Looking for wiring and a code
I got arduino uno r3, nema 23, Router TB6600, 3 push buttons, 2 solenoids, 2 limit switches.
I would like to buy wiring and a code to make it work.
I never tried this before and not sure how much it cost, but let me know your price range.
DM me if you want for this project.
Push clockwise button once.
Make solenoids be active.
Make the motor spin clockwise,
When clockwise limit switch is used then the motor will stop spin clockwise.
Make solenoids not be active anymore.
Push counter-clockwise button once.
Make the motor spin counter-clockwise,
When counter-clockwise limit switch is used then the motor will stop spin counter-clockwise.
Also a stop button for the motor.
Send you a DM
Cheers Pete.
Here is a simulation of your requirements in Wokwi
if that meets your needs, pay forward and give whatever amount you had in mind (what this code means to you) to a humanitarian organisation of your choice.
all the details
the code:
#include <AccelStepper.h>
#include <Toggle.h>
const byte dirPin             = 2;
const byte stepPin            = 3;
const byte cwButtonPin        = 4;
const byte ccwButtonPin       = 5;
const byte cwLimitSwitchPin   = 6;
const byte ccwLimitSwitchPin  = 7;
const byte stopButtonPin      = 8;
const byte solenoidPin        = 9;
const unsigned long cwTarget = 10000000;
const unsigned long ccwTarget = -10000000;
AccelStepper stepper = AccelStepper(AccelStepper::DRIVER, stepPin, dirPin);
Toggle cwButton, ccwButton, cwLimitSwitch, ccwLimitSwitch, stopButton;
enum MotorState {STOPPED, GOING_CW, GOING_CCW} motorState = STOPPED;
void activateSolenoids() {
  digitalWrite(solenoidPin, HIGH);
void deactivateSolenoids() {
  digitalWrite(solenoidPin, LOW);
void stop() {
  deactivateSolenoids();
  stepper.setCurrentPosition(0);
  stepper.moveTo(0);
void motorManagement() {
  cwButton.poll();
  ccwButton.poll();
  cwLimitSwitch.poll();
  ccwLimitSwitch.poll();
  stopButton.poll();
  switch (motorState) {
    case STOPPED:
      if (cwButton.onPress()) {
        stepper.moveTo(cwTarget);
        motorState = GOING_CW;
      } else if (ccwButton.onPress()) {
        stepper.moveTo(ccwTarget);
        motorState = GOING_CCW;
    case GOING_CW:
      if (stopButton.onPress() || cwLimitSwitch.onPress()) stop();
    case GOING_CCW:
      if (stopButton.onPress() || ccwLimitSwitch.onPress()) stop();
  stepper.run();
  pinMode(solenoidPin, OUTPUT);
  cwButton.begin(cwButtonPin);
  ccwButton.begin(ccwButtonPin);
  cwLimitSwitch.begin(cwLimitSwitchPin);
  ccwLimitSwitch.begin(ccwLimitSwitchPin);
  stopButton.begin(stopButtonPin);
  stepper.setMaxSpeed(1000);
  stepper.setAcceleration(20);
  stop();
  motorManagement();
for the wiring:
buttons and limit switches are wired : PIN --- button --- GND
Solenoids : I assume you have some kind of relay driving them. Connect the pin to the input of the relay. never connect a solenoid directly to an Arduino pin.
Motor: wokwi does not have the TB6600 so I used a A4988. Wiring for a TB6600 is documented all over the internet. here is one tutorial.
https://www.makerguides.com/wp-content/uploads/2019/08/TB6600-stepper-motor-driver-with-Arduino-UNO-wiring-diagram-schematic-768x564.jpg
You need a suitable power supply for your motor and another one for the Arduino.
Thank you very much, can you be so nice and DM me.
I can't do that as your profile is hidden.
For today's fun, I Uadded a track to @J-M-L's stepper demo. The track LEDs operate along side the motor controller, and assert the high and low limits by parallel connection to the exist limit pushbuttons.
Note: nothing yet keeps anyone from saying "CW" when the CW limit has been reached, so be careful out there.
Play with it here
Wokwi_badge UA Stepper w/ Track
The code.
// https://forum.arduino.cc/t/looking-for-wiring-and-a-code/1219905
// https://wokwi.com/projects/389441795099790337
// simple stepper demo with stand aside door simulator
# include <AccelStepper.h>
# include <Toggle.h>
// dDMotor for doorDoor
int dDMotor;
void stop() {
  stepper.moveTo(0);
  cwButton.poll();
  ccwButton.poll();
  stopButton.poll();
    case STOPPED:
dDMotor = 0;
    case GOING_CW:
dDMotor = 1;
    case GOING_CCW:
dDMotor = -1;
  stepper.run();
  Serial.println("Hello World!\n");
  setupSimulatedDoor();
  stop();
  motorManagement();
  runSimulatedDoor();
// library Adafruit_NeoPixel
// setup() +
  runSimulatedDoor();   // step the machine so inouts and outpus make sense
// void loop() +
  runSimulatedDoor();
// below here finds itself the door simulation machinery
// find five unused I/O pins
# define sDoorDown  A1
# define sDoorUp    A2
// # define doorX      18
# define sDoorDownMotorPin  A3
# define sDoorUpMotorPin    A4
# define door
# include <Adafruit_NeoPixel.h>
# define PIN A5          // the pin
# define NPIXELS 17     // number of LEDs on strip
Adafruit_NeoPixel doorBar(NPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int lPosition = 6;      // sim door starts at 6
unsigned char dir = 1;  // moving up. or is true down?
void setupSimulatedDoor()
  pinMode(sDoorDown, OUTPUT);
  pinMode(sDoorUp, OUTPUT);
  pinMode(sDoorDownMotorPin, INPUT);
  pinMode(sDoorUpMotorPin, INPUT);
  doorBar.begin();
  doorBar.setPixelColor(2, 0xff0000);
  doorBar.show();
  delay(777);
void runSimulatedDoor()
//  int doorPosition = analogRead(A0);
//  delay(20);
//  digitalWrite(sDoorDown, doorPosition < 100 ? LOW : HIGH); // active low
//  digitalWrite(sDoorUp, doorPosition > 923 ? LOW : HIGH);
  static unsigned long lastTime;
  if (millis() - lastTime < 333) return;
  lastTime = millis();
// this did work checking in this case. may not always
  if (0) {  // test - door will just cycle up and down all by itself
    lPosition += dir ? -1 : 1;
    if ((lPosition == -1) || (lPosition == NPIXELS)) dir = !dir;
  else {    // read the main code outputs and run the door if
    if (dDMotor == 1) lPosition++;
    if (dDMotor == -1) lPosition--;
    if (digitalRead(sDoorDownMotorPin)) lPosition--;
    if (digitalRead(sDoorUpMotorPin)) lPosition++;
  if (lPosition == -1) lPosition = 0;
  if (lPosition == NPIXELS) lPosition = NPIXELS - 1;
// argh! Serial.println(lPosition); delay(777);
  digitalWrite(sDoorDown, lPosition == 0 ? LOW : HIGH);
  digitalWrite(sDoorUp, lPosition == NPIXELS - 1 ? LOW : HIGH);
// moved the output section here to keep everything in phase:
  doorBar.clear();
  doorBar.setPixelColor(lPosition, 0xff0000);
  doorBar.show();
Seven minutes over budget.
The white wires are the only hardware connection between the two processes. The track has one setup() and one loop() function, and in this case I hacked the original code a bit more to just give the track simulator something on which to base the movement of the traveler pixel.
a7
