Loop problem in method calling
Hello everyone, I encountered a problem in my project, my project about a smart robot car with Arduino Uno with ESP8266 board , when I wrote the stopping condition of the car in the loop method does not stop but continues to move automatically and does not stop, how do I stop the car permanently in this case?
#define speedPinR 3
#define RightDirectPin1  12
#define RightDirectPin2  11
#define speedPinL 6
#define LeftDirectPin1  7
#define LeftDirectPin2  8
#define LPT 2
int sensor=A0;
#define SERVO_PIN     9
#define Echo_PIN    2
#define Trig_PIN    10
#define BUZZ_PIN     13
#define FAST_SPEED  250
#define SPEED  120
#define TURN_SPEED  200
#define BACK_SPEED1  255
#define BACK_SPEED2  90
#define USE_ARDUINO_INTERRUPTS true
int Threshold = 550;
int leftscanval, centerscanval, rightscanval, ldiagonalscanval, rdiagonalscanval;
const int distancelimit = 30;
const int sidedistancelimit = 30;
int distance;
int numcycles = 0;
const int turntime = 250;
const int backtime = 300;
int thereis;
Servo head;
/*motor control*/
void go_Advance(void)  //Forward
  digitalWrite(RightDirectPin1, HIGH);
  digitalWrite(RightDirectPin2, LOW);
  digitalWrite(LeftDirectPin1, HIGH);
  digitalWrite(LeftDirectPin2, LOW);
void go_Left()  //Turn left
  digitalWrite(LeftDirectPin1, LOW);
  digitalWrite(LeftDirectPin2, HIGH);
void go_Right()  //Turn right
  digitalWrite(RightDirectPin1, LOW);
  digitalWrite(RightDirectPin2, HIGH);
void go_Back()  //Reverse
void stop_Stop()    //Stop
  set_Motorspeed(0, 0);
/*set motor speed */
void set_Motorspeed(int speed_L, int speed_R)
  analogWrite(speedPinL, speed_L);
  analogWrite(speedPinR, speed_R);
void buzz_ON()   //open buzzer
  for (int i = 0; i < 100; i++)
    digitalWrite(BUZZ_PIN, LOW);
    delay(2);//wait for 1ms
    digitalWrite(BUZZ_PIN, HIGH);
void buzz_OFF()  //close buzzer
void alarm() {
  buzz_ON();
  buzz_OFF();
/*detection of ultrasonic distance*/
int watch() {
  long echo_distance;
  digitalWrite(Trig_PIN, LOW);
  delayMicroseconds(5);
  digitalWrite(Trig_PIN, HIGH);
  delayMicroseconds(15);
  echo_distance = pulseIn(Echo_PIN, HIGH);
  echo_distance = echo_distance * 0.01657; //how far away is the object in cm
  //Serial.println((int)echo_distance);
  return round(echo_distance);
//Meassures distances to the right, left, front, left diagonal, right diagonal and asign them in cm to the variables rightscanval,
//leftscanval, centerscanval, ldiagonalscanval and rdiagonalscanval (there are 5 points for distance testing)
String watchsurrounding() {
  /*  obstacle_status is a binary integer, its last 5 digits stands for if there is any obstacles in 5 directions,
       for example B101000 last 5 digits is 01000, which stands for Left front has obstacle, B100111 means front, right front and right ha
  int obstacle_status = B100000;
  centerscanval = watch();
  if (centerscanval < distancelimit) {
    stop_Stop();
    alarm();
    obstacle_status  = obstacle_status | B100;
  head.write(120);
  delay(100);
  ldiagonalscanval = watch();
  if (ldiagonalscanval < distancelimit) {
    stop_Stop();
    alarm();
    obstacle_status  = obstacle_status | B1000;
  head.write(170); //Didn't use 180 degrees because my servo is not able to take this angle
  delay(300);
  leftscanval = watch();
  if (leftscanval < sidedistancelimit) {
    stop_Stop();
    alarm();
    obstacle_status  = obstacle_status | B10000;
  head.write(90); //use 90 degrees if you are moving your servo through the whole 180 degrees
  delay(100);
    stop_Stop();
    alarm();
  head.write(40);
  delay(100);
  rdiagonalscanval = watch();
  if (rdiagonalscanval < distancelimit) {
    stop_Stop();
    alarm();
    obstacle_status  = obstacle_status | B10;
  head.write(0);
  delay(100);
  rightscanval = watch();
  if (rightscanval < sidedistancelimit) {
    stop_Stop();
    alarm();
    obstacle_status  = obstacle_status | 1;
  head.write(90); //Finish looking around (look forward again)
  delay(300);
  String obstacle_str = String(obstacle_status, BIN);
  obstacle_str = obstacle_str.substring(1, 6);
  return obstacle_str; //return 5-character string standing for 5 direction obstacle status
void auto_avoidance() {
  ++numcycles;
  if (numcycles >= LPT) { //Watch if something is around every LPT loops while moving forward
    stop_Stop();
    String obstacle_sign = watchsurrounding(); // 5 digits of obstacle_sign binary value means the 5 direction obstacle status
    Serial.print("begin str=");
