I am trying to log temperature to an SD2/2GB SanDisk card. I am using the DS1307 to time stamp the data and this breakout board from Sparkfun to hold the SD card http://www.sparkfun.com/products/204 and DS18B20 temperature sensors to take temperature readings. Whenever the DS18B20s read in -192 degrees F the SD card file reads
2010/10/3 14:15:35
Internal Sensor: 4294967169 C 4294967100 F
External Sensor: 4294967169 C 4294967100 F
which is perfectly how I want it to be formatted except the temperature is completely wrong. If I get the DS18B20 to read in the correct temperature the SD card file reads
2011102214150
IInIntInteInterInternInternaInternalInternal Internal SInternal SeInternal SenInternal SensInternal SensoInternal SensorInternal Sensor:29 C C 84
EExExtExteExterExternExternaExternalExternal External SExternal SeExternal SenExternal SensExternal SensoExternal SensorExternal Sensor:29 C C 84
Any ideas? I don't know why sometimes I read in the temperature and it reads -192 degrees F and when I read upload the sketch it reads in 84 degrees Celsius or why the temperature change causes the SD file to screw up.
Code:
#include <SdFat.h>
#include <SdFatUtil.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h>#define error(s) error_P(PSTR(s))
#define ONE_WIRE_BUS 3
#define TEMPERATURE_PRECISION 12Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);DeviceAddress insideThermometer = { 0x28, 0xA3, 0xDB, 0xFF, 0x02, 0x00, 0x00, 0x91 };
DeviceAddress outsideThermometer = { 0x28, 0x86, 0xCA, 0xFF, 0x02, 0x00, 0x00, 0x7D };float tempC,tempF;
int hour, minute, seconds, day, month, year;char name[] = "TEMPLOG.TXT";
void error_P(const char* str)
PgmPrint("Error: ");
SerialPrintln_P(str);
if(card.errorCode())
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(),HEX);
while(1);
}void writeCRLF(SdFile& f)
f.write((uint8_t*) "\r\n",2);
}void writeNumber(SdFile& f, uint32_t n)
uint8_t buf[10];
uint8_t i = 0;
do{
i++;
buf[sizeof(buf) - i] = n%10 + '0';
n /= 10;
}while(n);
f.write(&buf[sizeof(buf) - i],i);
}void writeString(SdFile& f, char *str)
uint8_t n;
for(n = 0; str[n]; n++)
f.write((uint8_t *)str,n);
}void getTemperature(DeviceAddress deviceAddress)
sensors.requestTemperatures();
tempC = sensors.getTempC(deviceAddress);
tempF = DallasTemperature::toFahrenheit(tempC);
}void getTimeDate()
hour = RTC.get(DS1307_HR,TRUE);
minute = RTC.get(DS1307_MIN, false);
seconds = RTC.get(DS1307_SEC, false);
day = RTC.get(DS1307_DATE,false);
month = RTC.get(DS1307_MTH,false);
year = RTC.get(DS1307_YR,false);
}void setup()
Serial.println("Type any character to start");
while(!Serial.available());
Serial.println();sensors.begin();
Serial.println("Initialising Sensors.");sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
delay(100);RTC.stop();
RTC.set(DS1307_SEC,0);
RTC.set(DS1307_MIN,15);
RTC.set(DS1307_HR,14);
RTC.set(DS1307_DOW,6);
RTC.set(DS1307_DATE,22);
RTC.set(DS1307_MTH,10);
RTC.set(DS1307_YR,11);
RTC.start();Serial.println("Initialising SD Card...");
if(!card.init(SPI_HALF_SPEED))
error("card.init failed");
}if(!volume.init(&card))
error("volume.init failed");
}if(!root.openRoot(&volume))
error("openRoot failed");
Serial.println("SD Card initialised successfully");
}void loop()
Serial.println("File Opened.");
file.open(&root, name, O_CREAT | O_APPEND | O_WRITE);
getTimeDate();
file.timestamp(7,year,month,day,hour,minute,seconds);getTemperature(insideThermometer);
Serial.print("Inside: ");
Serial.print(tempC);
Serial.print(" C ");
Serial.print(tempF);
Serial.println(" F");
writeNumber(file,year);
writeString(file,"/");
writeNumber(file,month);
writeNumber(file,day);
writeNumber(file,hour);
writeNumber(file,minute);
writeNumber(file,seconds);
writeCRLF(file);
writeString(file, "Internal Sensor: ");
writeNumber(file, tempC);
writeString(file, " C ");
writeNumber(file,tempF);
writeString(file, " F");
writeCRLF(file);getTemperature(outsideThermometer);
Serial.print("Outside: ");
Serial.print( " C ");
writeString(file, "External Sensor: ");
writeNumber(file,tempC);
writeCRLF(file);
writeCRLF(file);Serial.println("Data Written");
file.close();
Serial.println("File Closed.");
delay(10000);
