#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <ThreeWire.h>
#include <RtcDS1302.h>
const int SWEEP_STEP = 3;
const int SWEEP_DELAY_MS = 10;
// Define DS1302 pin connections
const int DATpin = 3; // Data
const int CLKpin = 2; // SCLK
const int RSTpin = 4; // RST
// Create 3-wire interface and RTC object
ThreeWire myWire(DATpin, CLKpin, RSTpin); // IO, SCLK, CE
RtcDS1302<ThreeWire> rtc(myWire);
#define Servo_Min 100 //110 // Min pulse width
#define Servo_Max 580 //590 // Max pulse width
#define SERVO_RANGE 270.0 // Total servo rotation
Adafruit_PWMServoDriver brd1(0x40);
Adafruit_PWMServoDriver brd2(0x41);
Adafruit_PWMServoDriver brd3(0x42);
// 1-based array: index 0 is dummy (unused)
Adafruit_PWMServoDriver* arrayBrds[] = { nullptr, &brd1, &brd2, &brd3 };
struct ServoPair {
uint8_t board;
uint8_t servoH; // odd-numbered pin (H-hand, CW)
uint8_t servoM; // even-numbered pin (M-hand, CCW)
// === Grid > first digit brd number, second H hand, third M hand ===
ServoPair servoGrid[3][8] = {
{ { 1, 5, 4 }, { 1, 11, 10 }, { 2, 1, 0 }, { 2, 7, 6 }, { 2, 13, 12 }, { 2, 15, 14 }, { 3, 9, 8 }, { 3, 15, 14 } },
{ { 1, 3, 2 }, { 1, 9, 8 }, { 1, 15, 14 }, { 2, 5, 4 }, { 2, 11, 10 }, { 3, 1, 0 }, { 3, 7, 6 }, { 3, 13, 12 } },
{ { 1, 1, 0 }, { 1, 7, 6 }, { 1, 13, 12 }, { 2, 3, 2 }, { 2, 9, 8 }, { 3, 3, 2 }, { 3, 5, 4 }, { 3, 11, 10 } }
int currentPos[3][8][2]; // [row][col][0 = H-hand, 1 = M-hand]
int TargetPos;
int lastMinute = -1; // To track minute changes
int hour12; // 12-hour format hour
String ampm; // "AM" or "PM"
int dig1, dig2, dig3, dig4; // Time digits: HH:MM
bool isDST_Europe(RtcDateTime now) {
int year = now.Year();
int month = now.Month();
int day = now.Day();
int weekday = now.DayOfWeek(); // Sunday = 0
// DST starts: last Sunday of March
if (month == 3) {
if (day >= 25 && weekday == 0) return now.Hour() >= 2;
if (day > 25) return true;
// DST ends: last Sunday of October
if (month == 10) {
if (day >= 25 && weekday == 0) return now.Hour() < 3 ? true : false;
if (day > 25) return false;
// Between April and September: DST is active
if (month > 3 && month < 10) return true;
return false;
void Get_Time() {
// Set time manually once — comment this out after first upload
RtcDateTime italyTime(2025, 8, 8, 8, 26, 0);
rtc.SetDateTime(italyTime);
Serial.println("RTC time set to Italy local time.");
// Read current time from RTC
RtcDateTime now = rtc.GetDateTime();
int hour24 = now.Hour();
int minute = now.Minute();
// Apply DST offset if needed
if (isDST_Europe(now)) {
hour24 += 1;
if (hour24 >= 24) hour24 -= 24;
if (minute != lastMinute) {
lastMinute = minute;
// Convert to 12-hour format
hour12 = hour24 % 12;
if (hour12 == 0) hour12 = 12;
ampm = (hour24 < 12) ? "AM" : "PM";
// Break into individual digits
dig1 = hour12 / 10;
dig2 = hour12 % 10;
dig3 = minute / 10;
dig4 = minute % 10;
// Serial print formatted time
Serial.print("Time: ");
Serial.print(hour12);
Serial.print(":");
if (minute < 10) Serial.print("0");
Serial.print(minute);
Serial.print(" ");
Serial.println(ampm);
// Serial print digits
Serial.print("Digits: ");
Serial.print(dig1); Serial.print(" ");
Serial.print(dig2); Serial.print(" : ");
Serial.print(dig3); Serial.print(" ");
Serial.println(dig4);
inline void sweepChannel(uint8_t board, uint8_t channel, int &posRef, int target) {
if (posRef == target) return;
int dir = (target > posRef) ? SWEEP_STEP : -SWEEP_STEP;
int p = posRef;
while ((dir > 0 && p < target) || (dir < 0 && p > target)) {
p += dir;
if ((dir > 0 && p > target) || (dir < 0 && p < target)) p = target;
arrayBrds[board]->setPWM(channel, 0, p);
delay(SWEEP_DELAY_MS);
posRef = target;
void sweepAllToMax() {
for (int row = 0; row < 3; row++) {
for (int col = 0; col < 8; col++) {
ServoPair sp = servoGrid[row][col];
sweepChannel(sp.board, sp.servoH, currentPos[row][col][0], Servo_Max);
sweepChannel(sp.board, sp.servoM, currentPos[row][col][1], Servo_Max);
Wire.begin();
rtc.Begin();
for (int b = 1; b <= 3; b++) {
arrayBrds[b]->begin();
arrayBrds[b]->setOscillatorFrequency(27000000);
arrayBrds[b]->setPWMFreq(50);
delay(100);}
sweepAllToMax();