    Serial.println(obstacle_sign);
    if ( obstacle_sign == "10000") {
      Serial.println("SLIT right");
      set_Motorspeed(FAST_SPEED, SPEED);
      go_Advance();
      delay(turntime);
      stop_Stop();
    else    if ( obstacle_sign == "00001"  ) {
      Serial.println("SLIT LEFT");
      set_Motorspeed(SPEED, FAST_SPEED);
      go_Advance();
      delay(turntime);
      stop_Stop();
    else if ( obstacle_sign == "11100" || obstacle_sign == "01000" || obstacle_sign == "11000"  || obstacle_sign == "10100"  || obstacle_sign == "01100" || obstacle_sign == "00100"  || obstacle_sign == "01000" ) {
      Serial.println("hand right");
      go_Right();
      set_Motorspeed(TURN_SPEED, TURN_SPEED);
      delay(turntime);
      stop_Stop();
    else if ( obstacle_sign == "00010" || obstacle_sign == "00111" || obstacle_sign == "00011"  || obstacle_sign == "00101" || obstacle_sign == "00110" || obstacle_sign == "01010" ) {
      Serial.println("hand left");
      go_Left();//Turn left
      delay(turntime);
      stop_Stop();
    else if (  obstacle_sign == "01111" ||  obstacle_sign == "10111" || obstacle_sign == "11111"  ) {
      Serial.println("hand back right");
      go_Left();
      set_Motorspeed( FAST_SPEED, SPEED);
      delay(backtime);
      stop_Stop();
    else if ( obstacle_sign == "11011"  ||    obstacle_sign == "11101"  ||  obstacle_sign == "11110"  || obstacle_sign == "01110"  ) {
      Serial.println("hand back left");
      go_Right();
      set_Motorspeed( SPEED, FAST_SPEED);
      delay(backtime);
      stop_Stop();
    else Serial.println("no handle");
    numcycles = 0; //Restart count of cycles
    set_Motorspeed(SPEED, SPEED);
    go_Advance();  // if nothing is wrong go forward using go() function above.
    delay(backtime);
    stop_Stop();
  //else  Serial.println(numcycles);
  distance = watch(); // use the watch() function to see if anything is ahead (when the robot is just moving forward and not looking around it will test the distance in front)
  if (distance < distancelimit) { // The robot will just stop if it is completely sure there's an obstacle ahead (must test 25 times) (needed to ignore ultrasonic sensor's false signals)
    Serial.println("final go back");
    go_Right();
    delay(backtime * 3 / 2);
    ++thereis;
  if (distance > distancelimit) {
    thereis = 0;
  } //Count is restarted
  if (thereis > 25) {
    Serial.println("final stop");
    stop_Stop(); // Since something is ahead, stop moving.
    thereis = 0;
void stopCar(){
  /*setup L298N pin mode*/
  pinMode(RightDirectPin1, OUTPUT);
  pinMode(RightDirectPin2, OUTPUT);
  pinMode(speedPinL, OUTPUT);
  pinMode(LeftDirectPin1, OUTPUT);
  pinMode(LeftDirectPin2, OUTPUT);
  pinMode(speedPinR, OUTPUT);
  stop_Stop();//stop move
  /*init HC-SR04*/
  pinMode(Trig_PIN, OUTPUT);
  pinMode(Echo_PIN, INPUT);
  /*init buzzer*/
  pinMode(BUZZ_PIN, OUTPUT);
  buzz_OFF();
  /*init servo*/
  head.attach(SERVO_PIN);
  head.write(90);
  delay(2000);
  auto_avoidance();
 int msensor =analogRead(sensor);
    if(msensor>90 || msensor<200){
 Serial.println("car want self-stop automatically ");
go_Right();
stopCar();
delay(20);
a big kick in the car may be ?
for more ideas, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation of your ask).
Hmmm. You haven't exactly given us all the data... Could you post code...?
auto_avoidance();
go_Right();
stopCar();
delay(20);
Hello, do yourself a favour and please read How to get the best out of this forum and modify your 2 post accordingly - esp. posting ALL the code, with code tags...
You might not get any further answer otherwise.
So you want any value between 91 and 199 to do the go right and stop thing...?
ok , i will do this thnk you.
yes ,and otherwise the car will compelete driving.
otherwise, the car will complete driving
post ALL the code.. not just bits of it.
You sure this is supposed to be an OR (||)... or an AND (&&)... ?
This will ALWAYS be true!
I put all code ,but in if condition I write || because I just need one value.
Hello
Did you post the sketch in code tags already?
hi, sorry but I don`t know what you mean exactly
read post #2.
yes thank you ,but i have arduino uno with ESP8266 board
Did you read post 2? .. and post 5, and post 12, and post 14?
Maybe if you did that.. and you posted your code in code tags, someone might help.
I shared my full code ,but I don`t know where put my tags
Click this button when posting </>... then post ALL your code.
ok, I will do this thank you.
