LSM6DS3 Library - Board fails to initialize internal IMU
I am using an Arduino Uno WIFI Rev2 board to read internal gyroscope data. I picked it up after 3 months of not using it, and now the IMU initialization process seems to be broken. There is a condition set up to check whether the IMU has been initialized and it doesn't go past that. If i remove that code, the gyroscope is only sending out data for the first fraction of a second, then stops.
This is the entire code, it has additional stuff but all of that works perfectly if i remove any code that has to do with the IMU.
// Built-in gyroscope library
#include <Arduino_LSM6DS3.h>
// Ultrasonic sensor library
#include "Ultrasonic.h"
Ultrasonic ultrasonicX(2);
Ultrasonic ultrasonicY(3);
Ultrasonic ultrasonicZ(4);
int prev_isClosed = 0;
  // Start the serial communication
  while (!Serial);
  if (!IMU.begin()) {
    Serial.println("Failed to initialize IMU!");
    while (1);
  Serial.print("Gyroscope sample rate = ");
  Serial.print(IMU.gyroscopeSampleRate());
  Serial.println(" Hz");
  Serial.println("Gyroscope in degrees/second");
  Serial.println("X\tY\tZ");
  pinMode(A0, INPUT);
  // Read the gyro data
  float gyro_x, gyro_y, gyro_z;
  // Read the ultrasonic sensor data
  float uson_x = ultrasonicX.MeasureInCentimeters();
  float uson_y = ultrasonicY.MeasureInCentimeters();
  float uson_z = ultrasonicZ.MeasureInCentimeters();
  // proximity sensor indicating whether the box is open or not. 1 for closed, 0 for open
  int isClosed = digitalRead(A1);
  if(isClosed != prev_isClosed){
    Serial.print("prox ");
    Serial.println(isClosed);
    prev_isClosed = isClosed;
  Serial.print("xPos: ");
  Serial.print(uson_x);
  Serial.print(" yPos: ");
  Serial.print(uson_y);
  Serial.print(" zPos: ");
  Serial.println(uson_z);
  //gyroscope data
  if (IMU.gyroscopeAvailable()) {
    IMU.readGyroscope(gyro_x, gyro_y, gyro_z);
    Serial.print("gyro ");
    Serial.print(gyro_x);
    Serial.print(" ");
    Serial.print(gyro_y);
    Serial.print(" ");
    Serial.println(gyro_z);
Check the I2C connections by running the I2C Address Scanner program, with the IMU module connected. If the program doesn't see the correct device address, most likely your wiring is faulty, or the required pullup resistors on SDA and SCL are missing.
I am not using any I2C connections on the board, the IMU module is built in. Does it still make sense to still run address scanner?
It does not matter that the sensor is built in. Run the address scanner and post the addresses reported.
Make SURE that you are using the proper sensor library for your Arduino!
Edit: the schematic for the wifi rev 2 shows that the SPI bus is used instead (which is unusual), so the I2C scanner won't find it. Thus it is even more likely that you are not using the correct library.
So this is the output of the program:
Scanning...
I2C device found at address 0x60  !
done
According to all information I could find the lm6ds3 library is built specifically for my board's IMU.
0x60 is the crypto module. The IMU is not connected to the I2C bus.
Double check the library code to make sure it is using the SPI bus commands.
I'm not entirely sure what to look for,
but here's the begin function from lsm6ds3.cpp
int LSM6DS3Class::begin()
  if (_spi != NULL) {
    pinMode(_csPin, OUTPUT);
    digitalWrite(_csPin, HIGH);
    _spi->begin();
    _wire->begin();
  if (!(readRegister(LSM6DS3_WHO_AM_I_REG) == 0x6C || readRegister(LSM6DS3_WHO_AM_I_REG) == 0x69)) {
    end();
    return 0;
  //set the gyroscope control register to work at 104 Hz, 2000 dps and in bypass mode
  writeRegister(LSM6DS3_CTRL2_G, 0x4C);
  // Set the Accelerometer control register to work at 104 Hz, 4 g,and in bypass mode and enable ODR/4
  // low pass filter (check figure9 of LSM6DS3's datasheet)
  writeRegister(LSM6DS3_CTRL1_XL, 0x4A);
  // set gyroscope power mode to high performance and bandwidth to 16 MHz
  writeRegister(LSM6DS3_CTRL7_G, 0x00);
  // Set the ODR config register to ODR/4
  writeRegister(LSM6DS3_CTRL8_XL, 0x09);
  return 1;
and some definitions from the .h file
  private:
    TwoWire* _wire;
    SPIClass* _spi;
    uint8_t _slaveAddress;
    int _csPin;
    int _irqPin;
    SPISettings _spiSettings;
The library is set up to use either the SPI or the I2C bus.
So, it is possible that some definition or setting outside of the library is forcing it to set up for I2C, which won't work. Be sure to select the correct board in the Arduino IDE.
Or, the sensor is simply not working.
Well, the code in the original post is the only thing that I've written so I don't know what could possibly cause this.
You think it could be a hardware error then?
Selecting the wrong board will cause this.
Definitely have the correct one selected, but I was using the online editor. Tried on the IDE just now, same result. And it's definitely the correct board, and the same COM3 port I used back when everything worked
The sensor may have died an early death. There are plenty of external IMU modules that you can substitute. I would recommend to use the I2C bus to avoid conflicts with the built in sensor.
Could be, yeah. In any case, thanks a lot for your help!
