dannu
September 17, 2020, 10:23am
1
Hy !
You could help with a lora + wifi repeater code.
There is a wifi device connected to it
esp 32 and lora send data
2.lora receives data and esp 32 repeats the signal.
I have a deeper fish radar, I want to increase wifi power to 200m.
Is it possible ?
Are the two ends of the WiFi connection mostly stationary? If so, you might be well served with a parabolic reflector to make your WiFi router directional. The distance record is 382km so 0.2km shouldn't be too hard.
Specially shaped directional antennas can increase the range of a Wi-Fi transmission without a drastic increase in transmission power. High gain antenna may be of many designs, but all allow transmitting a narrow signal beam over greater distance than a non-directional antenna, often nulling out nearby interference sources. Such "WokFi" techniques typically yield gains more than 10 dB over the bare system; enough for line of sight (LOS) ranges of several kilometers (miles) and improvements in
