I am having trouble getting my code to work properly. It is supposed to run a loop if I have a signal from a relay. The loop is supposed to run a set amount of times and once it is done it will send a signal to another relay. Right now it is constantly pulsing a signal to cutPin. Any advice would be appreciated.
const int relayPin = 2;
const int stepPin = 7;
const int cutPin = 4;
const int directionPin = 13;
const int numberOfSteps = 50000;
int relayState = digitalRead(relayPin);
pinMode(relayPin, INPUT);
pinMode(stepPin, OUTPUT);
pinMode(cutPin, OUTPUT);
pinMode(directionPin, OUTPUT);
if (relayState == HIGH){
for (int i=0; i < numberOfSteps; i++){
digitalWrite(stepPin, HIGH);
delayMicroseconds(100);
digitalWrite(stepPin, LOW);
digitalWrite(cutPin, HIGH);
digitalWrite(cutPin, LOW);
delay(100);
delay(20);
but the value of relayState is not changed in loop() so the condition is either always true or always false. You need to read the state of relayPin in the loop() function
I forgot to mention, I am trying to communicate this with another PLC. That is supposed to read if there is a signal coming from the PLC and run the program when there is.
may work to set the value of a variable, but if it does would be once, before any of your code ran.
That statement does not establish a magic connection between the variable the current state of the pin when you use the variable later.
It's a common misconception.Think in terms of how the code works line by line; the only way for a variable to get a new value is with an assignment statement. In this case it means you must digitalRead() the relayPon whenever you want to know what's on the pin at that point.
I made the change and what Im hoping is that the code will cycle through quickly enough when the relaystate is low that it will loop and read it again. And I am still confused why each time the code loops it runs the section of code below while its in the if statement
delay(100);
The stepper motor is supposed to do a certain amount of steps which is equal to numberOfSteps so for now it is 50000 steps. I have 5 volts going to the positive post on the output side of the relay and then the other post on the output side of the relay is connected to pin 2.
Then how can you be sure of the state of relayPin when the relay is not turned on ?
We are now nearly 20 replies into this topic and you have made changes to the sketch. Is it doing what you want ? If not, then describe what it does and what you want it to do
What action do you want to take after the "certain number of steps" ? I ask, because there is no such action in your sketch
The main problem i came here for is that the program is looping and only running the program section that controls the cutpin. I need the cutpin program to only run once the for statement is complete. Right now it will skip the for statement and run the section of code that controls the cutPin
