Here is my code:
#include <SPI.h>
#include <SD.h>
#include <DS3232RTC.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
File myFile;
#define pinCS 53 // SD-Card CS-pin
#define ONE_WIRE_BUS_PIN 22 //Onewire temperature pin (for all probes)
static char sdString[33]; // make a char array to hold incoming data from the SD card
unsigned long sdCardMillis = -3500UL; // minus sdWriteDelay value for first run, so it won't skip the next round5 time
signed char round5delta[5] = {0, -1, -2, -3, -4}; // difference to the "rounded to nearest 5" value
long round5(long no) {
return no + round5delta[no % 5];
OneWire oneWire(ONE_WIRE_BUS_PIN);
DallasTemperature sensors(&oneWire);
unsigned long readTempsMillis = 0;
int tempReadDelay = 1000; //update temperatures every second
DeviceAddress tempWaterSensor = { 0x28, 0xFF, 0xAD, 0xE8, 0xC1, 0x17, 0x04, 0xD9 };
DeviceAddress tempAirSensor = { 0x28, 0xFF, 0x17, 0xE8, 0xC1, 0x17, 0x04, 0x2B };
DeviceAddress tempCaseSensor = { 0x28, 0x01, 0x20, 0x43, 0x98, 0x25, 0x00, 0x8A };
int tempSensor[3] = {tempWaterSensor, tempAirSensor, tempCaseSensor};
float tempVal[3] = {0, 0, 0}; //tempWaterValue, tempAirValue, tempCaseValue
float maxTempVal[3] = {0, 0, 0}; //maxTempWaterValue, maxTempAirValue, maxTempCaseValue
float minTempVal[3] = {0, 0, 0}; //minTempWaterValue, minTempAirValue, minTempCaseValue
float tempCalVal[3]; //CalibrationTempWaterValue, CalibrationTempAirValue, CalibrationTempCaseValue
Wire.begin();
Serial1.begin(115200);
setSyncProvider(RTC.get); // the function to get the time from the RTC
if (timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
Serial.print("Initializing SD card...");
if (!SD.begin(53)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
sensors.begin(); //temperature sensors;
sensors.setResolution(tempWaterSensor, 10);
sensors.setResolution(tempAirSensor, 10);
sensors.setResolution(tempCaseSensor, 10);
readTemps();
requestTemps();
writeToSDcard();
void writeToSDcard() {
unsigned long sdWriteDelay = 3500UL;
int timeInMin = (hour() * 60) + minute();
char filename[13] = "12345678.TXT";
char tempString[3][6] = {"00.00", "00.00", "00.00"};
if (millis() - sdCardMillis >= sdWriteDelay && timeInMin == round5(timeInMin)) { // record every 5 minutes
sprintf(filename, "%02d%02d-Tmp.txt", year() % 100, month());
Serial.print("Write to SD card: "); Serial.println(filename);
myFile = SD.open(filename, FILE_WRITE);
if (myFile) {
for (byte t = 0; t < sizeof(tempVal) / sizeof(float); t++) {
dtostrf(tempVal[t], 5, 2, tempString[t]);
sprintf(sdString, "%02d-%02d-%02d,%02d:%02d,%s,%s,%s", year() % 100, month(), day(), hour(), minute(), tempString[0], tempString[1], tempString[2]);
myFile.println(sdString);
myFile.close();
else {
Serial.println("error opening txt document"); // if the file didn't open, print an error:
sdCardMillis = millis();
bool cmpCA(char string1[], char string2[], byte sizeofString) {
for (byte i = 0; i < sizeofString; i++) {
if (string1[i] != string2[i] ) {
return false;
return true;
void readSDcard(byte line, byte timeFrame) {
static bool timeFrameSet = false;
static char dateTimeStart[15] = "00-00-00,00:00";
static char dateTimeEnd[15] = "00-00-00,00:00";
static byte multiplier = 6;
if (!timeFrameSet && timeFrame > 0) {
timeFrameSet = true;
if (timeFrame == 168) multiplier = 7;
multiplier = timeFrame / multiplier;
tmElements_t sdElements = {second(), minute(), hour(), weekday(), day(), month(), (year() - 1970) };
time_t sdTime = makeTime(sdElements);
sdTime = sdTime - (timeFrame * 3600UL);
breakTime(sdTime, sdElements);
sprintf(dateTimeStart, "%02d-%02d-%02d,%02d:%02d", (sdElements.Year + 1970) % 100, sdElements.Month, sdElements.Day, sdElements.Hour, round5(sdElements.Minute));
sprintf(dateTimeEnd, "%02d-%02d-%02d,%02d:%02d", year() % 100, month(), day(), hour(), round5(minute()));
static byte charPosS = 0; // to determine the character position within the selected line of the array sdString
static bool firstLineFound = false;
static byte lastLine = 0;
static unsigned long activeLinePos = 0;
myFile = SD.open("testfile.txt");
if (myFile) {
while (myFile.available() && !firstLineFound) {
char recieved = myFile.read(); // read a byte, then
if (recieved == '\n') { // if the byte is a newline character
sdString[charPosS] = '\0'; // null terminate the sdString
charPosS = 0; // set char position of sdString to the beginning
if (cmpCA(sdString, dateTimeStart, sizeof(dateTimeStart) - 1)) { // if beginning of sdString is the same as dateTimeStart
activeLinePos = myFile.position() - (sizeof(sdString) + 1);
firstLineFound = true; // Set the firstLineFound true
else if (recieved != '\r') { // if you got anything else but a carriage return character,
sdString[charPosS] = recieved; // add it to the end the array
charPosS++; // Go to the next char position
if (line == 255) {
lastLine = 0;
multiplier = 6;
Serial1.println("sdData|done|");
else if (line == lastLine && lastLine > 0) {
Serial1.println("sdData|end|");
else {
Serial.print("multiplier = "); Serial.println(multiplier);
myFile.seek(activeLinePos + (line * (sizeof(sdString) + 1) * multiplier));
myFile.read(sdString, sizeof(sdString));
Serial1.print("sdData|"); Serial1.print(line); Serial1.print("|"); Serial1.print(sdString); Serial1.println("|");
if (cmpCA(sdString, dateTimeEnd, sizeof(dateTimeEnd) - 1)) { // check if beginning of sdString is the same as dateTimeEnd
lastLine = line + 1; // Mark this line the lastLine
myFile.close(); // close the file
else {
void readTemps() {
if (readTempsMillis == 0) {
sensors.requestTemperatures();
readTempsMillis = millis();
void requestTemps() {
if (millis() - readTempsMillis > tempReadDelay) {
tempVal[t] = tempCalVal[t] + sensors.getTempC(tempSensor[t]);
if (tempVal[t] > maxTempVal[t]) {
maxTempVal[t] = tempVal[t];
if ((minTempVal[t] == 0) || (minTempVal[t] == -127.00)) {
minTempVal[t] = tempVal[t];
if (tempVal[t] < minTempVal[t]) {
