Sorry, yes: Arduino IDE 2.0, not Android
I dont think that the 2.0 is the cause, I tried it with 1.8.19 before, that gives me a similar error output:
Arduino: 1.8.19 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/f/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/f/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/f/Documents/Projekte/Arduino/libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=0000_0000 -ide-version=10819 -build-path /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211 -warnings=default -build-cache /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_cache_757981 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/f/Documents/Projekte/Arduino/code/ESP8266/Tueroeffner/tueroeffner.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/f/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/f/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/f/Documents/Projekte/Arduino/libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=0000_0000 -ide-version=10819 -build-path /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211 -warnings=default -build-cache /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_cache_757981 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mklittlefs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=/Users/f/Library/Arduino15/packages/esp8266/tools/mkspiffs/3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1 -verbose /Users/f/Documents/Projekte/Arduino/code/ESP8266/Tueroeffner/tueroeffner.ino
Using board 'nodemcuv2' from platform in folder: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2
Using core 'esp8266' from platform in folder: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2
Detecting libraries used...
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lwip2/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/variants/nodemcu /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp -o /dev/null
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lwip2/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/variants/nodemcu -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp -o /dev/null
Alternatives for UniversalTelegramBot.h: [Universal-Arduino-Telegram-Bot-master@1.3.0]
ResolveLibrary(UniversalTelegramBot.h)
-> candidates: [Universal-Arduino-Telegram-Bot-master@1.3.0]
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lwip2/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/variants/nodemcu -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src -I/Users/f/Documents/Projekte/Arduino/libraries/Universal-Arduino-Telegram-Bot-master/src /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp -o /dev/null
Alternatives for ArduinoJson.h: [ArduinoJson@6.19.4]
ResolveLibrary(ArduinoJson.h)
-> candidates: [ArduinoJson@6.19.4]
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lwip2/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/variants/nodemcu -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src -I/Users/f/Documents/Projekte/Arduino/libraries/Universal-Arduino-Telegram-Bot-master/src -I/Users/f/Documents/Projekte/Arduino/libraries/ArduinoJson/src /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/CertStoreBearSSL.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiGratuitous.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiMulti.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiSTA-WPS.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/ESP8266WiFiScan.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/WiFiClient.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/WiFiServer.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/WiFiUdp.cpp
Using cached library dependencies for file: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src/enable_wifi_at_boot_time.cpp
Using cached library dependencies for file: /Users/f/Documents/Projekte/Arduino/libraries/Universal-Arduino-Telegram-Bot-master/src/UniversalTelegramBot.cpp
Generating function prototypes...
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lwip2/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/variants/nodemcu -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src -I/Users/f/Documents/Projekte/Arduino/libraries/Universal-Arduino-Telegram-Bot-master/src -I/Users/f/Documents/Projekte/Arduino/libraries/ArduinoJson/src /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp -o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/signing.py --mode header --publickey /Users/f/Documents/Projekte/Arduino/code/ESP8266/Tueroeffner/public.key --out /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core/Updater_Signing.h
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lwip2/include -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/include -I/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/core -c -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/cores/esp8266 -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/variants/nodemcu -I/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi/src -I/Users/f/Documents/Projekte/Arduino/libraries/Universal-Arduino-Telegram-Bot-master/src -I/Users/f/Documents/Projekte/Arduino/libraries/ArduinoJson/src /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp -o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp.o
Compiling libraries...
Compiling library "ESP8266WiFi"
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/BearSSLHelpers.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/CertStoreBearSSL.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFi.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/WiFiClient.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/WiFiServer.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/WiFiUdp.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFi.a
Compiling library "Universal-Arduino-Telegram-Bot-master"
Using previously compiled file: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/Universal-Arduino-Telegram-Bot-master/UniversalTelegramBot.cpp.o
Compiling library "ArduinoJson"
Compiling core...
Using precompiled core: /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_cache_757981/core/core_50bacf3519bde935c4b8dc226f342ffd.a
Linking everything together...
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/mkdir.py -p /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/ld_h/
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/cp.py /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/ld/eagle.flash.4m2m.ld /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/ld_h/local.eagle.flash.ld.h
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/ld_h/local.eagle.flash.ld.h -o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/local.eagle.flash.ld
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/ld/eagle.app.v6.common.ld.h -o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/local.eagle.app.v6.common.ld
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc -fno-exceptions -Wl,-Map -Wl,/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.map -g -Werror=return-type -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static -L/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lib -L/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/lib/NONOSDK22x_190703 -L/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211 -L/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sdk/libc/xtensa-lx106-elf/lib -Tlocal.eagle.flash.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.elf -Wl,--start-group /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/sketch/tueroeffner.ino.cpp.o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/ESP8266WiFi/ESP8266WiFi.a /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/libraries/Universal-Arduino-Telegram-Bot-master/UniversalTelegramBot.cpp.o /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_cache_757981/core/core_50bacf3519bde935c4b8dc226f342ffd.a -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group -L/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/elf2bin.py --eboot /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/bootloaders/eboot/eboot.elf --app /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.elf --flash_mode dio --flash_freq 40 --flash_size 4M --path /Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin --out /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.bin
Creating BIN file "/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.bin" using "/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/bootloaders/eboot/eboot.elf" and "/var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.elf"
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/signing.py --mode sign --privatekey /Users/f/Documents/Projekte/Arduino/code/ESP8266/Tueroeffner/private.key --bin /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.bin --out /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.bin.signed --legacy /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.bin.legacy_sig
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/sizes.py --elf /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.elf --path /Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin --mmu "-DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 372272 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28377 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1616 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 4860 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 26096 ) - zeroed variables (global, static) in RAM/HEAP
Using library ESP8266WiFi at version 1.0 in folder: /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/ESP8266WiFi
Using library Universal-Arduino-Telegram-Bot-master at version 1.3.0 in folder: /Users/f/Documents/Projekte/Arduino/libraries/Universal-Arduino-Telegram-Bot-master
Using library ArduinoJson at version 6.19.4 in folder: /Users/f/Documents/Projekte/Arduino/libraries/ArduinoJson
/Users/f/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-size -A /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.elf
Sketch uses 407125 bytes (38%) of program storage space. Maximum is 1044464 bytes.
Global variables use 32572 bytes (39%) of dynamic memory, leaving 49348 bytes for local variables. Maximum is 81920 bytes.
/Users/f/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3 -I /Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/upload.py --chip esp8266 --port /dev/cu.usbserial-620 --baud 115200 --before default_reset --after hard_reset write_flash 0x0 /var/folders/mr/s_hzmn256fjg_nx49r4yx2_80000gp/T/arduino_build_9211/tueroeffner.ino.bin
esptool.py v3.0
Serial port /dev/cu.usbserial-620
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "/Users/f/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 529, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
The very same board works without problem with Windows, so it is likely not the board neither.
I had the same problem with a bigger NodeMCU Board, Windows works, Mac not.
This board is a mini NodeMCU board, has not flash button, only reset.
Thank!
EDiT: it is this board: D1 ESP8266 Mini WLAN Board Mikrokontroller Wifi Modul Wemos Nodemcu Arduino | eBay
