Hi everyone, I'm very new to arduino and have had some trouble saving acceleration data to a text file on my desktop.
Firstly, I'm using an Arduino Uno and an AM3X accelerometer.
I have been attempting to use Gobetwino in order to log data automatically onto a text file. I have read through the Gobetwino instructions but as I'm new to Arduino coding, I'm having a lot of trouble putting the code together correctly.
My code is as follows:
#include <AcceleroMMA7361.h>
AcceleroMMA7361 accelero;
int x;
int y;
int z;
int serInLen = 25;
char serInString[25];
int logx = 0;
int logy = 0;
int logz = 0;
accelero.begin(13, 12, 11, 10, A0, A1, A2);
accelero.setARefVoltage(3.3); //sets the AREF voltage to 3.3V
//accelero.setSensitivity(LOW); //sets the sensitivity to +/-6G
accelero.calibrate();
x = accelero.getXRaw();
y = accelero.getYRaw();
z = accelero.getZRaw();
Serial.print("\nX: ");
Serial.print(x);
Serial.print("\tY: ");
Serial.print(y);
Serial.print("\tZ: ");
Serial.print(z);
logx= x;
logy= y;
logz= z;
logData(logx,logy,logz);
delay(500); //(make it readable)
void logData( int x, int y, int z)
char buffer[5];
Serial.print("#S|LOGDATA|[");
Serial.print(itoa((x), buffer, 10));
Serial.print(";");
Serial.print(itoa((y), buffer, 10));
Serial.print(";");
Serial.print(itoa((z), buffer, 10));
Serial.println("]#");
readSerialString(serInString,1000);
// There ought to be a check here for a non 0 return value indicating an error and some error handeling
//read a string from the serial and store it in an array
//you must supply the array variable - return if timeOut ms passes before the sting is read
void readSerialString (char *strArray,long timeOut)
long startTime=millis();
int i;
while (!Serial.available()) {
if (millis()-startTime >= timeOut) {
return;
while (Serial.available() && i < serInLen) {
strArray[i] = Serial.read();
i++;
I'm trying to save the acceleration data in all 3 axis, and my code is compiling, but nothing is saving to the text file. An issue with Gobetwino I am having is that I get this error on the Gobetwino screen.
2/12/2015 5:54:05 PM Serial port : COM4 opened at 9600 baud
2/12/2015 5:54:07 PM Commandstring recieved : 3
2/12/2015 5:54:07 PM The string recieved : 3 is not a well formed command string
2/12/2015 5:54:10 PM Commandstring recieved :
Calibrating MMA7361011..................................................
DONE
X: 510 Y: 511 Z: 759#S|LOGDATA|[510;511;759]#
2/12/2015 5:54:10 PM The string recieved :
DONE
X: 510 Y: 511 Z: 759#S|LOGDATA|[510;511;759]# is not a well formed command string
2/12/2015 5:54:12 PM Commandstring recieved :
X: 510 Y: 511 Z: 761#S|LOGDATA|[510;511;761]#
2/12/2015 5:54:12 PM The string recieved :
X: 510 Y: 511 Z: 761#S|LOGDATA|[510;511;761]# is not a well formed command string
If anyone has any suggestions it would be greatly appreciated!
Thanks and kind regards,
Jackson Booth
