pls help me solve this error
Arduino: 1.8.18 (Windows 10), Board: "XIAO_ESP32C3, Enabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 160MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None"
Receiver:12:1: error: 'LoRaE5' does not name a type
LoRaE5 lora;
Multiple libraries were found for "WebServer.h"
Used: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\WebServer
Not used: C:\Users\User\Documents\Arduino\libraries\Webduino-master
Multiple libraries were found for "WiFi.h"
Used: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\WiFi
Not used: C:\Users\User\Documents\Arduino\libraries\WiFi
exit status 1
option enabled in File -> Preferences.
Hi @akcoding26. Did you find this sketch code somewhere on the Internet? Or did you write it yourself?
If you found it on the Internet, please provide a link to where you found it in a reply here on this forum topic
Likewise, if you are following some tutorial or reference when writing the code yourself, please provide the link to that tutorial or reference.
That will provide valuable context that will allow the forum helpers to more effectively assist you.
There are two (maybe more) LoRaE5 libraries if I'm not mistaken. Which one did you install?
Did you check the examples that come with the library that you installed?
Next time, please post your code using code tags using the <CODE/> button in the reply window or by using Edit -> Copy for Forum in the IDE.
You can also use the <CODE> button for the errors that you get; it's usually easier for people to copy if needed.
code in post 1 looks like a modified example code p2p_rx.ino from idreamsi/LoRaE5 library
a version for ESP32
// ESP32 <> Grove-E5 LoRa module
// example p2p_rx.ino from https://github.com/idreamsi/LoRaE5
#include <LoRaE5.h>
unsigned char buffer[128] = {0, };
#define GROVE_TX 15//21
#define GROVE_RX 16//20
void setup(void)
SerialUSB.begin(115200);
delay(2000);
Serial.println("ESP32 Grove-E5 receiver");
lora.init(GROVE_RX, GROVE_TX);
lora.init();
char id[200]={0};
char version[50]={0};
lora.getVersion(version, 50);
Serial.printf("Version = %s \n",version);
lora.getId(id, 200);
Serial.printf("ID = %s\n", id);
lora.initP2PMode(866, SF12, BW125, 12, 15, 14);
void loop(void)
short length = 0;
short rssi = 0;
memset(buffer, 0, 128);
length = lora.receivePacketP2PMode(buffer, 128, &rssi, 1);
if(length)
SerialUSB.print("Length is: ");
SerialUSB.println(length);
SerialUSB.print("RSSI is: ");
SerialUSB.println(rssi);
SerialUSB.print("Data is: ");
for(unsigned char i = 0; i < length; i ++)
SerialUSB.print("0x");
SerialUSB.print(buffer[i], HEX);
SerialUSB.print(" ");
SerialUSB.println();
serial monitor displays
Version =
ID = +ID: DevAddr, 42:00:33:26
+ID: DevEui, 2C:F7:F1:20:42:00:33:26
+ID: AppEui, 80:00:00:00:00:00:00:06
not receiving at present - a configuration problem between transmitter (Adafruit Feather 32u4 LoRa module) and above code
EDIT: updated LoRaE5 module code to
#include <LoRaE5.h>
unsigned char buffer[128] = {0};
void setup(void)
delay(2000);
lora.init();
char id[200]={0};
lora.initP2PMode(866, SF7, BW125, 12, 8, 8);
void loop(void)
short length = 0;
short rssi = 0;
if(length)
Serial.print("Length is: ");
Serial.println(length);
Serial.print("RSSI is: ");
Serial.println(rssi);
Serial.print("Data is: ");
Serial.print("0x");
Serial.print(buffer[i], HEX);
Serial.print(" ");
using a Heltec_WiFi_LoRa32_V2 as transmitter
// Heltec ESP32 LoRa (V2) SX1278 transmitter
Programs for Arduino - Copyright of the author Stuart Robinson - 20/01/20
This program is supplied as is, it is up to the user of the program to decide if the program is
suitable for the intended purpose and free from errors.
Program Operation - This is a simple LoRa test transmitter for an ESP32 device. A packet containing
ASCII text is sent according to the frequency and LoRa settings specified in the 'Settings.h' file.
The pins to access the SX127X need to be defined in the 'Settings.h' file also.
The program also has the option of using a logic pin to control the power to the lora and SD card
devices, which can save power in sleep mode. If the hardware is fitted to your board these devices are
powered on by setting the VCCPOWER pin low. If your board does not have this feature set VCCPOWER to -1.
