I need to make wireless control for pump, but it's about 1,5 km between pump and water tank so I used LoRa, but I meet incoming problem. In first few minutes after connection to power everything is working correctly, but when some time pass reciving module just stop working while transciver module is still working good. Did anybody already met this problem?
I wire it like on this page, but with some change
[Interfacing SX1278 Ra-02 LORA Module with Arduino]
I connected transmitter module as on the image, but instead of potentiometer I used hardware debounced switch connected to pin 2 and LED on pin 4 showing correct state.
On receiver side I also made a little change, instead of LED I connected transistor to control relay
There is receiver code
#include <SPI.h>
#include <LoRa.h>
int LED = 3;
String inString = ""; // string to hold input
int val = 0;
pinMode(LED,OUTPUT);
pinMode(4,OUTPUT);
while (!Serial);
Serial.println("LoRa Receiver");
if (!LoRa.begin(433E6)) { // or 915E6
Serial.println("Starting LoRa failed!");
while (1);
LoRa.setSyncWord(0xF3);
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// read packet
while (LoRa.available())
int inChar = LoRa.read();
inString += (char)inChar;
val = inString.toInt();
Serial.println(inString);
inString = "";
LoRa.packetRssi();
digitalWrite(LED, val);
And that's transmitter
#include <SPI.h>
#include <LoRa.h>
bool sw = 0;
void button();
pinMode(4, OUTPUT);
pinMode(2, INPUT_PULLUP);
while (!Serial);
Serial.println("LoRa Sender");
if (!LoRa.begin(433E6)) { // 433E6 or 915E6, the MHz speed of yout module
while (1);
LoRa.setTxPower(2);
delay(5000);
if(digitalRead(2) == HIGH)
LoRa.beginPacket();
LoRa.print(1);
LoRa.endPacket();
digitalWrite(4, HIGH);
else{
LoRa.beginPacket();
LoRa.print(0);
LoRa.endPacket();
digitalWrite(4, LOW);
Sorry for my english
