Loop randomly resets at 179 while reading temperature
Hi,i am a bit new to this whole arduino world but i have a small previous C# coding experience,i've just received my arduino Starter Kit and started building project 3,then i decided try creating a sketch that reads the temperature and elaboretes an average temperature with this code:
const int termoPin = A5;
float totVal = 0;
//int tot_i = 1;
//int i = 0;
  int tot_i = 1;  //max array value number counter
  int i = 0;      //array reference counter
  for(int l = 0;l < 10000;l++) {  //reset to avoid "cloging" the average temperature value
    int termoVal[tot_i];
    float voltage[tot_i];
    float temp[tot_i];
    termoVal[i] = analogRead(termoPin);
    voltage[i] = (termoVal[i] / 1024.0) * 5.0;  //conversion from analog valute to voltage
    temp[i] = (voltage[i] - 0.47) * 100;        //conversion from voltage to temperature in celsius
    totVal = temp[i] + totVal;
    float totMedia = totVal / i;  //average temperature
    Serial.println(totMedia);
    Serial.println(i);
    tot_i++;
    i++;
  Serial.println("Cleared");
After i start running the sketch trough my Arduino Uno R3 connected to the sensor it sarts creating the average temperature with a good accuracy,but when the loop reaches the value 171 it suddently restart (without printing the sentence "Cleared").
Welcome to the forum
The for loop iterates 10000 times
How much memory will these 3 arrays need when tot_i reaches its maximum value ?
        float temp[tot_i];
There are other problems too, but solve the one above first
So what should I do?
Do you understand the problem ?
Each level of those 3 arrays needs 10 bytes (2 floats - 4 bytes each and 1 int - 2 bytes)
Your code attempts to create 10000 levels of each array which would need 100000 bytes of storage
Even if the Uno had that much memory your sketch repeatedly declares the 3 arrays in the for loop thus overwriting any values that have already been written to them
Start by explaining what you are trying to do with the sketch and there may be an approach that allows you to use the Uno
first iteration of the for-loop
define arrays with two elements 0,1
second iteration of the for-loop
define arrays with three elements 0,1,2
third iteration of the for-loop
define arrays with four elements 0,1,2,4
10000 iteration
define arrays with 10001 elements 0,1,2,4.....10000
does this make sense?
How much RAM-memory does your microcontroller have?
After reading your previous answer after a hot shower I had an Eureka,so basically I was creating and storing many arrays instead of just changing the value of the valuable one.Thank you so much for your help.
You are creating new arrays with the same names as previous ones thus losing previously stored values until the new arrays are too big to fit in the memory available
How much kB of RAM does your microcontroller have?
How many kB of RAM do you need for a 10000 element array?
There is a different way to obtain an averaged value with a few bytes
even if you would like to use 1 million measurements.
I changed my code and now it works fine:
int i;
int termoVal;
float totVal;
float temp;
  i = 0;
  temp = 0;
  termoVal = 0;
  totVal = 0;
  for (int l = 0; l < 10000; l++) {  //reset per non "intasare" la media in caso di cambio di temperatura
    termoVal = analogRead(termoPin);
    temp = (((termoVal / 1024.0) * 5.0 - 0.484) * 100);  //conversione da valore analogico a voltaggio
    totVal = temp + totVal;
    float totMedia = totVal / i;  //media basata sul numero di cicli
    i++;
  for (int p = 0; p <= 100; p++) {
Thank for your help and i will apreciate further suggestion.
What is the purpose of the last for loop in the loop() function ?
I used it in testing phase to create an easy solution to see when the loop restarts, it's basically useless and I will take it out after some more smaller improvements.
Here is a code-version with two modifications
The averaged value is printed only once every 500 milliseconds
The code waits for a button-press of a button that is connected between IO-pin 4 and GND
const byte termoPin = A5;
int i;
int termoVal;
float totVal;
float temp;
const byte myButtonPin = 4;
  pinMode(myButtonPin,INPUT_PULLUP);
  Serial.println("Setup-Start");
  Serial.println("Starting measuring......");
  i = 0;
  temp = 0;
  termoVal = 0;
  totVal = 0;
    // only once every 500 milliseconds print i and totMedia
    if (millis() % 500 == 0) {
      Serial.print("i:");
      Serial.print(i);
      Serial.print(" totMedia=");
    i++;
  Serial.println("press button to start new averaging");
  while (digitalRead(myButtonPin) == HIGH) {
    // keep looping this while-loop until button is pressed
    // digitalRead(myButtonPin) results in LOW when the button is pressed
best regards Stefan
Thank you Stefan
What is the value of ā€œiā€ the first time this instruction executes?
It's the counter for the number of temperatures registered,it starts by the value of 0 and grows of 1 by any cycles,so I can also use it for the average formula as the total number to divide with.
The point is that as it starts with a value of zero then
will not work the first time round
so i just need to change it to 1?
That sounds like a good idea
