Can someone help? I found this site Arduino Hardware Interrupts Tutorial and can't get the three example programs to work. Must be something simple! I get an error
error: macro names must be identifiers
#define LED 9
exit status 1
system
April 17, 2017, 7:48pm
2
Post your code.
Use code tags.
#define LED 9
volatile byte state = LOW;
pinMode(LED, OUTPUT);
attachInterrupt(0, toggle, RISING);
digitalWrite(LED, state);
void toggle() {
state = !state;
Except you chopped off the #define .
MadTom544:
#define LED 9
void toggle() {
state = !state;
void toggle() {
state = !state;
This compiles fine if I remove the duplicate definition of toggle()
I still get an error:
#define LED 9
exit status 1
#define LED 9
void toggle() {
state = !state;
Copy and paste it to a new .ino.
Is that your full code? It compiles fine for me on IDE version 1.6.9
That's the first example: http://www.bristolwatch.com/arduino/arduino_irq.htm
I'm using 1.8.2 IDE Uno on Com5
That's the code and I get this error:
sketch_apr17a:2: error: macro names must be identifiers
#define LED 13
exit status 1
try changing LED to LED1 or somthing
Mark
Is there a way to "clean" an Arduino project? It really looks like the IDE is stubbornly holding on to some pre-compiled file or something.
I still get an error!
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\MadTo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\MadTo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\MadTo\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10802 -build-path C:\Users\MadTo\AppData\Local\Temp\arduino_build_119315 -warnings=default -build-cache C:\Users\MadTo\AppData\Local\Temp\arduino_cache_81419 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\MadTo\AppData\Local\Temp\arduino_modified_sketch_634909\sketch_apr17a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\MadTo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\MadTo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\MadTo\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10802 -build-path C:\Users\MadTo\AppData\Local\Temp\arduino_build_119315 -warnings=default -build-cache C:\Users\MadTo\AppData\Local\Temp\arduino_cache_81419 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\MadTo\AppData\Local\Temp\arduino_modified_sketch_634909\sketch_apr17a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Build options changed, rebuilding all
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\MadTo\AppData\Local\Temp\arduino_build_119315\sketch\sketch_apr17a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\MadTo\AppData\Local\Temp\arduino_build_119315\sketch\sketch_apr17a.ino.cpp" -o "C:\Users\MadTo\AppData\Local\Temp\arduino_build_119315\preproc\ctags_target_for_gcc_minus_e.cpp"
#define LED1 9
exit status 1
From the HTML code of http://www.bristolwatch.com/arduino/arduino_irq.htm:
#define LED 9
You have non-breaking spaces instead of regular spaces in your sketch.
Just copy the sketch from reply #2 and everything will be okay.
The forum software converts certain characters when you post a message.
Mark, that makes sense, but still doesn't work! tried to delete spaces...
OK! Works now! I had to rewrite to whole code. I guess copy and paste didn't work from that site.
Thanks for the help! I learned something new! Any other way around this problem?
color coding helps
#define LED 9
void toggle() {
state = !state;
LarryD
April 18, 2017, 1:50am
16
"Any other way around this problem?"
Stop being a script kitty.
is there any to help me i have the same problem
system
April 3, 2018, 5:25pm
18
safikulislam729:
You have some code you didn't post. It generates some errors you didn't post. The solution seems obvious to me.
tigger
April 3, 2018, 5:46pm
19
Surprised it didn't throw up stray \ ?? (sorry about that non-code) errors during the compile.
Tabs, spaces, quotation marks can all generate loads of stray errors from copy and paste code, as I know.
I've never found a quick way of stripping them out. Notepad ++ has a lot of useful editing tools, but never very successful. Dumping the code into Excel and using the CLEAN() function removes some, but not all non-printing characters. Re-writing the code is the penance.
Be careful with copy and paste as the characters may not be ASCII or precisely what you see. This is particularly troublesome with single and double quotes.