The details of the packet sent and any errors are shown on the Serial Monitor, together with the transmit
power used, the packet length and the CRC of the packet. The matching receive program, '4_LoRa_Receive'
can be used to check the packets are being sent correctly, the frequency and LoRa settings (in Settings.h)
must be the same for the Transmit and Receive program. Sample Serial Monitor output;
10dBm Packet> {packet contents*} BytesSent,23 CRC,DAAB TransmitTime,54mS PacketsSent,1
Serial monitor baud rate is set at 9600
#include <SPI.h> //the SX127X device is SPI based so load the SPI library
#include <SX127XLT.h> //include the appropriate library
#include "Settings.h" //include the setiings file, frequencies, LoRa settings etc
SX127XLT LT; //create a library class instance called LT
uint8_t TXPacketL;
uint32_t TXPacketCount, startmS, endmS;
uint8_t buff[] = "0Hello World 1234567890";
Serial.print(TXpower); //print the transmit power defined
Serial.print(F("dBm "));
Serial.print(F("Packet> "));
Serial.flush();
TXPacketL = sizeof(buff); //set TXPacketL to length of array
buff[TXPacketL - 1] = '*'; //replace null character at buffer end so its visible on reciver
LT.printASCIIPacket(buff, TXPacketL); //print the buffer (the sent packet) as ASCII
digitalWrite(LED1, HIGH);
startmS = millis(); //start transmit timer
if (LT.transmit(buff, TXPacketL, 5000, TXpower, WAIT_TX)) //will return packet length sent if OK, otherwise 0 if transmit error
endmS = millis(); //packet sent, note end time
TXPacketCount++;
packet_is_OK();
packet_is_Error(); //transmit packet returned 0, there was an error
digitalWrite(LED1, LOW);
// increment buff[0] or reset to '0'
if(buff[0]=='9') buff[0]='0';
else buff[0]++;
delay(5000);//packet_delay); //have a delay between packets
void packet_is_OK()
//if here packet has been sent OK
uint16_t localCRC;
Serial.print(F(" BytesSent,"));
Serial.print(TXPacketL); //print transmitted packet length
localCRC = LT.CRCCCITT(buff, TXPacketL, 0xFFFF);
Serial.print(F(" CRC,"));
Serial.print(localCRC, HEX); //print CRC of sent packet
Serial.print(F(" TransmitTime,"));
Serial.print(endmS - startmS); //print transmit time of packet
Serial.print(F("mS"));
Serial.print(F(" PacketsSent,"));
Serial.print(TXPacketCount); //print total of packets sent OK
void packet_is_Error()
//if here there was an error transmitting packet
uint16_t IRQStatus;
IRQStatus = LT.readIrqStatus(); //read the the interrupt register
Serial.print(F(" SendError,"));
Serial.print(F("Length,"));
Serial.print(F(",IRQreg,"));
Serial.print(IRQStatus, HEX); //print IRQ status
LT.printIrqStatus(); //prints the text of which IRQs set
void led_Flash(uint16_t flashes, uint16_t delaymS)
uint16_t index;
for (index = 1; index <= flashes; index++)
delay(delaymS);
delay(delaymS);
pinMode(LED1, OUTPUT); //setup pin as output for indicator LED
led_Flash(2, 125); //two quick LED flashes to indicate program start
if (VCCPOWER >= 0)
pinMode(VCCPOWER, OUTPUT); //For controlling power to external devices
digitalWrite(VCCPOWER, LOW); //VCCOUT on. lora device on
delay(3000);
Serial.println(F("3_LoRa_Transmitter_ESP32 Starting"));
//SPI.begin(); //default setup can be used be used
SPI.begin(SCK, MISO, MOSI); //alternative format for SPI3, VSPI; SPI.begin(SCK,MISO,MOSI,SS)
//SPI beginTranscation is normally part of library routines, but if it is disabled in library
//a single instance is needed here, so uncomment the program line below
//SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
//setup hardware pins used by device, then check if device is found
if (LT.begin(NSS, NRESET, DIO0, LORA_DEVICE))
Serial.println(F("LoRa Device found"));
led_Flash(2, 125); //two further quick LED flashes to indicate device found
Serial.println(F("No device responding"));
while (1)
led_Flash(50, 50); //long fast speed LED flash indicates device error
//The function call list below shows the complete setup for the LoRa device using the information defined in the
//Settings.h file.
