Hi there. I've just started working with an Arduino Lilypad and have done a few simple tutorials.
I'm now trying to connect a BlueSMirf Gold shield to the Lilypad. However, various instructions I've found are lacking details.
For example, this one, by Leah Buechley, is most often referenced, but shows an older version of the Lilypad.
thehighlowtech.com/LilyPad/extend.html
It says nothing about how to power the set up, and (most significant for me) does not say how the pins described map to the hardware.
Theres just a picture of an older board (the current Lilypad, and the BlueSmirf, have six header pins, not four), and this description:
"Attach 5v to PWR, - to GND, tx to RX - I, and rx to TX - O. "
I've found other Web pages describing how to connect things to the Lilypad and they all seem a to assume the reader knows exactly where to find 5v or 3.3v or TX or whatever.
There's nothing on the Lilypad though that indicates what any of the header pins are. So I have no idea what pin is 5v, or tx, etc.
I searched around for this info and have found assorted documents and schematics that may have the info I'm looking for, but it's not in a format I can understand.
The closest thing I found was a Lilypad diagram here:
It's an excerpt from the book Programming Interactivity.
The specific image is
It's almost perfect, but it does not say what the header pins are for (the pins where you would attach a USB link cable).
Does anyone know of such a diagram, something that clearly explains what each and every pin or connector on the Lilypad is for, using a picture or simple drawing of the board itself?
Thanks very much.
