LTC2485 arduino library
I want to use LTC2485 with current meter as part of VA-logger.
Please help me to find library for this device or example sketch.
google gave me this code
update:
A quick look shows it is not a library and 7 yrs old code, but it could get you started.
datasheet
I CAN use Google and found this long time ago. That is why I created this topic. I'm looking for example code and library I can use in IDE. Files from "Linduino" I cannot connect to IDE.
@vitaliykrym
Sorry, you did not mention in your post what you did so far, so I assumed incorrectly that you had no information at all.
Searched a bit further and found no library not in the Arduino registry, not on Platformio.
On GitHub I found only partial pieces of code, but I assume you have seen those too.
So my conclusion is no (maintained) library for the LTC2485 exists.
The datasheet does not look too complicated, so writing / testing / registering etcetera an initial version could be done in 10 hours if no problems pop up. (estimate based on libraries written in the past).
@vitaliykrym
Created an initial version of an Arduino library for the LTC2485 as 24 bit for an ADC is interesting.
Currently the library has four examples.
The code is based upon the datasheet, and compiles for UNO, M4, ESP32 and RPIpico
The library is not tested with hardware, documentation is limited, no unit tests exists.
Hello.
Thank you for library but non of examples are working.
Address 0x16. Ref 3.3V input 2.5V
LTC2485_connect:
Could not connect to device
2009	address: 22
4009	address: 22
6009	address: 22
8010	address: 22
After LTC.begin(); should be delay(200);
FILE: LTC2485_internal_temp_volt.ino
TEMP: 688.48
VOLT: 661.90
TEMP: 688.48
VOLT: 661.90
TEMP: 688.48
VOLT: 661.90
TEMP: 688.48
FILE: LTC2485_performance.ino
speed	micros
50000	1036
100000	552
150000	396
200000	332
250000	300
300000	268
350000	248
400000	244
450000	228
500000	220
550000	212
FILE: LTC2485_plot_microVolts.ino
microVolts
0.00
0.00
0.00
0.00
0.00
0.00
FILE: LTC2485_plotter.ino
TEMP 	 milliVolts
688.48 	 0.662
688.48 	 0.662
688.48 	 0.662
688.48 	 0.662
688.48 	 0.662
688.48 	 0.662
688.48 	 0.662
FILE: LTC2485_reject_50Hz.ino
ADC: 2147483647
ADC: 274631983
ADC: 276637956
ADC: 275681966
ADC: 273102616
ADC: 274233839
ADC: 273406856
ADC: 274928092
ADC: 274844750
ADC: 276156485
ADC: 274579567
ADC: 272766268
ADC: 274259707
| robtillaart
February 22 |
@vitaliykrym
github.com
GitHub - RobTillaart/LTC2485: Arduino library for LTC2485 I2C 24 bit ADC.
OK, I do not have the hardware to test so I depend on you for that.
First thing to tackle is the connection.
Can you try this version of the connect sketch.
It has adjusted the address of the device.
//    FILE: LTC2485_connect.ino
//  AUTHOR: Rob Tillaart
// PURPOSE: detect device on I2C bus
//     URL: https://github.com/RobTillaart/LTC2485
#include "Wire.h"
#include "LTC2485.h"
//  adjust address if needed
//  0x14  CA1 = LOW  CA0 = HIGH
LTC2485 LTC(0x16);
  while(!Serial);
  Serial.println(__FILE__);
  Serial.print("LTC2485_LIB_VERSION: ");
  Serial.println(LTC2485_LIB_VERSION);
  Wire.begin();
  Wire.setClock(100000);
  LTC.begin();
  while (!LTC.isConnected())
    Serial.println("Could not connect to device");
    delay(2000);
  Serial.print(millis());
  Serial.print("\taddress: ");
  Serial.println(LTC.getAddress());
  delay(2000);
//  -- END OF FILE --
FYI, the library is updated to 0.1.1 this morning.
(no major changes)
that would be a wait for the first conversion I assume?
Where in the datasheet is this delay mentioned?
I only see these
It is not mentioned but without it it shows "device not found" once.
I sent result before but here is hew one
C:\Users\maintbr\AppData\Local\Temp\.arduinoIDE-unsaved2025124-2380-1gksys6.zjtr\LTC2485_plotter\LTC2485_plotter.ino
LTC2485_LIB_VERSION: 0.1.1
Could not connect to device (this disapeares with delay(200);
2009	address: 22
4009	address: 22
6009	address: 22
8010	address: 22
10011	address: 22
12011	address: 22
14012	address: 22
16013	address: 22
18014	address: 22
20014	address: 22
22014	address: 22
| robtillaart
February 24 |
vitaliykrym:
Hello.
vitaliykrym:
LTC2485_connect:
#include "Wire.h"
LTC2485 LTC(0x16);
  while(!Serial);
  Wire.begin();
  LTC.begin();
    delay(2000);
  delay(2000);
OK, I can update the examples with the delay(200);
I assume it is for the first conversion as during conversion it might just not be able to answer I2C call.
Lets find out
Created a new develop branch.
This includes a new example LTC2485_getADC() which is the only one you need to test as it checks the core reading from the ADC.
I have modified the LTC2485::read() function to return the amount of bytes it got from the device.
uint32_t LTC2485::_read()
  uint32_t rv = 0;
  int n = _wire->requestFrom(_address, (uint8_t)4);
  if (n == 4)
    _lastRead = millis();
    rv |= _wire->read();
    rv <<= 8;
    rv <<= 8;
    rv <<= 8;
    return rv;
  return n;
So we can see if the device honors the request for 4 bytes.
I do not see new example.
May be it should be like this
rv <<= 24;
rv <<= 16;
rv <<= 8;
@vitaliykrym
this one should be in it.
//    FILE: LTC2485_getADC.ino
// PURPOSE: minimal test
#include "Wire.h"
LTC2485 LTC(0x16);
  while(!Serial);
  Wire.begin();
  LTC.begin();
  delay(200);
    Serial.print("Could not connect to device ");
    delay(2000);
  Serial.print("\tADC: ");
  Serial.println(LTC.getADC());
  delay(2000);
no then the first 8 bytes would shift 24 + 16 + 8 = 48 places
Think you meant
rv = _wire->read() << 24;
rv |= _wire->read() << 16;
rv |= _wire->read() << 8;
That would work too but need 48 bits to shift, where the library only uses 24.
For some processors this is less optimal.
C:\Users\maintbr\AppData\Local\Temp\.arduinoIDE-unsaved2025124-11820-6v2xjb.79hn\sketch_feb24a\sketch_feb24a.ino
206	ADC: 2147483647
2207	ADC: 2147483647
4208	ADC: 2147483647
6209	ADC: 2147483647
How it can give more then 2^24?
Looking at identical number I would say it does not read anything.
Have you downloaded the 0.1.2 develop branch?
Version 0.1.1 has no error handling, only a very crude flag. That is probably the cause.
And yes I agree it seems there is nothing read.
So I need some time to read the datasheet in more detail.
