I am looking for the LANC power OFF and power ON commands.
I have:
00111010 Power on
01111010 Power off
but they don't seem to be working. I am using this code to start/stop recording and it is working great. But when I tried to modify it to power off the camera, it is not working. :~
Send a Start/Sop Recording command to the LANC port of a video camera.
Tested with a Canon XF300 camcorder
This code requires a simple interface see http://micro.arocholl.com
Feel free to use this code in any way you want.
Comprehensive LANC info: www.boehmel.de/lanc.htm
"LANC" is a registered trademark of SONY.
CANON calls their LANC compatible port "REMOTE".
2011, Martin Koch
http://controlyourcamera.blogspot.com/2011/02/arduino-controlled-video-recording-over.html
#define cmdPin 7
#define lancPin 11
#define recButton 2
int cmdRepeatCount;
int bitDuration = 104; //Duration of one LANC bit in microseconds.
pinMode(lancPin, INPUT); //listens to the LANC line
pinMode(cmdPin, OUTPUT); //writes to the LANC line
pinMode(recButton, INPUT); //start-stop recording button
digitalWrite(recButton, HIGH); //turn on an internal pull up resistor
digitalWrite(cmdPin, LOW); //set LANC line to +5V
delay(5000); //Wait for camera to power up completly
bitDuration = bitDuration - 8; //Writing to the digital port takes about 8 microseconds so only 96 microseconds are left till the end of each bit
if (!digitalRead(recButton)) {
REC(); //send REC command to camera
delay(1000); //debounce button
void REC() {
cmdRepeatCount = 0;
while (cmdRepeatCount < 5) { //repeat 5 times to make sure the camera accepts the command
while (pulseIn(lancPin, HIGH) < 5000) {
//"pulseIn, HIGH" catches any 0V TO +5V TRANSITION and waits until the LANC line goes back to 0V
//"pulseIn" also returns the pulse duration so we can check if the previous +5V duration was long enough (>5ms) to be the pause before a new 8 byte data packet
//Loop till pulse duration is >5ms
//LOW after long pause means the START bit of Byte 0 is here
delayMicroseconds(bitDuration); //wait START bit duration
//Write the 8 bits of byte 0
//"18hex" or “00011000” tells the camera that there will be a normal command to camera in the next byte
//Note that the command bits have to be put out in reverse order with the least significant, right-most bit (bit 0) first
digitalWrite(cmdPin, LOW); //Write bit 0.
digitalWrite(cmdPin, LOW); //Write bit 1
digitalWrite(cmdPin, LOW); //Write bit 2
digitalWrite(cmdPin, HIGH); //Write bit 3
digitalWrite(cmdPin, HIGH); //Write bit 4
digitalWrite(cmdPin, LOW); //Write bit 5
digitalWrite(cmdPin, LOW); //Write bit 6
digitalWrite(cmdPin, LOW); //Write bit 7
//Byte 0 is written now put LANC line back to +5V
delayMicroseconds(10); //make sure to be in the stop bit before byte 1
while (digitalRead(lancPin)) {
//Loop as long as the LANC line is +5V during the stop bit
//0V after the previous stop bit means the START bit of Byte 1 is here
//Write the 8 bits of Byte 1
//"33hex" or “00110011” sends the Record Start/Stop command
digitalWrite(cmdPin, HIGH); //Write bit 0
digitalWrite(cmdPin, HIGH); //Write bit 1
digitalWrite(cmdPin, LOW); //Write bit 3
digitalWrite(cmdPin, HIGH); //Write bit 5
//Byte 1 is written now put LANC line back to +5V
cmdRepeatCount++; //increase repeat count by 1
/*Control bytes 0 and 1 are written, now don’t care what happens in Bytes 2 to 7
and just wait for the next start bit after a long pause to send the first two command bytes again.*/
}//While cmdRepeatCount < 5
