I'd like to mirror what I see on the small LCD on to a monitor. VGA or else HDMI. I realize that it'll still be 320x240 resolution, just on a larger screen.
I'm hoping I can buy an adapter and make this work with some soldering and wiring.
The pinout diagram going to the LCD looks like this:
1 FLM First Line Mark / Shift Direction Select
2 M Alternation Control Signal
3 CL1 LP, data latch (row) / Display Data I/P Clock
4 CL1 CP, data shift (column) / Display Data I/P Clock
5 DISPOFF Controls Display off, 0: off, 1: on
6 D0 Data Pin
7 D1 Data Pin
8 D2 Data Pin
9 D3 Data Pin
10 VDD+5V Power Supply 5volts
11 VSS-GRD Ground
12 VLC-24V
13 VO Contrast Adjustment, usually uses POT that can source 0-5V
14 FGND
I'd like to split out these pins to feed both the LCD and an optional monitor so I don't have to squint over the device and look at the small LCD to see what I am doing all the time.
There's lots of options to convert VGA or HDMI to LVDS. But not vice versa. I need to convert the signal the opposite way. monochrome. Only 4 bits. It shouldn't be too difficult.
I was not joking at all. Unless you are a really experienced and knowledgeable engineer armed with complete documentation on the device and all the interface protocols, you haven't even a slim chance.
