Looking for variant approach/sketch
I have given below a working sketch to accomplish this task:
Create sketch to count number of presses done on pushbutton1 (Fig-1) within 5-sec and then compute factorial for that count. LED1 will blink to reflect the number of press counts and L will reflect by blinking the factorial value.
Would appreciate to receive all possible better/alternate sketches/hints from the readers. This is to improve mine and my pupils' programming skills.
Figure-1:
Sketch:
#include <Debounce.h>
#define pushbutton1 2
#define LED1 12
#define L LED_BUILTIN
Debounce Button(pushbutton1);
unsigned long prMillis = 0;
byte pressCount = 0;
  pinMode(pushbutton1, INPUT_PULLUP);
  pinMode(L, OUTPUT);
  pinMode(LED1, OUTPUT);
  while (millis() - prMillis < 5000) //5-sec time slot
    digitalWrite(LED1, Button.read()); // Read the button state and write it to the Led.
    pressCount = Button.count(); //times button1 is pressed
  Serial.println("5-sec is over.");
  Serial.println(pressCount);
  int facValue = factorial(pressCount);
  Serial.print("Button Pressed ");
  Serial.print(pressCount); Serial.print(" times: ");
  Serial.print("Factorial: "); Serial.println(facValue);
  blinkL(facValue);
  Button.resetCount();
  pressCount = 0;
  prMillis = millis();
int factorial(byte n)
  if (n == 1)
    return 1;
  return (n * factorial(n - 1));
void blinkL(byte m)
  for(int i = 0; i< m; i++)
    digitalWrite(L, HIGH);
    delay(200);
    digitalWrite(L, LOW);
    delay(200);
You could use the symbol for an LED instead of the symbol for an incandescent bulb.
If you want to give your students a big head start have them use KiCad, it is a full blown schematic capture program that is very well supported. You can leave your wallet in your pocket, for each of your students to have an unlimited edition and your self, it is free for downloading. They will ask for a non required donation. This works very well on Linux and I here good things about it on the Mac and Windoze.
  • Sorry @PaulRB this was meant for @GolamMostafa
  • For a class assignment, suggest no libraries allowed.
  • For switch debounce, simply scan the switches every 50ms; look for a switch change in state, increment a counter when change is detected.
  • Suggest not using while(. . .) as it is evil (unless kept short in duration).
  • Always strive for non-blocking code in sketches !
  • A 5 second non-blocking TIMER would obviously be needed.
  • To help show if there is code blocking, I ALWAYS encourage using a heartbeat LED.
It looks like a really good enough code.
WhatYou could add is how to document code! One old method is Flow Charts. They work like road maps giving an overview of the execution flow.Dry reading code is a very time consuming way to understand what's done.
Thanks to all posters for generous guidance.
I assume you can get an overflow here
update fact(8) = 40320 > 32767
and yes fact(13) = 6.227.020.800 > uint32_t
recursive factorial() is good theory, iterative factorial is fast practice.
uint32_t factiorial(uint8_t n)
  uint32_t fac = n;
  while ((--n) > 1) fac *= n;
  return fac;
Better initialize prMillis just before the loop() as now the calling of loop() will be subtracted from the 5000 ms.
  pressCount = 0;
  blinkL(facValue);
I have got it. I am deciding to limit the pressCount upto eight and declare uint16_factValue.
This is the first time I am seeing the iterative method of computing factorial. Simple and yet thought provoking like implementing artificial iret to execute single instruction in 8086. Thank you so much.
I am not a fan of #define where const int would be more safe. But this is really asking for trouble.
'L' is way too short for a define...
  • If I have one more beer things will go wonky. :face_with_spiral_eyes:
//                                        F a c t o r i a l
//  https://forum.arduino.cc/t/looking-for-better-alternate-approach-sketch/1393668/1
//  See schematic:
//  Version    YY/MM/DD    Comments
//  1.00       25/07/04    Running code
//  Notes:
#define LEDon              HIGH
#define LEDoff             LOW
#define ENABLED            true
#define DISABLED           false
#define CLOSED             LOW
#define OPENED             HIGH
//                              G P I O s   A n d   V a r i a b l e s
//Analogs
//INPUTS
const byte pushButton1   = 2;
//OUTPUTS
const byte LED1          = 12;
const byte Lled          = 13;
const byte heartbeatLED  = 19;   //Same as A5. Gives us an indication if code is blocking.
//VARIABLES
bool switchEnabledFlag   = ENABLED;
bool testingFlag         = DISABLED;
bool solutionFlag        = DISABLED;
byte lastButton1         = OPENED;
const byte limit         = 8;              //Press count is limited to 8.
int pressCount           = 0;              //The number of times the switch was pressed.
unsigned int factorial   = 0;
unsigned int ledToggles  = 0;              //The number of LED toggles (on/off) in the solution.
