Long distance multiple sensors and no wifi
Hi im new to arduino and just need any advice i can get!
Im a student working on a group project and have been tasked with getting an ultrasonic sensor to send data to a media server (isadora) so that the contents brightness can be affected with the closer people get to the installation.
My problem lies with the fact that from arduino to the media server will be a distance of around 15 to 20ft and we will not have access to wifi at the location. The arduino itself will be under stage decking as the event is outside and the sensor will have a shelter built for it under the stage but still accessible for when the audience walks closer.
TLDR
how would i get a non wifi arduino to reach and connect to a media server 15 to 20ft away whilst protecting cables from rain as the server is in a shed off to the side of the stage where the arduino will be under?
No WiFi doesn't mean you can't use radio. Use a second Arduino at the media server to receive the remote signal from the transmitter and have it send the info to the media server in whatever way it can receive it: USB, UART, I2C, whatever.
First, an ultrasonic sensor does not send data because it does not have any data. Only the Arduino it is connected to may create data from the timing of a possible echo from that sensor.
So, what is your data, how many bytes per message and how often will it be sent? Do you need any acknowledgement returned to the sensor/Ardiuno to prove the message was received?
From that information, you can put parameters to the communications you will need.
First, I don't see anything in your description that requires it to be wireless, simplest thing would be to run a wire to the sensor. How is the sensor getting power?
At that range Bluetooth would work.
