LT3652 design stops charging around 4.0 V on LiPo
Hi all — I’m a hobbyist looking for help debugging a solar Li‑ion charger based on the LT3652 (schematic attached: schema_v1.pdf).
I’m charging two 18650 cells in parallel, but the charger consistently stops early: it terminates around 4.04–4.08 V instead of reaching the expected 4.20 V float voltage.
Setup
  • Input: small solar panel, ~18 V open‑circuit (VIN is the panel voltage under load)
  • Battery: 2× 18650 in parallel (treated as a single cell)
  • Charger: LT3652 with VFB divider set for ~4.2 V float
  • Icharge NEVER goes over 25mA (design current is 1000mA!!!)
Observed behavior
  • Charging current tapers and CHRG goes low when the battery reaches ~4.04–4.08 V
  • The battery never reaches 4.20 V
  • Same behavior across multiple PCB revisions and different divider values
VFB divider tests
  • Initially designed per datasheet guidelines (including input bias compensation)
  • Later increased equivalent resistance to better match recommendations (~250 kΩ)
  • Also tested other combinations (e.g. 330 kΩ / 1.2 MΩ)
  • Result unchanged: termination still occurs at ~4.0 V
Measurements and checks
  • Current/voltage monitored with INA219 (both battery and panel side)
    • Current drops to near zero at ~4.05 V
  • SHDN pin:
    • Always > 1.25 V → device is enabled (threshold ~1.2 V)
  • VIN_REG:
    • Measured > 2.7 V → no apparent input undervoltage regulation
  • VFB:
    • Around 3.3 V at termination (as expected for CV phase)
Input power observations
  • With ~16 V available from the panel, input current is only ~20–25 mA
  • Panel voltage stays close to open‑circuit, only slightly dropping under load
  • Even with a second panel, current remains very low (<50 mA peak)
  • This suggests the system may be operating in a very limited input‑power condition
  • However, VIN_REG / VREFIN remains above threshold, so input regulation does not appear to be the direct cause of early termination
Bench supply test
  • Powered VIN from a bench supply instead of the solar panel
  • Same behavior observed:
    • With a partially discharged battery (~3.7 V), input current is still limited to ~25 mA
    • VFB remains around 3.3 V
  • So the issue does not seem tied to the solar source
Strange observation on VFB
  • When probing VFB with a multimeter, input current increases (up to ~60 mA)
  • This seems too large to be explained by measurement loading alone
  • It makes me suspect:
    • Possible grounding issue
    • Noise or instability on the VFB node
    • The IC not correctly sensing the feedback voltage
(I’m also attaching a PCB photo for layout review.)
What I have NOT changed
  • SHDN is not driven by firmware and stays high
  • Safety timer is configured as in the schematic
Questions
Based on the schematic and measurements, what should I investigate next?
In particular:
  • Could PCB layout (switch node, ground routing, VFB trace, VIN_REG filtering) cause incorrect VFB sensing or early CV termination?
  • Are there known LT3652 pitfalls (sense resistor routing, diode orientation, inductor placement, grounding strategy, compensation network issues) that could explain termination around ~4.0 V?
  • Could the very low charge current (~25 mA even with bench supply) indicate a hidden limiting condition (e.g. ILIM, thermal, or internal fault behavior)?
Thanks in advance — any targeted debugging suggestions or measurement ideas would be greatly appreciated.
FILES: Download schema_v1.pdf | LimeWire
Do you get the same response when you charge only a single 18650? Are your cells "protected" variety?
Are you aware that charging to a slightly lower voltage than 4.2 actually extends the lifetime of LiPo cells? The effect is dramatic.
yes, same issue with one single LiPo 18650.
I didn’t realize it had such a big impact. The problem is that I still can’t charge the battery! The charging current always stays around 25 mA, both with the solar panel (in full sun) and with the bench power supply. As a result, the energy storage is basically unusable, or at least very limited.
