Mac USB connection to R4 works every second attempt
I have no problem setting the Board Manager to
Arduino UNO R4 WiFi.
When I select Tools > Port in IDE-2 it shows
/dev/cu.usbmodem1101
When I try to upload my script I get error:
No device found on usbmodem1101
I go back to IDE-2 and now
Tools > Port shows
/dev/cu.usbmodem4827E2E11CF42 (Arduino UNO R4 WiFi)
If I select that my script will upload and run.
But when I come back to IDE-2, Tools > Port again shows:
usbmodem1101
This means that I can only upload a script every second time.
Sometimes it takes 25 seconds trying to upload.
Pretty frustrating!
I have only been using Arduino for about a month.
DETAILS:
MacBook Pro M1Max Sonoma 14.6.1
Board: Arduino UNO R4 WiFi
Firmware: I have upgraded to 4.1
Hardware: MPU6050 accelerometer connected by serial.
Output: via serial in IDE-2
Project:
Using the accelerometer to make a joystick emulator to control the mouse cursor via Human Interface through USB.
At this stage it is not actually moving the mouse. Just displaying accelerometer results in the serial display of IDE-2.
I searched through Hardware posts on this forum and did not find any posts about this problem. I could not find a SEARCH button!
PS:
I have the same problem with an empty script.
I did try switching USB-C to USB-C sea to shining sea cables.
Using IDE 2.3.2.
After rebooting my Mac and unplugging the Arduino I found that the Blink example works OK. So it appears to be my software. I will have to tidy it up before posting code!
In the meantime any suggestions would be helpful!
Thanks in advance.
This is the main error message.
Port monitor error: command 'open' failed: no such file or directory. Could not connect to /dev/cu.usbmodem1101 serial port.
Could it be caused by using HID.h and mouse.h ?
I turned on verbose compilation and loading, resulting in this huge printout: I don't see anything obvious here. There are two Documents> files called Arduino and Arduino15.
loading library from /Users/Evan/Library/Arduino15/libraries/  Libraries must be placed here in :Users:Evan:Library:Arduino15:libraries:Servo:src:: invalid library: no header files found
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0
Using core 'arduino' from platform in folder: /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0
Detecting libraries used...
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /dev/null
Alternatives for Mouse.h: [Mouse@1.0.1 Mouse@1.0.1]
ResolveLibrary(Mouse.h)
  -> candidates: [Mouse@1.0.1 Mouse@1.0.1]
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -I/Users/Evan/Documents/Arduino/libraries/Mouse/src -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /dev/null
Alternatives for HID.h: [HID]
ResolveLibrary(HID.h)
  -> candidates: [HID]
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -I/Users/Evan/Documents/Arduino/libraries/Mouse/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /dev/null
Alternatives for MPU6050_tockn.h: [MPU6050_tockn@1.5.2]
ResolveLibrary(MPU6050_tockn.h)
  -> candidates: [MPU6050_tockn@1.5.2]
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -I/Users/Evan/Documents/Arduino/libraries/Mouse/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID -I/Users/Evan/Documents/Arduino/libraries/MPU6050_tockn/src -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire]
ResolveLibrary(Wire.h)
  -> candidates: [Wire]
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -I/Users/Evan/Documents/Arduino/libraries/Mouse/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID -I/Users/Evan/Documents/Arduino/libraries/MPU6050_tockn/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/Wire -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/Evan/Documents/Arduino/libraries/Mouse/src/Mouse.cpp
Using cached library dependencies for file: /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID/HID.cpp
Using cached library dependencies for file: /Users/Evan/Documents/Arduino/libraries/MPU6050_tockn/src/MPU6050_tockn.cpp
Using cached library dependencies for file: /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/Wire/Wire.cpp
Generating function prototypes...
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -I/Users/Evan/Documents/Arduino/libraries/Mouse/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID -I/Users/Evan/Documents/Arduino/libraries/MPU6050_tockn/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/Wire -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/3759009306/sketch_merged.cpp
/Users/Evan/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/3759009306/sketch_merged.cpp
Compiling sketch...
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -Wall -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/tinyusb -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino/api/deprecated-avr-comp -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/cores/arduino -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -I/Users/Evan/Documents/Arduino/libraries/Mouse/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID -I/Users/Evan/Documents/Arduino/libraries/MPU6050_tockn/src -I/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/Wire -iprefix/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0 @/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/includes.txt /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp -o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp.o
Compiling libraries...
Compiling library "Mouse"
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/Mouse/Mouse.cpp.o
Compiling library "HID"
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/HID/HID.cpp.o
Compiling library "MPU6050_tockn"
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/MPU6050_tockn/MPU6050_tockn.cpp.o
Compiling library "Wire"
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/Wire/Wire.cpp.o
Compiling core...
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/tmp_gen_c_files/common_data.c.o
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/tmp_gen_c_files/pin_data.c.o
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/tmp_gen_c_files/main.c.o
Using previously compiled file: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/variant.cpp.o
Using precompiled core: /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/cores/arduino_renesas_uno_unor4wifi_47a15b0cebf961bafd7ec3f63aee5e3c/core.a
Linking everything together...
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -Wl,--gc-sections --specs=nosys.specs -Wall -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.elf -L/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D -L/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4 -T/Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/fsp.ld /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/sketch/MPU6050_mouse_4_way_Switch_v8.ino.cpp.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/Mouse/Mouse.cpp.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/HID/HID.cpp.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/MPU6050_tockn/MPU6050_tockn.cpp.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/libraries/Wire/Wire.cpp.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/tmp_gen_c_files/common_data.c.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/tmp_gen_c_files/main.c.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/tmp_gen_c_files/pin_data.c.o /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/core/variant.cpp.o -Wl,--whole-archive -Wl,--start-group /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/variants/UNOWIFIR4/libs/libfsp.a /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/../../cores/arduino_renesas_uno_unor4wifi_47a15b0cebf961bafd7ec3f63aee5e3c/core.a -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group -Wl,-Map,/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.map
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary -j .text -j .data /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.elf /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.bin
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -j .text -j .data /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.elf /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.hex
Multiple libraries were found for "Mouse.h"
  Used: /Users/Evan/Documents/Arduino/libraries/Mouse
  Not used: /Users/Evan/Library/Arduino15/libraries/Mouse
Using library Mouse at version 1.0.1 in folder: /Users/Evan/Documents/Arduino/libraries/Mouse
Using library HID in folder: /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/HID (legacy)
Using library MPU6050_tockn at version 1.5.2 in folder: /Users/Evan/Documents/Arduino/libraries/MPU6050_tockn
Using library Wire in folder: /Users/Evan/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.2.0/libraries/Wire (legacy)
/Users/Evan/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.elf
Sketch uses 65728 bytes (25%) of program storage space. Maximum is 262144 bytes.
Global variables use 9500 bytes (28%) of dynamic memory, leaving 23268 bytes for local variables. Maximum is 32768 bytes.
"/Users/Evan/Library/Arduino15/packages/arduino/tools/bossac/1.9.1-arduino5/bossac" -d --port=cu.usbmodem1101 -U -e -w "/private/var/folders/rk/3qmhyc0j6n795vyq8mbvzcw80000gn/T/arduino/sketches/605758A9EC72359FEE504BB9DA7A6E8D/MPU6050_mouse_4_way_Switch_v8.ino.bin" -R
No device found on cu.usbmodem1101
Failed uploading: uploading error: exit status 1
