LoRa Two Way Communication Failed
I Have a problem with the concept of LoRa Two Way Communication. I tried to apply this concept in my project. So the project is like this:
when there is an object that passes from point A to point B, the ultrasonic sensor will be triggered and the arduino will send a message from point A to point B. The problem is when point a sends a message to point b, sometimes point b can't send a message back to point a, and vice versa.
The sensor will be attached on left, right, and bellow the pillars.
What i used :
  1. Arduiono Uno R3
  2. LoRa Ra-02
  3. Sensor Ultrasonic HC-SR04
4
here's my messy code.
Transmitter
#include <SPI.h>
#include <LoRa.h>
#define TRIGGER1 8
#define TRIGGER2 6
#define TRIGGER3 4
#define ECHO1 7
#define ECHO2 5
#define ECHO3 3
#define LED A0
const int ss = 10;
const int rst = 9;
const int dio0 = 2;
int count = 0;
byte localAddress = 0xBB;     // address of this device
byte destination = 0xFF;      // destination to send to
long lastSendTime = 0;        // last send time
int interval = 50;          // interval between sends
String outgoing;
String LoRaData;
long duration, distance, FIRSTSensor,SECONDSensor,THIRDSensor;
  Serial.begin (115200);
  Serial.println("Starting the system");
  Serial.println("LoRa Transmiter");
  pinMode(TRIGGER1, OUTPUT);
  pinMode(TRIGGER2, OUTPUT);
  pinMode(TRIGGER3, OUTPUT);
  pinMode(ECHO1, INPUT);
  pinMode(ECHO2, INPUT);
  pinMode(ECHO3, INPUT);
  pinMode(LED, OUTPUT);
  LoRa.setPins(ss, rst, dio0);
  while (!Serial);
  if (!LoRa.begin(433E6)){
    Serial.println("Starting LoRa failed!");
    while(1);
  if(millis() - lastSendTime > interval){
    SonarSensor(TRIGGER1, ECHO1);
    FIRSTSensor = distance;
    SonarSensor(TRIGGER2, ECHO2);
    SECONDSensor = distance;
    SonarSensor(TRIGGER3, ECHO3);
    THIRDSensor = distance;
    if((FIRSTSensor >=5) & (FIRSTSensor <=8)){
      if((SECONDSensor >=8) & (SECONDSensor <=10)){
        if((THIRDSensor >=5) & (THIRDSensor <=8)){
          count = count-1;
          digitalWrite(LED,HIGH);
          Serial.print("MOBIL TERDETEKSI\n");
          String message = "ONNN";
          sendMessage(message);
          delay(3000);
          //digitalWrite(LED, LOW);
    if(count==0){
    if(count<=-3){
      //Serial.println("GANTIAN");
      digitalWrite(LED, HIGH);
    //lastSendTime = millis();        // timestamp the message
    //interval = random(50) + 150;    // 2-3 seconds
    //onReceive(LoRa.parsePacket());
     // parse for a packet, and call onReceive with the result:
void sendMessage(String outgoing){
  LoRa.beginPacket();                   // start packet
  LoRa.write(destination);              // add destination address
  LoRa.write(localAddress);             // add sender address
  LoRa.print(outgoing);                 // add payload
  //LoRa.endPacket();                     // finish packet and send it
  LoRa.endPacket(true);                 // lora non-blocking mode
void onReceive(int packetSize){
  if (packetSize == 0) return;          // if there's no packet, return
  int recipient = LoRa.read();          // recipient address
  byte sender = LoRa.read();            // sender address
  String incoming = "";                 // payload of packet
  Serial.print("Packet incoming : " + incoming);
  while (LoRa.available()) {            // can't use readString() in callback, so
    incoming += (char)LoRa.read();      // add bytes one by one
  if(incoming == "ONN"){
    //count++;
    Serial.println("Message: " + incoming);
    Serial.println("MOBIL TERDTEKSI");
    Serial.println("RSSI: " + String(LoRa.packetRssi()));
    Serial.println("Snr: " + String(LoRa.packetSnr()));
    Serial.println(count = count+1);
void SonarSensor(int TRIGGER,int ECHO) {
  digitalWrite(TRIGGER, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGER, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO, HIGH);
  distance = (duration/2) / 29.1;
Receiver
#include <SPI.h>
#include <LoRa.h>
#define TRIGGER1 8
#define TRIGGER2 6
#define TRIGGER3 4
#define ECHO1 7
#define ECHO2 5
#define ECHO3 3
#define LED A0
const int ss = 10;
const int rst = 9;
const int dio0 = 2;
int count = 0;
String outgoing;
String LoRaData;
  while (!Serial);
    while(1);
          count = count-1;
          delay(3000);
    if(count==0){
    if(count<=-3){
    //count++;
The Transmitter and Receiver are bassically the same, but why is it a problem. Is there any way to do LoRa two way communication like the concept i was expecting. Thank you
Its probably a problem because after you transmit a packet you then delay for 3 seconds before attempting to recieve a packet;
delay(3000);
So if the packet is transmitted in that 3 seconds, it will be missed.
Also you need to appreciate that the LoRa devices are transceivers only, they are either in transmit or receive mode, so they cannot receive whilst transmitting.
I can point you to a LoRa library that has several worked examples of two way communications with LoRa devices.
