Hello,
A question about looping inside a switch case scenario.
I saw some tutorials and topics on this and other forums about it but it just couldn't work.
Idea: I have 1 button that I want to use to go through a switch case menu.
Only when I press the button, the next case in the switch has to loop,
until then I want the case itself to loop.
In this code, the switch runs through it until it reaches the last one and stops there.
I tried some if / else if statements, one button menu's and other ideas but I'm lost.
In the code I only display the first case, the second and further cases are copies.
Goal: Use the switch case to receive a signal, display a measurement every 1 / 2 secs,
and Most importantly: - I want to loop through custom buzzer and led signals. -
The custom 'receiving signals' are quite simple but I don't know how to isolate just that and keep the rest the same...
Greets!
#include "Arduino.h"
#include <Wire.h> // BMP280 + LCD screen
#include <LiquidCrystal_I2C.h> //LCD screen
#include <SPI.h> //NRF24L01
#include "RF24.h" //NRF24L01
#include "i2c.h" //BMP280 sensor
#include "i2c_BMP280.h" //BMP280 sensor
#include <OneButton.h>
#include <MenuBackend.h>
#define NRF24L01_PIN_CE 4 //D4
#define NRF24L01_PIN_CS 10 //D10
const int menuButton = 3;
int menu = 0;
boolean isPressed = false;
float temperature;
float pascal;
int pascal2;
// leds met int voor hernoeming + buzzers
int led2 = 8;
int led1 = A0;
//int led2 = A1;
int led3 = A2;
int led4 = A3;
const int buzzer = 6; //-> Transistor naar buzzer
LiquidCrystal_I2C lcd(0x27, 20, 4);
BMP280 bmp280;
RF24 myRadio (4, 10);
const int timeout = 1000; //define timeout of 10 sec
//char menuOption = 0; //menu option!
long time0;
struct package //NRF24L01 input
int id = 0;
float temperature = 0.0;
char text[100] = "empty"; //?
byte addresses[][6] = {"0"};
typedef struct package Package;
Package data;
//******************************************************************************************************** initialise & bmp test
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(menuButton, INPUT_PULLUP);
//pinMode(nextButton, INPUT_PULLUP);
lcd.begin(20, 4);
lcd.init(); // initialize the lcd
lcd.backlight();
Serial.begin(115200); //(9600) is standard
while (!Serial) ; //whait for signal
Serial.println("Lets Begin!");
Serial.print("\n Probe BMP280: ");
if (bmp280.initialize()) Serial.println("Sensor found");
Serial.println("Sensor missing");
while (1) {
lcd.setCursor(2, 3); lcd.print("Sensor fout");
// onetime-measure:
bmp280.setEnabled(0);
bmp280.triggerMeasurement();
myRadio.begin();
myRadio.setChannel(115);
myRadio.setPALevel(RF24_PA_MAX);
myRadio.setDataRate( RF24_250KBPS ) ;
myRadio.openReadingPipe(1, addresses[0]);
myRadio.startListening();
//********************************************************************************************************* Button Function - Menu
if (digitalRead(menuButton) == LOW && isPressed == false ) //button is pressed AND this is the first digitalRead() that the button is pressed
isPressed = true; //set to true, so this code will not run again until button released
menudisplay(); // a call to a separate function that performs the switch statement and subsequent evoked code
menu++; // this is done after the doSwitchStatement(), so case 0 will be executed on the first button press
if (menu > 3) {
menu = 0;
//menu = (menu+ 1) % 4; // does the same, without if-statement
} else if (digitalRead(menuButton) == HIGH)
isPressed = false; //button is released, variable reset
void menudisplay() {
switch (menu) {
case 0:
Serial.println("Case 0");
if ( myRadio.available())
while (myRadio.available())
myRadio.read( &data, sizeof(data) );
digitalWrite(buzzer, HIGH); //RECEIVING SIGNALL
digitalWrite(buzzer, LOW); //This is what I want to change.
digitalWrite(led1, HIGH); // All the other stuff has to be the same :)
delay(200); // Only the number on the lcd screen about the menu that i'm in hehe
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
delay(200);
digitalWrite(led2, LOW);
//else
//{lcd.setCursor(0,0); lcd.print("X"); Wanneer de NRF geen signaal meer krijgt - pas de tijd nog aan!
bmp280.awaitMeasurement();
delay(1000); //5 sec - hoe vaak meet de sensor
//float temperature;
bmp280.getTemperature(temperature);
//float pascal;
bmp280.getPressure(pascal);
//int pascal2;
pascal2 = pascal / 100;
//float SLpressure_mB = (((pascal) / pow((1 - ((float)(1)) / 44330), 5.255)) / 100.0); //-> Accurate meting 2 dec.
//lcd.clear(); //ziet er mooier uit - pas op dat er verder niets veranderd
lcd.setCursor(0, 0); lcd.print("****************[V1]"); //lcd.setCursor(0, 1); lcd.print("|"); lcd.setCursor(0, 2); lcd.print("|");
lcd.setCursor(0, 3); lcd.print("______[Menu:1]_____>"); //lcd.setCursor(19, 1); lcd.print("|"); lcd.setCursor(19, 2); lcd.print("|");
lcd.setCursor(1, 1); lcd.print("Temp: "); lcd.print(temperature); lcd.print(" C");
lcd.setCursor(1, 2); lcd.print("Druk: "); lcd.print(pascal2); lcd.print(" mB");
//case 1: ...
//case: 2...
//case: 3...
