Hello!
I have been working with an Arduino Nano 33 BLE Sense and in order to reduce the consumption of energy I was trying to turn off the gyroscope (in the respective datasheet, I understand that it consumes a relatively high amount of energy compared to other components in the integrated IMU).
I attempted to modify the writeRegister(LSM9DS1_ADDRESS, LSM9DS1_CTRL_REG1_G, 0x78); with 0x78 -> 0x00. I think it would be enough but the consumption of energy remains the same as before, nothing changed! According to the datasheet, setting the three MBSs of the CTRL_REG1_G register to 0 puts the gyroscope into power-down mode.
I'm not sure if this modification alone is sufficient or if I need to do something else. By the way, I read from other forum that: "The setting may only work when the gyro is disabled..." So, is disabling the gyroscope equivalent as turning it off?
Moderator
Moved to English Forum.
Please read this How to get the best out of this forum
The datasheet will tell, or You can wait for a helper having the specific knowledge in this matter.
What forum would that be? A respected, reputated forum or a common "gutter"?
There's a lot of misinformation on the Internet.
