I was having trouble with this compilation error, too.
fork/exec /usr/local/bin/python: no such file or directory}
but I solved it with your instruction.
Compilation complete.
really appriciated.
really appriciated.
Bhargav3's method solved the issue (upload via USB works) but killed the ArduinoOTA. Any ideas? Here's the error message:
java.io.IOException: Cannot run program "python": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.GenericNetworkUploader.uploadUsingPreferences(GenericNetworkUploader.java:99)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2061)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:247)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 10 more
An error occurred while uploading the sketch
I tried cometmace's suggestion above and edited the second reference to python within the file, but it didn't work.
@riemannn your python path might be different. Try this
which python3
then use the output as the python path and try compiling again.
Thank you for the quick response.
This is what I have on the relevant parts of platform.txt where there are 2 instances of python (just to reiterate, USB upload works with this configuration below, but ArduinoOTA upload doesn't):
tools.esptool_py.network_cmd=python "{runtime.platform.path}/tools/espota.py"
tools.esptool_py.network_cmd.windows="{runtime.platform.path}/tools/espota.exe"
tools.gen_esp32part.cmd=/usr/local/bin/python3 "{runtime.platform.path}/tools/gen_esp32part.py"
tools.gen_esp32part.cmd.windows="{runtime.platform.path}/tools/gen_esp32part.exe"
Editing tools.esptool_py.network_cmd=python part as well to python3
or /usr/local/bin/python3
or to any of the other variations I could think of, gives the same error in ArduinoOTA upload (USB upload always works).
And this is what which python3
command returns on Terminal:
/Library/Frameworks/Python.framework/Versions/3.10/bin/python3
Any ideas?
@riemannn that's what I have said. Use that output path in platform.txt instead of /usr/local/bin/python3
tools.gen_esp32part.cmd=/Library/Frameworks/Python.framework/Versions/3.10/bin/python3 "{runtime.platform.path}/tools/gen_esp32part.py"
Try this and let me know
@bhargav3 Thank you, that did it! Do you think I should change the following Python path as well, to avoid future problems? Currently everything works, so I'm reluctant to touch anything. Just curious what you think.
Great! Change that setting a well. Basically where ever you find only python without the full path, please update it to full path.
I wondered why all my old sketches stopped working - thanks for this!
My python path is /Library/Frameworks/Python.framework/Versions/3.9/bin/python3 btw
@ bhargav3
Besten Dank, die Lösung hat bei mir auf Anhieb funktioniert!!!!!
Thank you !! worked for me!
Same here, with this (python3) modification all my ESP32 sketches compile again. Thanks!
I stopped pulling my hair out.
Thanks...I edited it to python3, if that helps anybody else.
It's frustrating when Apple just decides to remove python, but shameful that Arduino did not put out a bulletin and a macro to do this for you. I have a box stock Mac M1 and unmodified latest build IDE. Shame!
Yes, worked for me also, would never have found that solution without your help, so a big thank you!
Iam using arduino ide 1.8.9 with osx 10.9.5 and python version 2.7. after upload blank sketch and following the instruction I got log message error
Arduino: 1.8.9 (Mac OS X), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/tonymaryana/Library/Arduino15/packages -hardware /Users/tonymaryana/Documents/Arduino/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/tonymaryana/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/tonymaryana/Documents/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none -ide-version=10809 -build-path /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542 -warnings=none -build-cache /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_cache_670068 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0 -prefs=runtime.tools.mkspiffs.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -verbose /Users/tonymaryana/Documents/Arduino/cekboard/cekboard.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/tonymaryana/Library/Arduino15/packages -hardware /Users/tonymaryana/Documents/Arduino/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/tonymaryana/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/tonymaryana/Documents/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none -ide-version=10809 -build-path /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542 -warnings=none -build-cache /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_cache_670068 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0 -prefs=runtime.tools.mkspiffs.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -verbose /Users/tonymaryana/Documents/Arduino/cekboard/cekboard.ino
Using board 'esp32' from platform in folder: /Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3
Using core 'esp32' from platform in folder: /Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3
WARNING: Category '' in library ESP RainMaker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFiProv is not valid. Setting to 'Uncategorized'
bash -c "[ ! -f \"/Users/tonymaryana/Documents/Arduino/cekboard\"/partitions.csv ] || cp -f \"/Users/tonymaryana/Documents/Arduino/cekboard\"/partitions.csv \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/partitions.csv"
bash -c "[ -f \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/partitions.csv ] || [ ! -f \"/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32\"/partitions.csv ] || cp \"/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32\"/partitions.csv \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/partitions.csv"
bash -c "[ -f \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/partitions.csv ] || cp \"/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3\"/tools/partitions/default.csv \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/partitions.csv"
bash -c "[ -f \"/Users/tonymaryana/Documents/Arduino/cekboard\"/bootloader.bin ] && cp -f \"/Users/tonymaryana/Documents/Arduino/cekboard\"/bootloader.bin \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/cekboard.ino.bootloader.bin || ( [ -f \"/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32\"/bootloader.bin ] && cp \"/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32\"/bootloader.bin \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/cekboard.ino.bootloader.bin || cp -f \"/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3\"/tools/sdk/esp32/bin/bootloader_qio_80m.bin \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/cekboard.ino.bootloader.bin )"
bash -c "[ ! -f \"/Users/tonymaryana/Documents/Arduino/cekboard\"/build_opt.h ] || cp -f \"/Users/tonymaryana/Documents/Arduino/cekboard\"/build_opt.h \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/build_opt.h"
bash -c "[ -f \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/build_opt.h ] || touch \"/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542\"/build_opt.h"
Detecting libraries used...
