I'm studing a way to bypass a low cost stepper driver voltage limitation, maybe some of you may had the same issue.
Can one use a custom Mosfets H-bridge to on the +A/-A/+B/-B end to drive the bipolar stepper with approximately the same waveform but using different voltage?
Example:
A L298 with 12v output and 0.25A that passes through this second H-bridge that uses 200v 10amp mosfets? The arduino would be used with a current sensing circuit on the supply voltage to control the current flow.
No, you just use the right MOSFET drivers with the output devices. There are a lot of high-low drivers that
are rated to 200V or even 600V...
However once you are starting to work at high voltage and power levels there are a lot of pitfalls and
its ever so easy to pop MOSFETs (they typically explode, so wearing eye-protection is essential!).
IGBTs are more robust for high voltage, but need extra free-wheel diodes (if not built-in to the package,
IGBTs don't have a body diode as part of their geometry, so its a separate die).
MOSFET/IGBT gate driving is best the province of gate driver chips designed for the purpose, not a cobbled together
small slow H-bridge.
The L298 uses darlingtons so it cannot even pull a gate to 0V for hard turn off, let alone do it in 250ns or
whatever switching window you need for sensible switching losses in a high power H-bridge.
Don't know if its possible, but you need lots of voltage to overcome inductive and motional back-EMF to
run a stepper motor quickly with torque. You do get increased losses as the voltage and switching speed
goes up, and eventually that limits performance.
I've driven a NEMA17 at 2400rpm from 24V, but with very little torque available at that speed. 80V systems
are fairly common for CNC.
Proper stepper driver chips aren't commonly available for very high voltage, so a separate index controller and
explicit MOSFET H-bridges are used with current feedback in hardware I'd imagine for bespoke high voltage
controllers. Most integrated stepper driver chips are around 30 to 50V I think.
