Looking for a small prximity/inductive sensor for a rotary encoder.
Hi Forum
Im going to make a rotary encoder for a project. I need roughly 1° resolution. Im going to lasercut a plate, and need some small sensors to read the holes in the plate. To avoyd a large diameter I need a sensor with a narrow "Beam" of detection. I can have a distance around 1 mm, from sensor to plate.
So I need a really narroww detection field.
Does anyone know of a sensor that fullfills this? I need a handfull, so price is also an issue.
Due to oil, dirt near the sensor i cannot use an infrared sensor. A hall sensor is not a good option either since i cannot have magnetic parts around the sensor. So im cutting the sensordisk in AISI 316 stainless.
Peter
To achieve a 1° resolution, you will need to place this sensor (2mm x 2mm) about 5 inches from the axis.
Here's a thought...
Take a look at an air-variable capacitor. Turning the shaft on the capacitor changes the amount of penetration of the movable plate(s) into the stationary plate(s) -- and that in turn changes the effective capacitance.
That change in capacitance can be used to tune a high-frequency oscillator, and you can determine the relative location of the movable plates by measuring the oscillator frequency.
A round metal disk with a shaft positioned off-center, will generate a small, but measurable and continuous, variation in capacitance as the shaft rotates the disk near a stationary plate.
Something like that might work for you. And it's not hard to measure even very small changes in frequency given today's high speed digital electronics.
What about an angular position sensor?
