Loopback test for Serial1 on Mega 2560
I have to verify if my Serial1 port on Mega 2560 is functional. While its easy to do a loop back on the main Serial port using the Serial Monitor how do we do it for hardware serial ports like Serial1, Serial2 etc ? Will something like this need to be done after Shorting the Tx and Rx of Serial1 ?
Type a string in serial monitor
Read the same into Serial1
Write the same into serial monitor
have a look at
// Arduino Mega serial1 test
// mega Serial1 pin 18 is Tx
//      Serial1 pin 19 is Rx
// for loopback test connect pin 18 to pin 19
// for RS232 shield connect
// Mega pin 18 TXD to TTL/RD232 Tx
// Mega pin 19 RXD to TTL/RS232 Rx
// for loopback test connect 9-pin D_type connector pins 2 Tx to 3 Rx (pin 5 is GND)
// connect GND pins together and VCC to 5V
  Serial.begin(115200);  // initialise serial monitor port
  Serial1.begin(9600);  //115200);  // initialise Serial1
  Serial.write("Arduino Mega Serial1 test -  for loopback test connect pin 18 to pin 19\n");
  Serial.write("RS232: Mega pin 18 TXD to TTL/RD232 Tx and pin 19 RXD to TTL/RS232 Rx\n");
  Serial.write("RS232 - loopback connect 9-pin D-type pin 2 Tx to pin 3 Rx\n");
  if (Serial1.available()) {  // read from Serial1 output to Serial
    Serial.write(Serial1.read());
  if (Serial.available()) {  // read from Serial outut to Serial1
    char inByte = Serial.read();
    //Serial.write(inByte);     // local echo if required
    Serial1.write(inByte);
connect pin 18 to pin 19 to form a loopback
text entered on serial monitor is echoed back to the display
Your textual codes make sense and they work well when I have converted them into programming codes and have tested on MEGA. TX1-pin is shorted to RX1-pin.
  byte n = Serial.available();
  if ( n != 0)
    char y1 = Serial.read();
    Serial1.print(y1);
    byte m  = Serial1.available();
    if ( m != 0)
      char y2 = Serial1.read();
      Serial.print(y2);
Output:
Forum
Cooperation
Heh:
with a reconfig of
Thanks to all of you who responded ! Problem solved. !
