Might be leaning towards a bad Arduino. ![]()
If you have a DMM (digital multimeter), what voltage is between the Arduino 5v to GND pins ?
Check the PCB to see if there are any poor solder joints.
Hi, @rando_tron232
Can you please try this code, its a edited version of @LarryD with serial print lines added.
When you run it, open the IDE Monitor, set it on 9600 baud and observe what it displays.
Both pins 13 and 7 will be activated.
Serial.println("TEST CODE FOR PIN 13 AND 7 OUTPUT");
// initialize digital pin LED_BUILTIN as an output.
pinMode(13, OUTPUT);
pinMode(7, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(7, HIGH);
Serial.println("PINS HIGH");
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
digitalWrite(7, LOW);
Serial.println("PINS LOW");
Thanks.. Tom...
What pins did you apply 9V to?
