Long wires with sensors and arduino
my requirement is interfacing the sensor such as wcs1700(current sensor) with arduino here the distance is 10mtrs long so which kind of wire is suitable to avoid noise ,and voltage drop
Do you also need to supply power over this cable?
Are you using just the sensor or some module with an amplifier?
I don't think that there will be a noticeable voltage drop as long as you use decent wires, the noise could be a problem though. I have done a tiny search on Google, but can't find the used protocol for the output. Is it just analog, or is it some kind of one wire I²C or something? Some other questions:
  • What do you want to make?
  • what is the required resolution?
  • What's the operating voltage (probably +3.3V or +5V, but you never know)
  • What is the power supply?
  • Does the power need to run through the same cables?
  • Do you have any datasheets of the sensor?
  • (you will probably have thought about this one, but) does it really need to be 10m?
If the output is analog, and you need to have a high resolution, is an ADC and shift register a solution? If an ADC and shift register aren't a solution, you'll need to build an array of different capacitors, coils and resistors. Chose the values based on the required voltage (I assume that you're working with +3.3V or +5V?), but if you have a scope to use, measure the noise on the cables to make it more precise. Either way, I would use something pair twisted, the twists eliminate the capacitive effect of the wires.
yes sir through this cable power will be carried . i am just using the sensor only
Only if current runs through them does the magnetic effect of the twists counteract the capacitance, and only properly if a couple of MAX485 transceivers (or similar) are used.
I recommend this
That looks like pretty good stuff for the job. btw do you know of any cable with 2 thick power leads and a much thinner 9single or double) data lead ?
Close, there will be no voltage drop, because the Arduino pin draws no current from the sensor. No current == no drop.
Must be VCC of the processor used, to preserve ratiometric behaviour of the sensor.
Use twisted or shielded wire for long cable runs.
A 10-100n cap from analogue input to ground, close to the Arduino, could kill any noise.
See page 4 of the datasheet.
The sensor seems almost the same as an ACS712...
Leo..
