I recently bought a Mac Mini (2010) running Catalina v10.15.7
I freshly installed the Arduino IDE and I wanted to program my Adafruit VL450X. I have connected the SCL and SDA pins to the chip and the Uno. When I want to upload the sketch it gives me the following error:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno"
Sketch uses 1486 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 200 bytes (9%) of dynamic memory, leaving 1848 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have tried using a different port, I used 1 and now 4. I have selected /dev/cu.usbserial-640 so that should be fine. I have also tried using three different cables and two different Arduino Uno's. One is 100% new, the other I have been using for a while and I know for sure it works. I haven't tried uploading the sketch on my Windows PC, I could try that, but I kind of want to program my Arduino Uno on my Mac.
Any advice or tips?