//Define TIMERs
unsigned long heartbeatTime;
const unsigned long heartbeatInterval  = 500ul;
unsigned long checkSwitchTime;
const unsigned long switchInterval     = 50ul;
unsigned long testingTime;
const unsigned long  testingInterval   = 5000;
unsigned long solutionTime;
const unsigned long solutionInterval   = 300ul;
//                                           s e t u p ( )
  pinMode(pushButton1, INPUT_PULLUP);
  pinMode(Lled, OUTPUT);
  pinMode(heartbeatLED, OUTPUT);
  Serial.println("Testing Ready . . . ");
} //END of   setup()
//                                            l o o p ( )
  //========================================================================  T I M E R  heartbeatLED
  //Is it time to toggle the heartbeat LED ?
  if (millis() - heartbeatTime >= heartbeatInterval)
    //Restart this TIMER.
    heartbeatTime = millis();
    //Toggle the heartbeat LED.
    digitalWrite(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
  //========================================================================  T I M E R  check switches
  //Is it time to scan our switches ?
  if (millis() - checkSwitchTime >= switchInterval)
    checkSwitchTime = millis();
    checkSwitches();
  //========================================================================  T I M E R  testing
  //When enabled, has the testing TIMER expired ?
  if (testingFlag == ENABLED && millis() - testingTime >= testingInterval)
    //Disable switch press counting.
    switchEnabledFlag = DISABLED;
    //Switch counting is finished.
    Serial.println("\nFive seconds is over.\n");
    Serial.print("Button Pressed = ");
    Serial.print(" times. ");
    Serial.print("Factorial = ");
    Serial.println(factorial);
    //Get ready to show the results; double facValue.
    ledToggles = factorial * 2;
    //Enable this TIMER
    solutionFlag = ENABLED;
    //Start the TIMER
    solutionTime = millis();
  //========================================================================  T I M E R  solution
  //When enabled, is it time to toggle the L LED ?
  if (solutionFlag == ENABLED && millis() - solutionTime >= solutionInterval)
    //Are we finished with LED toggling ?
    if (ledToggles > 0)
      //Is ledToggles an even number
      if (ledToggles % 2 == 0)
        //LED goes ON
        digitalWrite(Lled, HIGH);
        ledToggles--;
      //It's odd
        //LED goes OFF
        digitalWrite(Lled, LOW);
        ledToggles--;
    //We are finished.
      //We are finished with the toggling LED results.
      //Switch press counting is allowed.
      Serial.print("\nTesting can now continue.\n");
  //       Other non blocking code goes here
} //END of   loop()
//                                   c h e c k S w i t c h e s ( )
void checkSwitches()
  int pinState;
  //========================================================================  p u s h B u t t o n 1
  pinState = digitalRead(pushButton1);
  //Was the a switch change in state ?
  if (lastButton1 != pinState)
    //Update to the new state.
    lastButton1 = pinState;
    //Is this switch closed ?
    if (pinState == CLOSED)
      //Are we starting a new test ?
      if (testingFlag == DISABLED && solutionFlag == DISABLED)
        Serial.println("\nFive second testing TIMER started.\n");
        //Get ready for the test.
        pressCount = 0;
        factorial = 1;
        //enable our TIMER
        testingFlag = ENABLED;
        //Start the TIMER.
        testingTime = millis();
      //Are we allowed to count switch presses ?
      if (switchEnabledFlag == ENABLED && pressCount < limit)
        Serial.println("Switch Closed");
        digitalWrite(LED1, LEDon);
        pressCount++;
        factorial = factorial * pressCount;
    //The switch was opened.
      digitalWrite(LED1, LEDoff);
} //END of   checkSwitches()
EDIT: Added a limit of 8 presses.
Every recursive function can be rewritten as an iterative one, however the recursive are more elegant and (often) easier to implement.
Going through (binary) trees in different ways, e.g. for adding, searching or deleting, are easier recursive.
A serious risk of recursive functions is stack usage which can crash your system.
A famous recursive algorithm is QuickSort(), it defines a pivot element and swaps all elements smaller and larger than the pivot, and then it calls itself recursively for both sub-array's.
Think that QuickSort() is one of the most researched recursive functions. There exist a variant that sorts the smallest subarray first as that uses the least stack space.
L is printed on the UNOR3 Board for the Built-in Led connected at DPin-13.
That does not matter. Global variables (#defines) should be longer than a few characters to prevent accidental reuse.
Also LED_BUILTIN is probably #defined itself...
So,
is redundant or not necessary.
I can simply write the following code in the setup() function knowing that LED_BUILTIN is the symbolic name for DPin-13:
pinMode(LED_BUILIN, OUTPUT);
Can we always do it?
The inclusion of Debounce.h Library makes the programming cool in the context of:
Key debounce.
Knowing the number of keypress over a duration.
Without using Library, I can try to write discrete codes and see how it goes.
I would say it is very bad programming practice.
And indeed
pinMode(LED_BUILTIN, OUTPUT);
Is much better.
  • The code offered you in post 13 does this.
