambient temperature, float type, unit: %rH
ENS160.setTempAndHum(/*temperature=*/bme.getTemperature(), /*humidity=*/bme.getHumidity());
delay(5000);
//GASES
while(!Serial);
while(!mics.begin()){
Serial.println("NO Deivces !");
} Serial.println("Device connected successfully !");
uint8_t mode = mics.getPowerState();
if(mode == SLEEP_MODE){
mics.wakeUpMode();
Serial.println("wake up sensor success!");
}else{
Serial.println("The sensor is wake up mode");
delay(5000);
//PMS
Serial.println("\nStart");
pmsSerial.begin(9600,SERIAL_8N1, RX2, TX2);
pms.begin(pmsSerial);
//pms.wakeUp();
pms.setMode(ACTIVE);
void loop(){
uint16_t ozoneConcentration = Ozone.readOzoneData(COLLECT_NUMBER);
Serial.print("Ozone concentration is ");
Serial.print(ozoneConcentration);
Serial.println(" PPB.");
Serial.println(" 2");
carpeta = SD.open("/test.txt", FILE_APPEND);
if (carpeta)
carpeta.print(ozoneConcentration);
carpeta.print(",");
carpeta.print(",");
carpeta.println(" ");
carpeta.flush();
carpeta.close();
//CO2
float temp = bme.getTemperature();
uint32_t press = bme.getPressure();
float alti = bme.calAltitude(SEA_LEVEL_PRESSURE, press);
float humi = bme.getHumidity();
Serial.println("======== start print ========");
Serial.print("temperature (unit Celsius): "); Serial.println(temp);
Serial.print("pressure (unit pa): "); Serial.println(press);
Serial.print("altitude (unit meter): "); Serial.println(alti);
Serial.print("humidity (unit percent): "); Serial.println(humi);
Serial.println("======== end print ========");
uint8_t Status = ENS160.getENS160Status();
Serial.print("Sensor operating status : ");
Serial.println(Status);
uint8_t AQI = ENS160.getAQI();
Serial.print("Air quality index : ");
Serial.println(AQI);
uint16_t TVOC = ENS160.getTVOC();
Serial.print("Concentration of total volatile organic compounds : ");
Serial.print(TVOC);
Serial.println(" ppb");
uint16_t ECO2 = ENS160.getECO2();
Serial.print("Carbon dioxide equivalent concentration : ");
Serial.print(ECO2);
Serial.println(" ppm");
//GASES
int16_t red_data = 0;
red_data = mics.getADCData(RED_MODE);
if (red_data > 3.4f) {
COO = 0.0;
else if (red_data < 0.01) {
COO = 1000.0;
else {
COO = 4.2/ pow(red_data,1.2);
Serial.print("CO = ");
Serial.println(COO);
//PMS
pms.request();
if(!pms.read()){
return;
Serial.print("PM1.0(CF1)\t");
Serial.print(pms.getPmCf1(1.0));
Serial.println("ug/m3");
Serial.print("PM2.5(CF1)\t");
Serial.print(pms.getPmCf1(2.5));
Serial.print("PM10(CF1)\t");
Serial.print(pms.getPmCf1(10));
Serial.print("Formalde\t");
Serial.print(pms.getForm());
Serial.print("Temperat\t");
Serial.print(pms.getTemp());
Serial.println("'C");
Serial.print("Humidity\t");
Serial.print(pms.getHumi());
Serial.println("%");
And this is the code of the PMS alone that works.
//pms.wakeUp();
pms.request();
if(!pms.read()){
return;