Datasheet of the cell you use?
Here is the DS. I tested several brand (low cost china) and got the same issue.
Is GND PAD (13) connected to Ground?
Does not look like it.
The values I calculated for resistors are 318K and 1.17M
YES! I also applied some vias for enance thermal exchage with grounded bottom plane.
Here attached the second version of my design, but also this one has the same issues as the one reported in the previous schematic.
For the Resistor I used 330k // 1.2M 1% 0603 . But the main issue is the max absorbed current about 25mA, it grows up to 65mA while I put on Vfb terminal the probe.
Did you calibrate that.
Are you sure your DMM is accurate.
A low battery in your DMM can also throw things off.
Yes, even with a bench power supply (set voltage and current limit), I'm only measuring around 0.25 mA of absorbed current.
Is there any way to check whether the LT3652 has a proper ground connection using the exposed pins? (I soldered it using a homemade reflow oven.)
"Does my design seem to have any RF coupling or other problems
When I asked if it was connected to ground your answer was "YES!". So how did you check it then?
Using copper pours for ground/power connections can be quite problematic. Did you examine each and every ground path?
Is that also with flat batteries.
Most chargers reduce charge current between 4.0 and 4.2volt from full to zero.
My question was if your voltmeter was not reading too low.
Sorry, I thought you were referring to the PCB connection itself (the F.Cu layer). In any case, given the LT3652 package, I’m not sure how to verify whether the soldering underneath was actually successful, even though I followed a standard reflow profile for the solder alloy I used.
Is that also with flat batteries.Most chargers reduce charge current between 4.0 and 4.2volt from full to zero.
I tried discharging the batteries — I did the same test with just one cell as well — down to about 3.6 V, and the behavior is exactly the same: it only charges at 25 mA, both in full sun and with a bench power supply. I checked it with a DMM, a small multimeter (DSO TC3), and the readings from the bench supply itself, and those three measurements are consistent with each other.
So possible problems:
  1. If the thermal vias are to big the paste will just flow out.
    Also thermals may prevent the solder from reaching the correct temperature.
  2. Bad copper pours.
  3. Poor layout
  4. Incorect component selection.
THX for your suggestion.
  1. Thermal vias have 0.3 mm hole diameter. I was thinking the opposite: with heating from both top and bottom during reflow, the thermal wave should reach the vias before, or at least at the same time as, the surface reaches the peak temperature.
  2. and
  3. I can’t say for sure (except I tested each pad to be sure there arent sort circuit) and leave a GND plane under all the loop SW-BOOST and SENSE as shown in the img.
  4. The components are quite similar to those on the LT evaluation board, except for the following:
Component LT eval board My design Note
Bootstrap capacitor 1 uF, 50 V ceramic 1 uF, 50 V ceramic Same value and type
Diode on SW path Schottky diode SS14 Same class, but lower current margin
Bootstrap diode Schottky diode CUS10S30 Vin<20V (Voc panel 18.5V -measured)
4.1. The resistance above Vfb, 330k // 1.2M, should match the equivalent resistance requested in the datasheet.
I've never tried to DIY reflow a part with a thermal pad, so I can't provide any further help in that area.
Copper pours:
When used for grounds you could wind up having isolated islands, long ground paths, or very small copper traces.
I looked at the LTC demo board and it was 4 layers.
Yes, but I can’t image this pcb as 4 layer:
or this other one (more accurate from my view) :
so you say they could miss in my design?
Very posible.
I always route the grounds and powers with the proper width traces, then pour over them or use a separate plane layer.
Does that board you show have thermal vias under the IC?
First all thx to your support.
Here is the bottom layer (B.Cu). It seems to be well connected, but are there any tests you would suggest?
I found many 2-layer designs, but I’m not expert enough to say whether mine is comparable to the others.
Trace a line from the LT3652 ground to the input connector and the battery connector. Are they short with no restrictions?