/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-1-gb8050b365e\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/config -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/newlib/platform_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/heap/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/log/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/include/apps -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/platform_port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/port/soc -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/xtensa/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/driver/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/driver/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_pm/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/efuse/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/efuse/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/vfs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_wifi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_event/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_netif/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_eth/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_phy/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_ipc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/app_trace/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_timer/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/app_update/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/spi_flash/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bootloader_support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nvs_flash/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/pthread/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/espcoredump/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ieee802154/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/console -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/asio/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/osi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/cbor/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/unity/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/unity/unity/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/cmock/CMock/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/coap/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/coap/libcoap/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nghttp/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-tls -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hid/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/tcp_transport/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_http_client/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_http_server/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_https_ota/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_lcd/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_lcd/interface -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/common -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/security -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/transports -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mdns/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/sdmmc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/expat/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wear_levelling/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/diskio -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/vfs -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freemodbus/common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/idf_test/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/jsmn/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json/cJSON -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/libsodium/port_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/openssl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/perfmon/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/spiffs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ulp/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/button/button/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/rmaker_common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_parser/upstream -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_generator/upstream -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_schedule/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/qrcode/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ws2812_led -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_littlefs/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_littlefs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/image -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/math -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fb_gfx/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/qspi_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/build_opt.h -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/cores/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32 /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/sketch/cekboard.ino.cpp -o /dev/null
Generating function prototypes...
/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-1-gb8050b365e\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/config -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/newlib/platform_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/heap/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/log/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/include/apps -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/platform_port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/port/soc -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/xtensa/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/driver/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/driver/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_pm/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/efuse/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/efuse/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/vfs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_wifi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_event/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_netif/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_eth/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_phy/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_ipc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/app_trace/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_timer/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/app_update/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/spi_flash/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bootloader_support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nvs_flash/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/pthread/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/espcoredump/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ieee802154/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/console -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/asio/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/osi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/cbor/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/unity/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/unity/unity/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/cmock/CMock/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/coap/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/coap/libcoap/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nghttp/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-tls -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hid/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/tcp_transport/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_http_client/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_http_server/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_https_ota/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_lcd/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_lcd/interface -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/common -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/security -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/transports -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mdns/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/sdmmc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/expat/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wear_levelling/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/diskio -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/vfs -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freemodbus/common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/idf_test/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/jsmn/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json/cJSON -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/libsodium/port_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/openssl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/perfmon/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/spiffs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ulp/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/button/button/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/rmaker_common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_parser/upstream -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_generator/upstream -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_schedule/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/qrcode/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ws2812_led -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_littlefs/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_littlefs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/image -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/math -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fb_gfx/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/qspi_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/build_opt.h -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/cores/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32 /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/sketch/cekboard.ino.cpp -o /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.1-1-gb8050b365e\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/config -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/newlib/platform_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/heap/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/log/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/include/apps -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/soc/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/hal/platform_port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/port/soc -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/xtensa/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/driver/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/driver/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_pm/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/efuse/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/efuse/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/vfs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_wifi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_event/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_netif/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_eth/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_phy/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_ipc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/app_trace/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_timer/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/app_update/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/spi_flash/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bootloader_support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nvs_flash/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/pthread/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/espcoredump/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ieee802154/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/console -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/asio/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/osi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/cbor/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/unity/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/unity/unity/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/cmock/CMock/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/coap/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/coap/libcoap/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nghttp/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-tls -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_hid/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/tcp_transport/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_http_client/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_http_server/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_https_ota/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_lcd/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_lcd/interface -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/common -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/security -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/protocomm/include/transports -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mdns/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/sdmmc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/expat/port/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wear_levelling/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/diskio -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/vfs -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fatfs/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/freemodbus/common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/idf_test/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/jsmn/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json/cJSON -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/libsodium/port_include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/openssl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/perfmon/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/spiffs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ulp/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/button/button/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/rmaker_common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_parser/upstream -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/json_generator/upstream -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_schedule/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/qrcode/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/ws2812_led -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_littlefs/src -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp_littlefs/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/image -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/math -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/include/fb_gfx/include -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/qspi_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/build_opt.h -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/cores/esp32 -I/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/variants/esp32 /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/sketch/cekboard.ino.cpp -o /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/sketch/cekboard.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_cache_670068/core/core_3b442995743665f6e3cdfd0b0d86a80d.a
Linking everything together...
