I designed a little RC aircraft lighting system based on the ULN2803, that has no overcurrent protection. I added a polyfuse (self resetting fuse), that you can see in the lower left corner. Maybe this works for your application.
You might start by telling us what your application is and what the load requirements are including
the mAh rating of your battery (not all 18650s are the same). We also need to know what you wiuld connect the outputs to.
hmeijdam:
Apparently (since it is currently unkown) OP did not read DS18B20 datasheet before posting and just found out they can be bussed but need a common pullup on the data line.I have no idea why he asked about the 8-channel source driver because that won't work for high current RC loads so I don't see the connection to DS18B20's. I can see the application for sensing ESC temp but if the ESC frys you see it lose power or catch fire . You don't need a temp sensor to tell you your aircraft is trailing black smoke or just burst into flames. Just not
seeing where the source driver fits in. Any ideas?