//The 'Setup LoRa device' list below can be replaced with a single function call;
//LT.setupLoRa(Frequency, Offset, SpreadingFactor, Bandwidth, CodeRate, Optimisation);
//Setup LoRa device
LT.setMode(MODE_STDBY_RC); //got to standby mode to configure device
LT.setPacketType(PACKET_TYPE_LORA); //set for LoRa transmissions
LT.setRfFrequency(Frequency, Offset); //set the operating frequency
LT.calibrateImage(0); //run calibration after setting frequency
LT.setModulationParams(SpreadingFactor, Bandwidth, CodeRate, LDRO_AUTO); //set LoRa modem parameters
LT.setBufferBaseAddress(0x00, 0x00); //where in the SX buffer packets start, TX and RX
LT.setPacketParams(8, LORA_PACKET_VARIABLE_LENGTH, 255, LORA_CRC_ON, LORA_IQ_NORMAL); //set packet parameters
LT.setSyncWord(LORA_MAC_PRIVATE_SYNCWORD); //syncword, LORA_MAC_PRIVATE_SYNCWORD = 0x12, or LORA_MAC_PUBLIC_SYNCWORD = 0x34
LT.setHighSensitivity(); //set for highest sensitivity at expense of slightly higher LNA current
LT.setDioIrqParams(IRQ_RADIO_ALL, IRQ_TX_DONE, 0, 0); //set for IRQ on RX done
LT.printModemSettings(); //reads and prints the configured LoRa settings, useful check
LT.printOperatingSettings(); //reads and prints the configured operating settings, useful check
LT.printRegisters(0x00, 0x4F); //print contents of device registers, normally 0x00 to 0x4F
Serial.print(F("Transmitter ready"));
Heltec_WiFi_LoRa32_V2 serial monitor output
Transmitter ready
10dBm Packet> 0Hello World 1234567890* BytesSent,24 CRC,3382 TransmitTime,62mS PacketsSent,1
10dBm Packet> 1Hello World 1234567890* BytesSent,24 CRC,481 TransmitTime,62mS PacketsSent,2
10dBm Packet> 2Hello World 1234567890* BytesSent,24 CRC,5D84 TransmitTime,62mS PacketsSent,3
10dBm Packet> 3Hello World 1234567890* BytesSent,24 CRC,6A87 TransmitTime,62mS PacketsSent,4
10dBm Packet> 4Hello World 1234567890* BytesSent,24 CRC,EF8E TransmitTime,62mS PacketsSent,5
10dBm Packet> 5Hello World 1234567890* BytesSent,24 CRC,D88D TransmitTime,62mS PacketsSent,6
10dBm Packet> 6Hello World 1234567890* BytesSent,24 CRC,8188 TransmitTime,62mS PacketsSent,7
10dBm Packet> 7Hello World 1234567890* BytesSent,24 CRC,B68B TransmitTime,62mS PacketsSent,8
10dBm Packet> 8Hello World 1234567890* BytesSent,24 CRC,9BBB TransmitTime,62mS PacketsSent,9
10dBm Packet> 9Hello World 1234567890* BytesSent,24 CRC,ACB8 TransmitTime,62mS PacketsSent,10
10dBm Packet> 0Hello World 1234567890* BytesSent,24 CRC,3382 TransmitTime,62mS PacketsSent,11
10dBm Packet> 1Hello World 1234567890* BytesSent,24 CRC,481 TransmitTime,62mS PacketsSent,12
10dBm Packet> 2Hello World 1234567890* BytesSent,24 CRC,5D84 TransmitTime,62mS PacketsSent,13
10dBm Packet> 3Hello World 1234567890* BytesSent,24 CRC,6A87 TransmitTime,62mS PacketsSent,14
10dBm Packet> 4Hello World 1234567890* BytesSent,24 CRC,EF8E TransmitTime,62mS PacketsSent,15
10dBm Packet> 5Hello World 1234567890* BytesSent,24 CRC,D88D TransmitTime,62mS PacketsSent,16
10dBm Packet> 6Hello World 1234567890* BytesSent,24 CRC,8188 TransmitTime,62mS PacketsSent,17
LoRaE5 serial monitor output
Version =
+TEST: LEN:24, RSSI:-33, SNR:12
+TEST: RX "3048656C6C6F20576F726C6420313233343536373839302A"
Length is: 24
RSSI is: -33
Data is: 0x31 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -34
Data is: 0x32 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -35
Data is: 0x33 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
Data is: 0x34 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
Data is: 0x35 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
Data is: 0x36 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
Data is: 0x37 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
Data is: 0x38 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
Data is: 0x39 0x48 0x65 0x6C 0x6C 0x6F 0x20 0x57 0x6F 0x72 0x6C 0x64 0x20 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x30 0x2A
Length is: 24
RSSI is: -33
NOTE: if the transmitter transmits too fast, e.g. once a second, the receiver crashes with a reset
