Serial communication - Arduino Mega and ESP32
I have an Arduino Mega and an ESP32 that I want to connect by serial communication. The thing is, pins 0 and 1 for RX/TX from Mega are not available because they are covered by a screen shield. So, I decided to use pins 18 and 19 for RX/TX, but with the classic code it doesn't work. How to define that I use pins 18 and 19 instead of 0 and 1? I mention that when connecting to pins 0 and 1, the communication works. I'll attach the code for both boards.
Arduino Mega:
  Serial.println("Hello");
ESP32:
#define RX 16
#define TX 17
  Serial2.begin(9600, SERIAL_8N1, RX, TX);
    Serial.println("Message Received: ");
    Serial.println(Serial2.readString());
Do you know how many hardware serial ports the Arduino MEGA has? Why not use an alternate MEGA hardware serial port?
You didn't even attempt a websearch.
I did.
Use Multiple Serial Ports on the Arduino Mega | Arduino Documentation
Mega 2560 Rev3 | Arduino Documentation
Serial1
You should use a voltage divider for the Mega-TX ESP-RX connection to lower the 5V to 3.3V.
Caution:
Use level shifter to connect MEGA and ESP32 as --
1. Connect MEGA and ESP32 using UART2 Ports as per Fig-1 using level shifter.
ESP32-UART-Pins
Figure-1:
2. Upload the following sketches:
MEGA Sketch:
//MEGA
  Serial2.begin(9600);  //RX2 = 17, TX2 = 16
  Serial2.println("Hello"); //sending to ESP32
ESP32 Sketch:
#define RX2 16
#define TX2 17
  Serial2.begin(9600, SERIAL_8N1, RX2, TX2);
  byte n = Serial2.available();
  if (n != 0)
an aletrnative to a level shifter is a potential divider - see Mega_with_ESP-01
basically I have problem with the read.String() that cannot read the data transfer from mega 2560 to esp32 through serial communication2. I hope someone can give to me the solution about my problem
how have you connected the Mega to the ESP32? remember the Mega uses 5V logic the ESP32 3.3V
upload your code (using code tags </>)
