Hello,
I'm spending quiet a while on this Problem, and just can't find the fault.
I use 4 Buttons, which are connected to 4 digital inputs, and additional to one interrupt input (via a diode).
The schematic is attached. When the Buttons close they are connected to +5V.
the problem is that it doesn't work properly, especially the long press mode. The buttons are really high quality, so i didn't use debouncing here (for the short press mode).
I guess the fault should be in the interrupt function, but I just can't find it.
Maybe one of you will find it very quick. (To miss the forest for the trees could be my problem ...)
Thank you!
const int button[] = {
10,9,8,7};
//storing the button state for short press mode
volatile int state[] = {
LOW, LOW, LOW, LOW};
//storing the button state for long press mode
volatile int state_long[] = {
//stores the time each button went high or low
volatile unsigned long current_high[4];
volatile unsigned long current_low[4];
for(int i=0; i<4; i++)
pinMode(button[i], INPUT);
attachInterrupt(0, read_button, CHANGE);
if(state[0] == HIGH)
//do something when button 0 was pressed short ...
state[0] = LOW;
if(state_long[3] == HIGH)
//do something when button 3 was pressed long ...
state[0] = LOW;
//is called when the Interrupt Pin is pressed or released (CHANGE Mode)
void read_button()
//cycles through the buttons to find out which one was pressed or released
//if this is true the button was just pressed down
if(digitalRead(button[i]) == HIGH)
//note the time the button was pressed
current_high[i] = millis();
//if no button is high one had to be released. The millis function will increase while a button is hold down the loop function will be cycled (no change, so no interrupt is active)
current_low[i] = millis();
//determines the time passed since the button pressed down
if((current_low[i] - current_high[i]) < 500)
state[i] = !state[i];
//if the time between press and release is higher than 500 and lower than 1000 ms it is a long press
else if((current_low[i] - current_high[i]) >= 500 && (current_low[i] - current_high[i]) < 1000)
state_long[i] = !state_long[i];
