Low-Power by Rock Scream No matching function
I am writing a code for a self contain soil moisture sensor box using Arduino Nano. I am a completely armature at Arduino and have been coasting though my previous project with Youtube videos and Wokwi publicly available projects
The gist is that I am trying the Arduino IDE keeps giving me errors saying that TIMER1_0N is not recognized by the library even if I copied the text straight from the library repository.
I am stuck because this project needs the TIMER function to be on in the sleep. To wake up the Arduino every hour to take sensor readings.
I know the code us extremely messy and probably is full of errors but at this moment I really need the TIMER function to work so please if anyone have any advice they can give I will be very grateful.
Thank you for your time in advance
this is the error message
Soil_Moisture_fulltest.ino: In function 'void goToSleep()':
Soil_Moisture_fulltest.ino:95:65: error: no matching function for call to 'LowPowerClass::powerDown(period_t, adc_t, bod_t, timer1_t)'
     LowPower.powerDown(SLEEP_FOREVER, ADC_ON, BOD_OFF, TIMER1_ON);
In file included from T:\Arduino Proj\Soil_Moisture_fulltest\Soil_Moisture_fulltest.ino:1:0:
LowPower.h:151:9: note: candidate: void LowPowerClass::powerDown(period_t, adc_t, bod_t)
    void powerDown(period_t period, adc_t adc, bod_t bod) __attribute__((optimize("-O1")));
LowPower.h:151:9: note:   candidate expects 3 arguments, 4 provided
Soil_Moisture_fulltest.ino:97:66: error: no matching function for call to 'LowPowerClass::powerDown(period_t, adc_t, bod_t, timer1_t)'
     LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF, TIMER1_ON);
In file included fromSoil_Moisture_fulltest.ino:1:0:
#include <LowPower.h>
#include <TimerOne.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
const int moistSensorPin = A0;
const int knockSensorPin = 4;
const int ledPin = 2;
const unsigned long awakeMoistInterval = 500;
unsigned long awakeMoistLastReading = 0;
unsigned long lastKnockTime = 0;
int moistValue = 0;
int moistPercentValue = 0;
volatile bool knockDetected = false;
volatile bool lowMoisture = false;
volatile bool blinkState = false;
  pinMode(knockSensorPin, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
  attachInterrupt(digitalPinToInterrupt(knockSensorPin), knockInterrupt, FALLING);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("Awake! (^w^)b");
  lcd.clear();
  // Initialize Timer1 for blinking
  Timer1.initialize(500); // 0.5 seconds
  Timer1.attachInterrupt(blinkLED);
  if (knockDetected) {
    lastKnockTime = millis();
    lcd.backlight();
    wakeUp();
  if(lowMoisture == true){
    digitalWrite(ledPin, HIGH);
  else {
    digitalWrite(ledPin, LOW);
  if (millis() - awakeMoistLastReading >= awakeMoistInterval) {
    awakeMoistLastReading = millis();
    String msg = moistPercentValue < 30 ? "Dry" : moistPercentValue > 70 ? "WET" : "OK";
    lcd.setCursor(0, 0);
    lcd.print("  Soil : ");
    lcd.print(msg);
    lcd.setCursor(7, 1);
    int moistValue = analogRead(moistSensorPin);
    int moistPercentValue = map(moistValue, 478, 288, 0, 100);
    lcd.print(moistPercentValue);
    lcd.print("%");
    if (moistPercentValue <= 30) {
      lowMoisture = true;
    else {
      Timer1.detachInterrupt();
    Serial.println(moistPercentValue);
  if (millis() - lastKnockTime > 300000) {
    goToSleep();
void goToSleep(){
  // Set timer to wake up every hour
  Timer1.initialize(3600000);
  Timer1.attachInterrupt(wakeUp);
  if (lowMoisture == true) {
void wakeUp() {
  lcd.backlight();
    lowMoisture = true;
  else {
  // Take sensor reading and go back to sleep
  goToSleep();
void knockInterrupt() {
  knockDetected = true;
  wakeUp(); // Wake up from deep sleep
void blinkLED() {
  digitalWrite(ledPin, blinkState);
  blinkState = !blinkState;
The code was written for a different version of the library you have chosen to use. Look for a library that matches the code, or change the code to match the library you are using.
Unfortunately, it is often that case that two different Arduino libraries have the same name.
I think I found a work around. I now use the idle sleep instead of deepsleep. everything is turn off accept adc and timer1. I have other problems at the moment but this is not the topic for it.
Thank you for the responds I appreciate it!