/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++ -Wl,--Map=/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/cekboard.ino.map -L/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/lib -L/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/ld -L/Users/tonymaryana/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/tools/sdk/esp32/qspi_qspi -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/sketch/cekboard.ino.cpp.o /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_cache_670068/core/core_3b442995743665f6e3cdfd0b0d86a80d.a -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lbutton -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lwakenet -lmultinet -lesp_audio_processor -lesp_audio_front_end -lesp-sr -lwakenet -lmultinet -lesp_audio_processor -lesp_audio_front_end -ljson -lspiffs -ldl_lib -lc_speech_features -lhilexin_wn5 -lhilexin_wn5X2 -lhilexin_wn5X3 -lnihaoxiaozhi_wn5 -lnihaoxiaozhi_wn5X2 -lnihaoxiaozhi_wn5X3 -lnihaoxiaoxin_wn5X3 -lcustomized_word_wn5 -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/cekboard.ino.elf
/Users/tonymaryana/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/cekboard.ino.bin /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/arduino_build_209542/cekboard.ino.elf
[10125] Error loading Python lib '/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/_MEIIpKsPK/libpython3.8.dylib': dlopen: dlopen(/var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/_MEIIpKsPK/libpython3.8.dylib, 10): Symbol not found: ____chkstk_darwin
Referenced from: /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/_MEIIpKsPK/libintl.8.dylib
Expected in: /usr/lib/libSystem.B.dylib
in /var/folders/2k/007q1_8n4vx869_z_58nf6680000gn/T/_MEIIpKsPK/libintl.8.dylib
exit status 255
Error compiling for board ESP32 Dev Module.
Thank you very much, bhargav3 - this worked for me after I upgraded to 1.06, although I also needed to change 'python' to 'python3' as I upgraded to v3 python as well.
Thanks for the details - I was getting quite frustrated with this issue.
Hi Bhargav3. Thank you for this fix. I am not exactly sure what you mean in step 3 and 4. Specifically how to find these things and change them. Where do I run that command? Terminal, in the preferences somewhere? Apologies, just a newbie to using Python with Arduino on a Mac. I was able to use it on a Windows PC last year, but this is a different animal and things change in a year. If you know of a video, or made one yourself, of how to do this, I'm a visual learner. Thank you very much for taking the time to read this and any help you can give!
can someone make a video tutorial of this because I can't really follow written tutorials so
thanks for this info, the same issue I have get
but my be this instruction should be:
tools.gen_esp32part.cmd=/usr/local/bin/pythonx "{runtime.platform.path}/t....
in my case python3 on all path-instructions
starting it from terminal always works for me.
I have a new problem this one can solve for macOS 12.3 but I update the macOS 13 now I got new problem could you please help me solve it.
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
python3 /Users/mymac/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/gen_esp32part.py -q /var/folders/9_/hlklmr6134n1376dfyz962s80000gn/T/arduino_build_351134/partitions.csv /var/folders/9_/hlklmr6134n1376dfyz962s80000gn/T/arduino_build_351134/sketch_nov03b.ino.partitions.bin
sh: line 1: 24096 Abort trap: 6 /Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild -sdk macosx -find python3 2> /dev/null
python3: error: sh -c '/Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild -sdk macosx -find python3 2> /dev/null' failed with exit code 34304: (null) (errno=No such file or directory)
xcode-select: Failed to locate 'python3', requesting installation of command line developer tools.
exit status 72
/Applications/Arduino.app/Contents/Java/arduino-builder returned 72
Error compiling for board DOIT ESP32 DEVKIT V1.
then I try to edit the platform.txt same as previous 12.3 I got the new error
/usr/bin/python /Users/mymac/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/tools/gen_esp32part.py -q /var/folders/9_/hlklmr6134n1376dfyz962s80000gn/T/arduino_build_351134/partitions.csv /var/folders/9_/hlklmr6134n1376dfyz962s80000gn/T/arduino_build_351134/sketch_nov03b.ino.partitions.bin
fork/exec /usr/bin/python: no such file or directory
and I think it because of the new macOS 13 change the path of the python but I can't find the new path would you help me with this
